查看: 2727|回复: 3
bmp280,请求大神指点
47
426
1232
1232
2017-8-7
161 小时
发表于 2018-1-23 09:15:42 | 显示全部楼层 |阅读模式
10金钱
调了能有一周了,bmp280,用iic通讯,一直调出数据不对,地址什么的都是按照说明来的,0xec,大神指点一下是不是还差哪里没有配置对,附上程序
#define        BMP280_SlaveAddress   0xec          //定义器件在IIC总线中的从地址
#define OSS 0        // Oversampling Setting (note: code is not set up to use other OSS values)
unsigned short dig_T1;
short dig_T2;
short dig_T3;
unsigned short dig_P1;
short dig_P2;
short dig_P3;
short dig_P4;
short dig_P5;
short dig_P6;
short dig_P7;
short dig_P8;
short dig_P9;
void delay()    //略微延时  6us约>4.7us
_nop_();
  _nop_();
   _nop_();
    _nop_();
         _nop_();
          _nop_();
void iic_start()   //启动信号
  SDA=1;
  SCL=1;
  delay();
  SDA=0;
  delay();
  SCL=0;
void iic_stop()  //停止信号
        SDA=0;
        SCL=1;
        delay();
        SDA=1;
        delay();
        SCL=0;
void iic_ack()   //应答信号
        uchar i=0;
        SCL=1;
        delay();
        while((SDA==1)&&(i<255))
        i++;
        SCL=0;
        delay();
void iic_send_byte(uchar bat)  //发送数据
        uchar i,temp;
        temp=bat;
        for(i=0;i<=7;i++)
          temp=temp<<1;
          SCL=0;
          SDA=CY;
          delay();
          SCL=1;
          delay();
        SCL=0;
        delay();
        SDA=1;
        delay();
unsigned char iic_rev()  //接受数据
  uchar temp,i;
  SCL=0;
  delay();
  SDA=1;
  for(i=0;i<=7;i++)
   SCL=1;
   delay();
   temp=(temp<<1)|SDA;
   SCL=0;
   delay();
  delay();
  return temp;
uchar Single_Read(uchar ST_Address)
        uchar REG_data;
        //uchar bit;
        iic_start();         //起始信号
        iic_send_byte(BMP280_SlaveAddress);           //发送设备地址+写信号
        iic_ack();
        iic_send_byte(ST_Address);             //发送存储单元地址
        iic_ack();
        iic_start();                          //起始信号
        iic_send_byte(BMP280_SlaveAddress+1);         //发送设备地址+读信号
        iic_ack();
        REG_data = iic_rev();
        iic_ack();    //最后一个数据需要回NOACK
        return REG_data;
void Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data)
    iic_start();                       //起始信号
    iic_send_byte(SlaveAddress);   //发送设备地址+写信号
        iic_ack();
        iic_send_byte(REG_Address);    //内部寄存器地址
        iic_ack();
        iic_send_byte(REG_data);       //内部寄存器数据
        iic_ack();
        iic_stop();                   //发送停止信号
//读出BMP085内部数据,连续两个
short Multiple_read(uchar ST_Address)
        uchar msb, lsb;
        short _data;
        lsb = Single_Read(ST_Address);
        msb = Single_Read(ST_Address+1);
        _data = msb << 8;
        _data |= lsb;
        //rt_kprintf("data is %x %x\n",msb,lsb);
        return _data;
//读出BMP085内部数据,连续三个
long Multiple_three_read(uchar ST_Address)
        uchar msb, lsb,xlsb;
        long _data = 0;
        msb = Single_Read(ST_Address);
        lsb = Single_Read(ST_Address+1);
        xlsb = Single_Read(ST_Address+2);
        //rt_kprintf("data is %x %x %x\n",msb,lsb,xlsb);
        _data = msb << 16;
        _data |= lsb << 8;
        _data |= xlsb;
        _data = _data >> 4;
        return _data;
//初始化BMP280,根据需要请参考pdf进行修改**************
void Init_BMP280(void)
        unsigned short temp = 0;
        unsigned char write_byte;
