查看: 2021|回复: 14
YMODEM协议串口文件传输
58
193
193
2018-2-1
36 小时
发表于 2018-3-6 21:52:10 | 显示全部楼层 |阅读模式
YMODEM协议串口文件传输
GitHub仓库:https://github.com/XinLiGitHub/SerialPortYmodem
PS:博文不再更新,后续更新会在GitHub仓库进行。
    串口通过YMODEM协议进行文件传输。程序中涉及到YMODEM协议知识,详细介绍见维基百科[YMODEM](https://en.wikipedia.org/wiki/YMODEM)。
1,开发环境
      1,框架:Qt 5.7.1
      2,编译器:MSVC2015_64bit
      3,IDE:Qt Creator 4.2.0 社区版
      4,操作系统:Windows 10 专业版
2,程序源码
      Ymodem.h文件
[C++] 纯文本查看 复制代码
  * @file    Ymodem.h
  * [url=http://www.openedv.com/home.php?mod=space&uid=90321]@Author[/url]  XinLi
  * @version v1.0
  * @date    21-January-2018
  * @brief   Header file for Ymodem.cpp module.
  * @attention
  * <h2><center>Copyright © 2018 XinLi</center></h2>
  * This program is free software: you can redistribute it and/or modify
  * it under the terms of the GNU General Public License as published by
  * the Free Software Foundation, either version 3 of the License, or
  * (at your option) any later version.
  * This program is distributed in the hope that it will be useful,
  * but WITHOUT ANY WARRANTY; without even the implied warranty of
  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  * GNU General Public License for more details.
  * You should have received a copy of the GNU General Public License
  * along with this program.  If not, see <[url=https://www.gnu.org/licenses/]https://www.gnu.org/licenses/>.[/url]
#ifndef __YMODEM_H
#define __YMODEM_H
/* Header includes -----------------------------------------------------------*/
#include <stdint.h>
/* Macro definitions ---------------------------------------------------------*/
#define YMODEM_PACKET_HEADER    (3)
#define YMODEM_PACKET_TRAILER   (2)
#define YMODEM_PACKET_OVERHEAD  (YMODEM_PACKET_HEADER + YMODEM_PACKET_TRAILER)
#define YMODEM_PACKET_SIZE      (128)
#define YMODEM_PACKET_1K_SIZE   (1024)
#define YMODEM_CODE_CAN_NUMBER  (5)
/* Type definitions ----------------------------------------------------------*/
class Ymodem
public:
  enum Code
    CodeNone = 0x00,
    CodeSoh  = 0x01,
    CodeStx  = 0x02,
    CodeEot  = 0x04,
    CodeAck  = 0x06,
    CodeNak  = 0x15,
    CodeCan  = 0x18,
    CodeC    = 0x43,
    CodeA1   = 0x41,
    CodeA2   = 0x61
  enum Stage
    StageNone,
    StageEstablishing,
    StageEstablished,
    StageTransmitting,
    StageFinishing,
    StageFinished
  enum Status
    StatusEstablish,
    StatusTransmit,
    StatusFinish,
    StatusAbort,
    StatusTimeout,
    StatusError
  Ymodem(uint32_t timeDivide = 499, uint32_t timeMax = 5, uint32_t errorMax = 999);
  void setTimeDivide(uint32_t timeDivide);
  uint32_t getTimeDivide();
  void setTimeMax(uint32_t timeMax);
  uint32_t getTimeMax();
  void setErrorMax(uint32_t errorMax);
  uint32_t getErrorMax();
  void receive();
  void transmit();
  void abort();
private:
  Code receivePacket();
  void receiveStageNone();
  void receiveStageEstablishing();
  void receiveStageEstablished();
  void receiveStageTransmitting();
  void receiveStageFinishing();
  void receiveStageFinished();
  void transmitStageNone();
  void transmitStageEstablishing();
  void transmitStageEstablished();
  void transmitStageTransmitting();
  void transmitStageFinishing();
  void transmitStageFinished();
  uint16_t crc16(uint8_t *buff, uint32_t len);
  virtual Code callback(Status status, uint8_t *buff, uint32_t *len) = 0;
  virtual uint32_t read(uint8_t *buff, uint32_t len)  = 0;
  virtual uint32_t write(uint8_t *buff, uint32_t len) = 0;
  uint32_t timeDivide;
  uint32_t timeMax;
  uint32_t errorMax;
  uint32_t timeCount;
  uint32_t errorCount;
  uint8_t  dataCount;
  Code  code;
  Stage stage;
  uint8_t  rxBuffer[YMODEM_PACKET_1K_SIZE + YMODEM_PACKET_OVERHEAD];
  uint8_t  txBuffer[YMODEM_PACKET_1K_SIZE + YMODEM_PACKET_OVERHEAD];
  uint32_t rxLength;
  uint32_t txLength;
/* Variable declarations -----------------------------------------------------*/
/* Variable definitions ------------------------------------------------------*/
/* Function declarations -----------------------------------------------------*/
/* Function definitions ------------------------------------------------------*/
#endif /* __YMODEM_H */
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 21:53:18 | 显示全部楼层
      Ymodem.cpp文件
[C++] 纯文本查看 复制代码
  * @file    Ymodem.cpp
  * [url=home.php?mod=space&uid=90321]@Author[/url]  XinLi
  * @version v1.0
  * @brief   Ymodem protocol module source file.
