查看: 9714|回复: 34
SD卡SPI DMA模式FatFs读写,速度超1MB/s
339
1621
1621
2014-12-19
541 小时
发表于 2015-10-10 13:58:23 | 显示全部楼层 |阅读模式
采用SPI DMA方式读写SD卡,适用于STM32F4。FatFs版本为最新的R0.11a。
一次读写512、1024、2048或4096字节,连续读写10s,然后计算读写速度。
测试的是一张8G的三星TF卡,以下是从串口获取的读写速度情况。
start reading ARTOGARD.WAV
fr: 0 num: 19522 br: 512
speed: 976.1kB/s
fr: 0 num: 10866 br: 1024
speed: 1086.6kB/s
fr: 0 num: 7660 br: 2048
speed: 1532.0kB/s
fr: 0 num: 4827 br: 4096
speed: 1930.8kB/s
start writing 512.BIN
fr: 0 num: 6610 br: 512
speed: 330.5kB/s
start writing 1024.BIN
fr: 0 num: 3837 br: 1024
speed: 383.7kB/s
start writing 2048.BIN
fr: 0 num: 4037 br: 2048
speed: 807.4kB/s
start writing 4096.BIN
fr: 0 num: 3366 br: 4096
speed: 1346.4kB/s
SPI DMA方式核心部分代码如下,详见源码。
[C] 纯文本查看 复制代码
void SD_DMA_Config(void)
    DMA_InitTypeDef DMA_InitStructure;
    RCC_AHB1PeriphClockCmd(SD_DMA_RCC, ENABLE);
    DMA_DeInit(SD_DMA_RX_STREAM);
    DMA_DeInit(SD_DMA_TX_STREAM);
    DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)(&(SD_SPI->DR));
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
    DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
    DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
    DMA_InitStructure.DMA_Priority = DMA_Priority_High;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
    DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
    DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //!!!
    DMA_InitStructure.DMA_BufferSize = 0; //!!!
    DMA_InitStructure.DMA_Channel = SD_DMA_RX_CHANNEL;
    DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)0; //!!!
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
    DMA_Init(SD_DMA_RX_STREAM, &DMA_InitStructure);
    DMA_InitStructure.DMA_Channel = SD_DMA_TX_CHANNEL;
    DMA_InitStructure.DMA_DIR = DMA_DIR_MemoryToPeripheral;
    DMA_Init(SD_DMA_TX_STREAM, &DMA_InitStructure);
    SPI_I2S_DMACmd(SD_SPI, SPI_I2S_DMAReq_Rx, ENABLE);
    SPI_I2S_DMACmd(SD_SPI, SPI_I2S_DMAReq_Tx, ENABLE);
SD卡读取设置(写入类似)
[C] 纯文本查看 复制代码
// 设置接收通道
SD_DMA_RX_STREAM->CR |= DMA_MemoryInc_Enable; //自增
SD_DMA_RX_STREAM->M0AR = (uint32_t)pBuffer;
SD_DMA_RX_STREAM->NDTR = BlockSize;
//DMA_SetCurrDataCounter(SD_DMA_RX_STREAM, BlockSize);
// 设置发送通道
SD_DMA_TX_STREAM->CR &= ~DMA_MemoryInc_Enable; //不自增
SD_DMA_TX_STREAM->M0AR = (uint32_t)&Dummy_Send;
SD_DMA_TX_STREAM->NDTR = BlockSize;
//DMA_SetCurrDataCounter(SD_DMA_TX_STREAM, BlockSize);
// 启动
SD_DMA_RX_STREAM->CR |= DMA_SxCR_EN; //先启动接收
//DMA_Cmd(SD_DMA_RX_STREAM, ENABLE);
while(!(SD_DMA_RX_STREAM->CR & DMA_SxCR_EN));
//while(DMA_GetCmdStatus(SD_DMA_RX_STREAM) == DISABLE);
SD_DMA_TX_STREAM->CR |= DMA_SxCR_EN; //再启动发送