        temp = Single_Read(0xd0);//
        dig_T1 = Multiple_read(0x88);
        dig_T2 = Multiple_read(0x8A);
        dig_T3 = Multiple_read(0x8C);
        dig_P1 = Multiple_read(0x8E);
        dig_P2 = Multiple_read(0x90);
        dig_P3 = Multiple_read(0x92);
        dig_P4 = Multiple_read(0x94);
        dig_P5 = Multiple_read(0x96);
        dig_P6 = Multiple_read(0x98);
        dig_P7 = Multiple_read(0x9A);
        dig_P8 = Multiple_read(0x9C);
        dig_P9 = Multiple_read(0x9E);
        write_byte = 0x91;
        Single_Write(BMP280_SlaveAddress,0xf4,write_byte);
        write_byte = 0x00;//配置
        Single_Write(BMP280_SlaveAddress,0xf5,write_byte);//5<<2
        //rt_thread_delay(RT_TICK_PER_SECOND);
        Delay_N1ms(200);
long bmp280Convert(void)
        long adc_T;
        long adc_P;
        long var1, var2,t_fine,T,p;
         //rt_kprintf("----------------------------\n");
        //adc_T = Multiple_three_read(0xFA);
        adc_T = Multiple_three_read(0xFA);    // 读取温度
        //adc_P = Multiple_three_read(0xF7);
        adc_P = Multiple_three_read(0xF7); // 读取压强
        if(adc_P == 0)
                return 0;
        //Temperature
        var1 = (((double)adc_T)/16384.0-((double)dig_T1)/1024.0)*((double)dig_T2);
        //rt_kprintf("var1 is %d\n",var1);
        var2 = ((((double)adc_T)/131072.0-((double)dig_T1)/8192.0)*(((double)adc_T)/131072.0-((double)dig_T1)/8192.0))*((double)dig_T3);
        //rt_kprintf("var2 is %d\n",var2);
        t_fine = (uint32)(var1+var2);
        //rt_kprintf("t_fine is %d\n",t_fine);
        T = (var1+var2)/5120.0;
        T = T;
        //rt_kprintf("temperature is %d\n",T);
        var1 = ((double)t_fine/2.0)-64000.0;
        var2 = var1*var1*((double)dig_P6)/32768.0;
        var2 = var2+var1*((double)dig_P5)*2.0;
        var2 = (var2/4.0)+(((double)dig_P4)*65536.0);
        var1 = (((double)dig_P3)*var1*var1/524288.0+((double)dig_P2)*var1)/524288.0;
        var1 = (1.0+var1/32768.0)*((double)dig_P1);
        p = 1048576.0-(double)adc_P;
        //rt_kprintf("p is %d\n",p);
        p = (p-(var2/4096.0))*6250.0/var1;
        var1 = ((double)dig_P9)*p*p/2147483648.0;
        var2 = p*((double)dig_P8)/32768.0;
        p = p+(var1+var2+((double)dig_P7))/16.0;
        //rt_kprintf("pressure is %d\n",p);
        return p;
int get_pressure(void)
{         int pressure = 0;
        int i = 0;
         SDA=1;
        SCL=1;
        Delay_N1ms(200);                           //上电延时
        Init_BMP280();                //初始化BMP085
        while(i < 3)
                pressure = bmp280Convert();
                i++;
//        printf("pressure is %d\n",pressure);
        Single_Write(BMP280_SlaveAddress,0xf4,0x24);
        return pressure;
问题已解决,iic通信没问题,可以读取出id,读取数据之后处理错误,在把char型转换成long型时移位错误,所以结果也不对了,看着移位的方法是没有错误,但是最好还是调试看一下,张教训了,下面发上我改后的程序,仅供参考,欢迎一起探讨
qq1950361006,互帮互助,共同进步。
47
426
1232
1232
2017-8-7
161 小时
 楼主| 发表于 2018-1-23 09:15:43 | 显示全部楼层
bmp280111.rar
2.85 KB, 下载次数: 231
47
426
1232
1232
2017-8-7
161 小时
 楼主| 发表于 2018-1-24 10:49:52 | 显示全部楼层
扔个程序上来
opt101和温湿度.rar
6.91 MB, 下载次数: 188
50
778
2596
2596
2016-1-8
400 小时
发表于 2018-1-24 13:40:54 | 显示全部楼层
官方都写好了的
GMT+8, 2019-2-16 12:22