  * @attention
#include "Ymodem.h"
#include <string.h>
  * @brief  Ymodem constructor.
  * @param  [in] timeDivide: The fractional factor of the time the ymodem is called.
  * @param  [in] timeMax:    The maximum time when calling the ymodem.
  * @param  [in] errorMax:   The maximum error count when calling the ymodem.
  * @note   The longest waiting time = call time / (@timeDivide + 1) * (@timeMax + 1).
  * @return None.
Ymodem::Ymodem(uint32_t timeDivide, uint32_t timeMax, uint32_t errorMax)
  this->timeDivide = timeDivide;
  this->timeMax    = timeMax;
  this->errorMax   = errorMax;
  this->timeCount  = 0;
  this->errorCount = 0;
  this->dataCount  = 0;
  this->code       = CodeNone;
  this->stage      = StageNone;
  * @brief  Set the fractional factor of the time the ymodem is called.
  * @return None.
void Ymodem::setTimeDivide(uint32_t timeDivide)
  * @brief  Get the fractional factor of the time the ymodem is called.
  * @param  None.
  * @return The fractional factor of the time the ymodem is called.
uint32_t Ymodem::getTimeDivide()
  return timeDivide;
  * @brief  Set the maximum time when calling the ymodem.
  * @return None.
void Ymodem::setTimeMax(uint32_t timeMax)
  * @brief  Get the maximum time when calling the ymodem.
  * @param  None.
  * @return The maximum time when calling the ymodem.
uint32_t Ymodem::getTimeMax()
  return timeMax;
  * @brief  Set the maximum error count when calling the ymodem.
  * @return None.
void Ymodem::setErrorMax(uint32_t errorMax)
  * @brief  Get the maximum error count when calling the ymodem.
  * @param  None.
  * @return The maximum error count when calling the ymodem.
uint32_t Ymodem::getErrorMax()
  return errorMax;
  * @brief  Ymodem receive.
  * @param  None.
  * @return None.
void Ymodem::receive()
  switch(stage)
    case StageNone:
      receiveStageNone();
      break;
    case StageEstablishing:
      break;
    case StageEstablished:
      break;
    case StageTransmitting:
      break;
    case StageFinishing:
      break;
    default:
  * @brief  Ymodem transmit.
  * @param  None.
  * @return None.
void Ymodem::transmit()
  switch(stage)
    case StageNone:
      break;
      break;
      break;
      break;
      break;
    default:
  * @brief  Ymodem abort.
  * @param  None.
  * @return None.
void Ymodem::abort()
  timeCount  = 0;
  errorCount = 0;
  dataCount  = 0;
  code       = CodeNone;
  stage      = StageNone;
  for(txLength = 0; txLength < YMODEM_CODE_CAN_NUMBER; txLength++)
    txBuffer[txLength] = CodeCan;
  write(txBuffer, txLength);
  * @brief  Receives a packet of data.
  * @param  None.
  * @return Packet type.
Ymodem::Code Ymodem::receivePacket()
  if(code == CodeNone)
    if(read(&(rxBuffer[0]), 1) > 0)
      if(rxBuffer[0] == CodeSoh)
        uint32_t len = read(&(rxBuffer[1]), YMODEM_PACKET_SIZE + YMODEM_PACKET_OVERHEAD - 1);
        if(len < (YMODEM_PACKET_SIZE + YMODEM_PACKET_OVERHEAD - 1))
          rxLength = len + 1;
          code     = CodeSoh;
          return CodeNone;
          return CodeSoh;
      else if(rxBuffer[0] == CodeStx)
        uint32_t len = read(&(rxBuffer[1]), YMODEM_PACKET_1K_SIZE + YMODEM_PACKET_OVERHEAD - 1);
        if(len < (YMODEM_PACKET_1K_SIZE + YMODEM_PACKET_OVERHEAD - 1))
          rxLength = len + 1;
          code     = CodeStx;
          return CodeNone;
          return CodeStx;
        return (Code)(rxBuffer[0]);
      return CodeNone;
    if(code == CodeSoh)
      uint32_t len = read(&(rxBuffer[rxLength]), YMODEM_PACKET_SIZE + YMODEM_PACKET_OVERHEAD - rxLength);
      if(len < (YMODEM_PACKET_SIZE + YMODEM_PACKET_OVERHEAD - rxLength))
        rxLength += len;
        return CodeNone;
        code = CodeNone;
        return CodeSoh;
    else if(code == CodeStx)
      uint32_t len = read(&(rxBuffer[rxLength]), YMODEM_PACKET_1K_SIZE + YMODEM_PACKET_OVERHEAD - rxLength);
      if(len < (YMODEM_PACKET_1K_SIZE + YMODEM_PACKET_OVERHEAD - rxLength))
        rxLength += len;
        return CodeNone;
        code = CodeNone;
        return CodeStx;
      code = CodeNone;
      return CodeNone;
  * @brief  Receive none stage.