//DMA_Cmd(SD_DMA_TX_STREAM, ENABLE);
while(!(SD_DMA_TX_STREAM->CR & DMA_SxCR_EN));
//while(DMA_GetCmdStatus(SD_DMA_TX_STREAM) == DISABLE);
// 等待完成
while(!((SD_DMA->HISR & RESERVED_MASK) & SD_DMA_TX_TCIF));
//while(!DMA_GetFlagStatus(SD_DMA_TX_STREAM, SD_DMA_TX_TCIF));
while(!((SD_DMA->LISR & RESERVED_MASK) & SD_DMA_RX_TCIF));
//while(!DMA_GetFlagStatus(SD_DMA_RX_STREAM, SD_DMA_RX_TCIF));
// 清除完成标志
SD_DMA->LIFCR = SD_DMA_RX_TCIF & RESERVED_MASK; //清除接收完成标志
//DMA_ClearFlag(SD_DMA_RX_STREAM, SD_DMA_RX_TCIF);
SD_DMA->HIFCR = SD_DMA_TX_TCIF & RESERVED_MASK; //清除发送完成标志
//DMA_ClearFlag(SD_DMA_TX_STREAM, SD_DMA_TX_TCIF);
// 停止
SD_DMA_TX_STREAM->CR &= ~DMA_SxCR_EN;
//DMA_Cmd(SD_DMA_TX_STREAM, DISABLE);
while(SD_DMA_TX_STREAM->CR & DMA_SxCR_EN);
//while(DMA_GetCmdStatus(SD_DMA_TX_STREAM) == ENABLE);
SD_DMA_RX_STREAM->CR &= ~DMA_SxCR_EN;
//DMA_Cmd(SD_DMA_RX_STREAM, DISABLE);
while(SD_DMA_RX_STREAM->CR & DMA_SxCR_EN);
//while(DMA_GetCmdStatus(SD_DMA_RX_STREAM) == ENABLE);
STM32F3与F4的DMA存在一些区别,故DMA部分的代码需要作相应修改,详见附件。
SPI_DMA_TEST.rar
8.7 MB, 下载次数: 16829
SD_SPI_DMA_STM32F3.rar
9.75 KB, 下载次数: 1177
72
2719
3445
3445
2014-8-4
676 小时
发表于 2015-10-10 15:08:40 | 显示全部楼层
谢谢分享,有时间了试试~~~
以我资质之鲁钝,当尽平心静气、循序渐进、稳扎稳打之力。
125
259
259
2013-1-10
10 小时
发表于 2015-10-10 15:43:53 | 显示全部楼层
我用10M以太网  通F407向闪迪的tf卡内写数据 通过sdio+znfat  传输+写入一个15M 的数据 竟然用了我27分钟 太长了
个人博客www.xiaovdiy.cn
https://shop100764513.taobao.com/
510
9万
133625
133625
1274 小时
发表于 2015-10-10 18:15:09 | 显示全部楼层
谢谢分享....
78
178
178
2012-11-21
发表于 2015-10-12 22:20:03 | 显示全部楼层
谢谢分享。。。
44
186
1255
1255
2012-9-1
65 小时
发表于 2015-10-13 18:55:15 | 显示全部楼层
标记一下,也许有用,谢谢分享
339
1621
1621
2014-12-19
541 小时
 楼主| 发表于 2015-10-13 19:01:38 | 显示全部楼层
回复【7楼】yklstudent:
适用于STM32F3代码见附件。
120
230
230
2015-6-4
发表于 2015-10-19 13:00:55 | 显示全部楼层
学习了,以后有时一定好好学学!
510
9万
133625
133625
1274 小时
发表于 2016-6-1 20:21:14 | 显示全部楼层
cool
510
9万
133625
133625
1274 小时
发表于 2016-6-1 20:22:36 | 显示全部楼层
谢谢分享
51
51
2016-6-3
15 小时
发表于 2016-7-12 12:30:14 | 显示全部楼层
谢谢分享
39
39
2015-9-6
发表于 2016-7-12 13:38:55 | 显示全部楼层
楼主好人,谢谢分享
62
339
339
2012-5-8
83 小时
发表于 2016-7-13 08:40:26 | 显示全部楼层
谢谢分享
831
831
2015-9-1
161 小时
发表于 2016-7-13 09:44:47 | 显示全部楼层
感谢  正需要
85
225
225
2012-10-11
65 小时
发表于 2016-7-15 19:31:37 | 显示全部楼层
谢谢楼主的分享,DMA模式SPI
77
346
346
2014-1-22
41 小时
发表于 2016-7-20 15:46:37 | 显示全部楼层
谢谢楼主,我用FATF32读取SD卡文件太慢,感觉你的程序帮助很大
任何一件事情,只要心甘情愿,总是能够变得简单。
57
57
2015-2-7
发表于 2016-8-12 19:58:01 | 显示全部楼层
楼主好人
年轻即出发, 一天两天算不了什么。hold~
57
57
2015-2-7
发表于 2016-8-12 20:15:17 | 显示全部楼层
谢谢分享,有时间了试试~~~
87
331
906
906
2016-3-26
116 小时
发表于 2016-8-25 11:42:58 | 显示全部楼层
雨山 发表于 2015-10-10 15:43
我用10M以太网  通F407向闪迪的tf卡内写数据 通过sdio+znfat  传输+写入一个15M& ...
