查看: 771|回复: 14
STM32F446 ADC DMA模式下 经常OVR(数据溢出),导致ADC不工作
23
87
87
2017-9-9
16 小时
发表于 2017-11-8 21:57:47 | 显示全部楼层 |阅读模式
如题:STM32F446  ADC DMA模式下  经常OVR(数据溢出),导致ADC不工作。芯片STM32F446  ,系统时钟配置成168M,ADC为21M, 用PB0口进行ADC采样,软件触发方式,用DMA将采样数据存储在一个数组中。
程序跑着跑着ADC就停止工作,发现ADC_SR寄存器的OVR置为1,经过检查,也没查出有啥问题,请大神帮忙看看:
1、ADC配置如下
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
ADC_DeInit();
ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div4;//
ADC_CommonInit(&ADC_CommonInitStructure);
ADC_InitStructure.ADC_Resolution = ADC_Resolution_8b;
ADC_InitStructure.ADC_ScanConvMode = DISABLE;
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfConversion = 1;
ADC_Init(ADC1, &ADC_InitStructure);
ADC_RegularChannelConfig(ADC1,ADC_Channel_8, 1, ADC_SampleTime_3Cycles);//ADC12_IN_8
    /* Enable DMA request after last transfer (Single-ADC mode) */
ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
    /* Enable ADC1 DMA */
ADC_DMACmd(ADC1, ENABLE);
ADC_Cmd(ADC1, ENABLE);
2、DMA配置如下
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2, ENABLE);
  DMA_InitStructure.DMA_Channel = DMA_Channel_0;
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&(ADC1->DR);
  DMA_InitStructure.DMA_Memory0BaseAddr = (u32)addr;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
  DMA_InitStructure.DMA_BufferSize = len;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
  DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_Full;
  DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
  DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
  DMA_Init(DMA2_Stream0, &DMA_InitStructure);
  DMA_Cmd(DMA2_Stream0, ENABLE);
  DMA_ITConfig(DMA2_Stream0, DMA_IT_TC, DISABLE);
我用定时器定时读取DMA传出来的ADC的值,发现ADC采样的模拟数值是对的,但是通道不对,比如PA0输入1.5V,而读出的确是PA1为1.5V,即DMA传输出错了。修改方法,此时先DMA_DeInit(DMAy_Streamx); 重新初始化ADC; 之后再读数据就正常了。
Rank: 1
2017-11-23
发表于 2017-11-8 21:57:48 | 显示全部楼层
23
87
87
2017-9-9
16 小时
 楼主| 发表于 2017-11-8 23:27:45 | 显示全部楼层
23
87
87
2017-9-9
16 小时
 楼主| 发表于 2017-11-9 10:52:15 | 显示全部楼层
顶一下
485
8万
120314
120314
959 小时
发表于 2017-11-10 01:18:00 | 显示全部楼层
94
177
177
2017-8-2
25 小时
发表于 2017-11-14 16:34:59 | 显示全部楼层
我也遇到这个问题,我看资料里说溢出了就清溢出标志,然后重新初始化ADC和DMA.我这样做了,然后可以运行了。但是后面我加上定时器,本来ADC还在初始化,总是又跳进定时器了。我的定时器就是用来定时读取DMA传出来的ADC的值。
94
177
177
2017-8-2
25 小时
发表于 2017-11-14 16:50:18 | 显示全部楼层
尽管如此,如果数据丢失(溢出),则会将 ADC_SR 寄存器中的 OVR 位置 1 并生成一个中
断(如果 OVRIE 使能位已置 1)。随后会禁止 DMA 传输并且不再接受 DMA 请求。在这种
情况下,如果生成 DMA 请求,则会中止正在进行的规则转换并忽略之后的规则触发。随后
需要将所使用的 DMA 流中的 OVR 标志和 DMAEN 位清零,并重新初始化 DMA 和 ADC,
以将需要的转换通道数据传输到正确的存储器单元。只有这样,才能恢复转换并再次使能数
据传输。注入通道转换不会受到溢出错误的影响。
94
177
177
2017-8-2
25 小时
发表于 2017-11-14 16:53:15 | 显示全部楼层
要在使用 DMA 时将 ADC 从 OVR 状态中恢复,请按以下步骤操作:
1. 重新初始化 DMA(调整目标地址和 NDTR 计数器)
2.  将 ADC_SR 寄存器中的 ADC OVR 位清零
3.  触发 ADC 以开始转换。
94
177
177
2017-8-2
25 小时
发表于 2017-11-15 14:24:35 | 显示全部楼层
另外还要设置  ADC1->CR2|=1<<9;   才正确
位 9   DDS:DMA 禁止选择(对于单一 ADC 模式) (DMA disable selection (for single ADC mode))
此位由软件置 1 和清零。
0:最后一次传输后不发出新的 DMA 请求(在 DMA 控制器中进行配置)
1:只要发生数据转换且 DMA = 1,便会发出 DAM 请求
94
177
177
2017-8-2
25 小时
发表于 2017-11-16 09:54:53 | 显示全部楼层
我后来发现是我的DMA没有开启循环模式,导致ADC溢出,不知道你的是不是
23
87
87
2017-9-9
16 小时
 楼主| 发表于 2017-11-16 22:50:34 | 显示全部楼层
你好,最近没上线,我的DMA开启循环模式了啊,感觉配置的也没什么错,为啥这么容易溢出了呢,溢出后数据就断了,对于我的程序处理来说相当麻烦,数据得从头再开始采样。
50
50
2017-8-23
24 小时
发表于 2017-11-17 11:33:53 | 显示全部楼层
miraclexue 发表于 2017-11-16 22:50
你好,最近没上线,我的DMA开启循环模式了啊,感觉配置的也没什么错,为啥这么容易溢出了呢,溢出后数据 ...
DMA开启双缓冲模式呢?
94
177
177
2017-8-2
25 小时
发表于 2017-11-25 11:16:06 | 显示全部楼层
解决了吗
23
87
87
2017-9-9
16 小时
 楼主| 发表于 2017-12-5 12:14:46 | 显示全部楼层
每次初始化都要加DMA_DeInit(DMAy_Streamx);
94
177
177
2017-8-2
25 小时
发表于 2017-12-7 13:27:04 | 显示全部楼层
我的是开启的DMA中断解决的。ADC循环采集,DMA传输完成就中断处理一次数据
GMT+8, 2018-1-19 09:28
