查看: 388|回复: 6
多个任务,可以切换,但是第二个任务不能GUI_DispStringAt卡死,进入
61
258
258
2017-4-16
31 小时
发表于 2017-9-11 22:43:37 | 显示全部楼层 |阅读模式
如题所示:我参考原子的手册进行移植stemwin加ucosiii,我的main函数如下所示:
[AppleScript] 纯文本查看 复制代码
int main(void) {
	OS_ERR err;
	HAL_Init(); /* See Note 1.                                          */
	BSP_SystemClkCfg(); /* Initialize CPU clock frequency to 216Mhz             */
	CPU_Init(); /* Initialize the uC/CPU services                       */
	Mem_Init(); /* Initialize Memory Managment Module                   */
	Math_Init(); /* Initialize Mathematical Module                       */
	CPU_IntDis(); /* Disable all Interrupts.                              */
	BSP_Init(); /* Initialize BSP functions                             */
	OSInit(&err); /* Init uC/OS-III.                                      */
	App_OS_SetAllHooks();
	MessQueue_Init ();
	OSTaskCreate(&AppTaskStartTCB, /* Create the start task                                */
	"App Task Start", AppTaskStart, 0u,
	APP_CFG_TASK_START_PRIO, &AppTaskStartStk[0u],
			AppTaskStartStk[APP_CFG_TASK_START_STK_SIZE / 10u],
			APP_CFG_TASK_START_STK_SIZE, 0u, 0u, 0u,
			(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR ), &err);
	OSStart(&err); /* Start multitasking (i.e. give control to uC/OS-III). */
	while (DEF_ON) { /* Should Never Get Here.                               */
在main函数中创建了一个任务AppTaskStart,该函数如下所示:
static void AppTaskStart(void *p_arg) {
	OS_ERR err;
	(void) p_arg;
	__HAL_RCC_CRC_CLK_ENABLE()
	  GUI_Init ();
#if OS_CFG_STAT_TASK_EN > 0u
	OSStatTaskCPUUsageInit(&err); /* Compute CPU capacity with no task running            */
#endif
#ifdef CPU_CFG_INT_DIS_MEAS_EN
	CPU_IntDisMeasMaxCurReset();
#endif
	APP_TRACE_DBG(("Creating Application Tasks\n\r"));
GUI_DispStringAt ("iysheng", 100, 200);
	AppTaskCreate(); /* Create Application tasks                             */
	while (DEF_TRUE) { /* Task body, always written as an infinite loop.       */
		//OSTaskDel((OS_TCB*) 0, &err);
在该AppTaskStart任务中,我执行了GUI_DispStringAt ("iysheng", 100, 200);可以正常显示。
我通过AppTaskCreate新建了一个任务AppTaskObj0:
static void AppTaskCreate(void) {
	OS_ERR os_err;
	/* ---------- CREATE KERNEL OBJECTS TEST TASK --------- */
	OSTaskCreate(&AppTaskObj0TCB, "Kernel Objects Task 0", AppTaskObj0, 0,
	APP_CFG_TASK_OBJ0_PRIO, &AppTaskObj0Stk[0],
			AppTaskObj0Stk[APP_CFG_TASK_OBJ_STK_SIZE / 10u],
			APP_CFG_TASK_OBJ_STK_SIZE, 0u, 0u, 0,
			(OS_OPT_TASK_STK_CHK | OS_OPT_TASK_STK_CLR ), &os_err);
AppTaskObj0任务中也执行了一次显示的函数GUI_DispStringAt ("iysheng", 0, 0);
static void AppTaskObj0(void *p_arg) {
	OS_ERR os_err;
	(void) p_arg;
	static uint8_t uline;
	static float ftemp;
	static uint32_t uitemp;
	static char rstr[64];
GUI_DispStringAt ("iysheng@163.com", 0, 0);
while (DEF_TRUE) {
现在的现象是任务可以切换到AppTaskObj0,但是执行该函数下的GUI_DispStringAt 时就出现卡死,进入Infinite_Loop
Default_Handler:
Infinite_Loop:
  b  Infinite_Loop
这是什么问题呢?
61
258
258
2017-4-16
31 小时
 楼主| 发表于 2017-9-11 23:02:53 | 显示全部楼层
如果把AppTaskObj0的优先级提高到比AppTaskStart的优先级高,那么会显示AppTaskObj0任务中的内容,但是低优先级的任务中的内容就不会显示了。也就是总是显示高优先级的任务中的内容,低优先级的任务的内容就不会显示,会卡死。
61
258
258
2017-4-16
31 小时
 楼主| 发表于 2017-9-12 14:49:49 | 显示全部楼层
主要问题,有两个:
1。每个任务都需要执行一次GUI_Init()函数。
2。我没有把自己调度出去,所以会出现上述问题。
经过我的修改,两个任务,任务一:
    (void)p_arg;        /* 避免编译器告警 */
    OS_ERR      p_err;
    	  GUI_Init ();
while (1)
    GUI_DispStringAt ("AppTaskObj0", 0, 0);
    OSTimeDlyHMSM(0,0,2,0,OS_OPT_TIME_DLY,&p_err);
//MainTask();
任务二:
static void AppTaskObj1(void *p_arg)
    OS_ERR      p_err;
     GUI_Init ();
while (1)
    GUI_DispStringAt ("AppTaskObj1", 200, 200);
//Task_1();
现在可以输出两个任务中的内容了,
之前之所以卡死,是因为我没有在新的任务重GUI_Init()。
489
9万
124777
124777
1050 小时
发表于 2017-9-12 23:48:40 | 显示全部楼层
102
280
280
2012-8-10
22 小时
发表于 2017-11-11 22:03:12 | 显示全部楼层
iysheng 发表于 2017-9-12 14:49
主要问题,有两个:
2。我没有把自己调度出去,所以会出现上 ...
不是很明白为什么要在每个任务里面都执行一次 GUI_Init()?
61
258
258
2017-4-16
31 小时
 楼主| 发表于 2018-3-7 11:55:28 | 显示全部楼层
我也没有搞清楚,感觉有些任务可以不执行GUI_Init()就可以正常显示,有些任务必须要执行GUI_Init()才能正常显示,不知道会不会是GNU编译器的问题。
192
321
321
2016-3-16
131 小时
发表于 2018-3-7 14:22:56 | 显示全部楼层
iysheng 发表于 2018-3-7 11:55
我也没有搞清楚,感觉有些任务可以不执行GUI_Init()就可以正常显示,有些任务必须要执行GUI_Init()才 ...
在每个线程(任务)的循环中,加入OSTimeDly(),让其他线程被调度器调度到。
路漫漫其修远兮,戒骄戒躁。
GMT+8, 2018-4-21 06:15
