查看: 806|回复: 0
求msp430 模拟SPI口实现flah读写
41
159
159
2016-11-27
15 小时
发表于 2017-5-31 21:34:08 | 显示全部楼层 |阅读模式
#include <msp430.h>
char readdata=0;
char busy_data=0;
void write_byte(char data_byte);
void send_command(char address1,char address2, char address3,char data);// command and address and data
char recive_data(char read_address1, char read_address2,char read_address3);
void delay();
void erase(char command,char erase_address1,char erase_address2,char erase_address3);
void read_busy(void);
int main( void )
  // Stop watchdog timer to prevent time out reset
    WDTCTL = WDTPW + WDTHOLD;
    P2DIR|=BIT5+BIT4+BIT0;         //flsah sck hold cs out
    P4DIR|=BIT2+BIT3;   //flash  wp si output
    P4REN|=BIT1;            // so pull up
    P4OUT|=BIT1;             //flash so pullup  selected p4.1
    P4OUT|=BIT2;             //wp=1
    P6DIR=BIT4;
    P6OUT=BIT4;            //led
    P2OUT|=BIT0 ; //CS=1;
    P2OUT|=BIT5;  //sck=1;
    //P2OUT|=BIT4;  // hold =1
    _NOP();
    _NOP();
    P6OUT^=BIT4;
    erase(0x20,0x00,0x00,0x00);
    read_busy();
    send_command(0x00,0x01,0x01,0x00); //xie,mingling
    read_busy();
     readdata=recive_data(0x00,0x01,0x01);
     //  send_command(0x00,0x00,0x00,0x0f); //xie,mingling
      // if(readdata==0x00)
       P6OUT^=BIT4;
       delay();
    //  readdata=recive_data(0x00,0x01,0x01);
char num=0;
for(num=0;num<=7;num++)
     if(data_byte&0x80)
       P4OUT|=BIT3 ;                //si=1;
       P4OUT&=~BIT3;              //si=0;
       P2OUT&=~BIT5;             //sck=0;
       _NOP();
       _NOP();
       _NOP();
       _NOP();
        data_byte=data_byte<<1; //数据从高位传输
void send_command(char address1, char address2 ,char address3 ,char data)
  _NOP();
  P2OUT&=~BIT0 ; //CS=0;
  write_byte(0x06);   // write command
  write_byte(address1);
  write_byte(address2);
  write_byte(address3);
  write_byte(data);
  _NOP();
  _NOP();
  _NOP();
char recive_data(char read_address1,char read_address2, char read_address3)
   char read_data=0;
   char num=0;
  _NOP();
  write_byte(0x03);
  write_byte(read_address1);
  write_byte(read_address2);
  write_byte(read_address3);
  for(num=0;num<8;num++)
      read_data<<=1;
      _NOP();
      _NOP();
      _NOP();
      _NOP();
    if(P4IN&0x02)
       read_data|=0x01;
       read_data&=0xfe;
      _NOP();
      _NOP();
    _NOP();
    _NOP();
    _NOP();
   return read_data;
  _NOP();
  write_byte(0x06);
  write_byte(command);
  write_byte(erase_address1);
  write_byte(erase_address2);
  write_byte(erase_address3);
  _NOP();
  _NOP();
  _NOP();
void delay()
unsigned  int i=0;
unsigned  int j=0;
   for(i=0;i<=500;i++)
      for(j=0;j<=250;j++)
void read_busy()
   char read_data=0;
   char num=0;
   _NOP();
   write_byte(0x05);        // read the SR1
   do{
                _NOP();
                _NOP();
                _NOP();
                _NOP();
                if(P4IN&0x02)
                 read_data|=0x01;
                 read_data&=0xfe;
                 read_data<<=1;
            _NOP();
            _NOP();
            _NOP();
          busy_data=read_data;
   while((busy_data&0x03)!=0x02);
用的单片机是msp430f5438A,模拟spi实现对flash程序的读写,现在读出的数据始终是FF,即应该没有写进数据,那位大神开源指点一二!
GMT+8, 2019-3-26 14:04
