查看: 2025|回复: 6
stm32Fxx 驱动sht20 温湿度传感器
38
179
474
474
2016-9-28
137 小时
发表于 2017-11-28 22:13:45 | 显示全部楼层 |阅读模式
//系统硬件接口
PH4 -------I2C2_SCL
PH5--------I2C2_SDA
测试结果如下图:(注释:得到温湿度数据被放大100倍,换算成实际值需要乘以0.01)
和硬件相关接口代码:
#define I2C_GPIO_CLK_ENABLE()           __HAL_RCC_GPIOH_CLK_ENABLE()
#define I2C_GPIO_CLK_DISABLE()          __HAL_RCC_GPIOH_CLK_DISABLE()
#define GPIO_PORT_I2C         GPIOH
#define I2C_SCL_PIN                GPIO_PIN_4
#define I2C_SDA_PIN                GPIO_PIN_5
#define I2C_SCL_1()  HAL_GPIO_WritePin( GPIO_PORT_I2C, I2C_SCL_PIN, GPIO_PIN_SET)       /* SCL = 1 */
#define I2C_SCL_0()  HAL_GPIO_WritePin( GPIO_PORT_I2C, I2C_SCL_PIN, GPIO_PIN_RESET)        /* SCL = 0 */
#define I2C_SDA_1()  HAL_GPIO_WritePin( GPIO_PORT_I2C, I2C_SDA_PIN, GPIO_PIN_SET)         /* SDA = 1 */
#define I2C_SDA_0()  HAL_GPIO_WritePin( GPIO_PORT_I2C, I2C_SDA_PIN, GPIO_PIN_RESET)        /* SDA = 0 */
#define I2C_SDA_READ()  ((GPIO_PORT_I2C->IDR & I2C_SDA_PIN) != 0)        /* read SDA status */
#define I2C_SCL_READ()  ((GPIO_PORT_I2C->IDR & I2C_SCL_PIN) != 0)        /* read SCLs tatus */
void  board_i2cInit( void )
    GPIO_InitTypeDef  GPIO_InitStruct;
    /* Enable the GPIO_I2C clock */
    I2C_GPIO_CLK_ENABLE();
    /* Configure the GPIO_I2C pin */
    GPIO_InitStruct.Pin = I2C_SCL_PIN|I2C_SDA_PIN;
    GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_OD;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FAST;
    HAL_GPIO_Init(GPIO_PORT_I2C, &GPIO_InitStruct);
相关文档 Sensirion_Humidity_SHT20_Datasheet_V3_8395437268751607934.pdf (573.72 KB, 下载次数: 184)
38
179
474
474
2016-9-28
137 小时
 楼主| 发表于 2018-2-13 15:19:02 | 显示全部楼层
i2c driver for stm32l073
Desktop.zip
5.4 KB, 下载次数: 119
i2c driver
38
179
474
474
2016-9-28
137 小时
 楼主| 发表于 2018-7-15 19:47:38 | 显示全部楼层
历史帖更新:
38
179
474
474
2016-9-28
137 小时
 楼主| 发表于 2018-7-29 21:06:29 | 显示全部楼层
9万
136746
136746
1396 小时
发表于 2018-7-30 01:08:11 | 显示全部楼层
谢谢分享
38
179
474
474
2016-9-28
137 小时
 楼主| 发表于 2018-7-30 06:03:39 | 显示全部楼层
哥们,你太拼了,晚上1点钟还在回复帖子
38
179
474
474
2016-9-28
137 小时
 楼主| 发表于 2018-9-24 16:35:13 | 显示全部楼层
GMT+8, 2019-1-19 07:57