  * @param  None.
  * @return None.
void Ymodem::receiveStageNone()
  timeCount   = 0;
  errorCount  = 0;
  dataCount   = 0;
  code        = CodeNone;
  stage       = StageEstablishing;
  txBuffer[0] = CodeC;
  txLength    = 1;
  * @brief  Receive establishing stage.
  * @param  None.
  * @return None.
void Ymodem::receiveStageEstablishing()
  switch(receivePacket())
    case CodeSoh:
      uint16_t crc = ((uint16_t)(rxBuffer[YMODEM_PACKET_SIZE + YMODEM_PACKET_OVERHEAD - 2]) << 8) |
                     ((uint16_t)(rxBuffer[YMODEM_PACKET_SIZE + YMODEM_PACKET_OVERHEAD - 1]) << 0);
      if((rxBuffer[1] == 0x00) && (rxBuffer[2] == 0xFF) &&
         (crc == crc16(&(rxBuffer[YMODEM_PACKET_HEADER]), YMODEM_PACKET_SIZE)))
        uint32_t dataLength = YMODEM_PACKET_SIZE;
        if(callback(StatusEstablish, &(rxBuffer[YMODEM_PACKET_HEADER]), &dataLength) == CodeAck)
          timeCount   = 0;
          errorCount  = 0;
          dataCount   = 0;
          code        = CodeNone;
          stage       = StageEstablished;
          txBuffer[0] = CodeAck;
          txBuffer[1] = CodeC;
          txLength    = 2;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
        errorCount++;
        if(errorCount > errorMax)
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
          callback(StatusError, NULL, NULL);
          txLength    = 1;
      break;
    case CodeA1:
    case CodeA2:
    case CodeCan:
      timeCount  = 0;
      errorCount = 0;
      dataCount  = 0;
      code       = CodeNone;
      stage      = StageNone;
      callback(StatusAbort, NULL, NULL);
      break;
    default:
      timeCount++;
      if((timeCount / (timeDivide + 1)) > timeMax)
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
        callback(StatusTimeout, NULL, NULL);
      else if((timeCount % (timeDivide + 1)) == 0)
        txLength    = 1;
  * @brief  Receive established stage.
  * @param  None.
  * @return None.
void Ymodem::receiveStageEstablished()
    case CodeSoh:
        errorCount++;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
          txLength    = 2;
      else if((rxBuffer[1] == 0x01) && (rxBuffer[2] == 0xFE) &&
        if(callback(StatusTransmit, &(rxBuffer[YMODEM_PACKET_HEADER]), &dataLength) == CodeAck)
          timeCount   = 0;
          errorCount  = 0;
          dataCount   = 1;
          code        = CodeNone;
          stage       = StageTransmitting;
          txLength    = 1;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
        errorCount++;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
          txBuffer[0] = CodeNak;
          txLength    = 1;
      break;
    case CodeStx:
      uint16_t crc = ((uint16_t)(rxBuffer[YMODEM_PACKET_1K_SIZE + YMODEM_PACKET_OVERHEAD - 2]) << 8) |
                     ((uint16_t)(rxBuffer[YMODEM_PACKET_1K_SIZE + YMODEM_PACKET_OVERHEAD - 1]) << 0);
         (crc == crc16(&(rxBuffer[YMODEM_PACKET_HEADER]), YMODEM_PACKET_1K_SIZE)))
        uint32_t dataLength = YMODEM_PACKET_1K_SIZE;
          timeCount   = 0;
          errorCount  = 0;
          dataCount   = 1;
          code        = CodeNone;
          txLength    = 1;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
        errorCount++;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
          txLength    = 1;
      break;
    case CodeEot:
      timeCount   = 0;
      errorCount  = 0;
      dataCount   = 0;
      code        = CodeNone;
      stage       = StageFinishing;
      txLength    = 1;
      break;
    case CodeA1:
    case CodeA2:
    case CodeCan:
      timeCount  = 0;
      errorCount = 0;
      dataCount  = 0;
      code       = CodeNone;
      stage      = StageNone;
      break;
    default:
      timeCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
        txLength    = 1;
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 21:54:05 | 显示全部楼层
[C++] 纯文本查看 复制代码
  * @brief  Receive transmitting stage.