你好 朋友,你的问题解决了吗?我现在学这块,跟你的一样,也是网络传数据保存在SD卡,用的时间也是很久,如果你的问题已经解决了可以帮助我一下吗?
43
170
170
2010-12-14
53 小时
发表于 2016-11-27 09:28:54 | 显示全部楼层
谢谢分享
53
371
982
982
2016-6-15
452 小时
发表于 2016-11-27 10:07:15 | 显示全部楼层
SPI有这么快吗?楼主SPI频率多少?
magicigloo 该用户已被删除
发表于 2017-1-8 03:40:24 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
178
178
2012-11-5
34 小时
发表于 2017-2-11 10:16:34 | 显示全部楼层
感谢分享
40
40
2016-12-15
发表于 2017-2-28 13:41:04 | 显示全部楼层
谢谢楼主的分享,但是我在修改IO口后,发现没办法烧录呀Erase Failed!,是不是PB4在其他地方还有使用呢,我PB4作为SW的复位脚用的
98
98
2011-5-17
18 小时
发表于 2017-3-5 18:22:47 | 显示全部楼层
不错,楼主可以试试高速SPI,42M的SPI速度 可以极大提升读卡速度
39
39
2015-3-17
发表于 2017-3-29 15:51:28 | 显示全部楼层
谢谢楼主,通过借鉴学习,解决了我的问题,非常感谢啊!!!
606
606
2017-3-17
38 小时
发表于 2017-3-30 09:01:06 | 显示全部楼层
谢谢分享....
39
150
150
2016-9-24
26 小时
发表于 2017-4-6 17:50:59 | 显示全部楼层
好,谢谢分享
2017-4-7
21 小时
发表于 2017-4-10 06:51:11 | 显示全部楼层
你给的是平均值吧,一个一个时间来看,写入SD卡的速度稳定吗?里面会不会有一些很奇怪的写入时间?
44
298
209
209
2016-9-9
84 小时
发表于 2017-4-10 08:34:25 | 显示全部楼层
如果SDIO方式读写SD卡,用DMA速度多快,不用多块?
29
119
119
2015-1-15
19 小时
发表于 2017-6-20 08:51:55 | 显示全部楼层
楼主, 你好我把你的代码移植到了STM32F103 上面, SPI用的是SPI3, 最后速度是这样子的, 感觉差的好多。。。
--------SD Card Info--------
fr: 0 num: 1000 br: 512
speed: 50.0kB/s
fr: 0 num: 666 br: 1024
speed: 66.6kB/s
fr: 0 num: 400 br: 2048
speed: 80.0kB/s
fr: 0 num: 222 br: 4096
speed: 88.8kB/s
fr: 0 num: 930 br: 512
speed: 46.5kB/s
fr: 0 num: 324 br: 1024
speed: 32.4kB/s
fr: 0 num: 234 br: 2048
speed: 46.8kB/s
fr: 0 num: 143 br: 4096
speed: 57.2kB/s
48
48
2017-8-31
发表于 2018-6-1 11:00:54 | 显示全部楼层
bbssuiji 发表于 2017-6-20 08:51
楼主, 你好我把你的代码移植到了STM32F103 上面, SPI用的是SPI3, 最后速度是这样子的, 感觉差的好多。 ...
您好,能否分享下移植代码,我正在调试这方面程序,没有DMA的SPI,读取SD卡速度只有40kB/s。
116
664
664
2015-11-26
131 小时
发表于 2018-6-1 14:49:02 | 显示全部楼层
可以参考st官方的sd fatfs dma读写    支持rtos   大数据读写都不影响调度
127
207
207
2018-4-18
10 小时
发表于 2018-6-19 16:54:09 | 显示全部楼层
谢谢楼主分享
117
117
2018-6-14
23 小时
发表于 2018-6-27 18:57:03 | 显示全部楼层
谢谢楼主分享
报名原子哥新品发布会&粉丝见面会上一条 /1 下一条
GMT+8, 2018-10-16 12:12