  * @param  None.
  * @return None.
void Ymodem::receiveStageTransmitting()
    case CodeSoh:
      if((rxBuffer[1] == (uint8_t)(dataCount)) && (rxBuffer[2] == (uint8_t)(0xFF - dataCount)) &&
        errorCount++;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
          txLength    = 1;
      else if((rxBuffer[1] == (uint8_t)(dataCount + 1)) && (rxBuffer[2] == (uint8_t)(0xFE - dataCount)) &&
          timeCount   = 0;
          errorCount  = 0;
          dataCount   = dataCount + 1;
          code        = CodeNone;
          txLength    = 1;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
        errorCount++;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
          txLength    = 1;
      break;
    case CodeStx:
        errorCount++;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
          txLength    = 1;
          timeCount   = 0;
          errorCount  = 0;
          code        = CodeNone;
          txLength    = 1;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
        errorCount++;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
          txLength    = 1;
      break;
    case CodeEot:
      timeCount   = 0;
      errorCount  = 0;
      dataCount   = 0;
      code        = CodeNone;
      txLength    = 1;
      break;
    case CodeA1:
    case CodeA2:
    case CodeCan:
      timeCount  = 0;
      errorCount = 0;
      dataCount  = 0;
      code       = CodeNone;
      stage      = StageNone;
      break;
    default:
      timeCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
        txLength    = 1;
  * @brief  Receive finishing stage.
  * @param  None.
  * @return None.
void Ymodem::receiveStageFinishing()
    case CodeEot:
      timeCount   = 0;
      errorCount  = 0;
      dataCount   = 0;
      code        = CodeNone;
      stage       = StageFinished;
      txLength    = 2;
      break;
    case CodeA1:
    case CodeA2:
    case CodeCan:
      timeCount  = 0;
      errorCount = 0;
      dataCount  = 0;
      code       = CodeNone;
      stage      = StageNone;
      break;
    default:
      timeCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
        txLength    = 1;
  * @brief  Receive finished stage.
  * @param  None.
  * @return None.
void Ymodem::receiveStageFinished()
    case CodeSoh:
        timeCount   = 0;
        errorCount  = 0;
        dataCount   = 0;
        code        = CodeNone;
        stage       = StageNone;
        txLength    = 1;
        callback(StatusFinish, NULL, NULL);
        errorCount++;
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
          txLength    = 1;
      break;
    case CodeEot:
      errorCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
        txLength    = 2;
      break;
    case CodeA1:
    case CodeA2:
    case CodeCan:
      timeCount  = 0;
      errorCount = 0;
      dataCount  = 0;
      code       = CodeNone;
      stage      = StageNone;
      break;
    default:
      timeCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
        txLength    = 1;
  * @brief  Transmit none stage.
  * @param  None.
  * @return None.
void Ymodem::transmitStageNone()
  timeCount   = 0;
  errorCount  = 0;
  dataCount   = 0;
  code        = CodeNone;
  * @brief  Transmit establishing stage.
  * @param  None.
  * @return None.
void Ymodem::transmitStageEstablishing()
    case CodeC:
      memset(&(txBuffer[YMODEM_PACKET_HEADER]), NULL, YMODEM_PACKET_SIZE);
      if(callback(StatusEstablish, &(txBuffer[YMODEM_PACKET_HEADER]), &(txLength)) == CodeAck)
        uint16_t crc = crc16(&(txBuffer[YMODEM_PACKET_HEADER]), txLength);
        timeCount                                       = 0;
        errorCount                                      = 0;
        dataCount                                       = 0;
        code                                            = CodeNone;
        txBuffer[0]                                     = CodeSoh;
        txBuffer[1]                                     = 0x00;
        txBuffer[2]                                     = 0xFF;
        txBuffer[txLength + YMODEM_PACKET_OVERHEAD - 2] = (uint8_t)(crc >> 8);
        txBuffer[txLength + YMODEM_PACKET_OVERHEAD - 1] = (uint8_t)(crc >> 0);
        txLength                                        = txLength + YMODEM_PACKET_OVERHEAD;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
      break;
    case CodeA1:
    case CodeA2:
    case CodeCan:
      timeCount  = 0;
      errorCount = 0;
      dataCount  = 0;
      code       = CodeNone;
      stage      = StageNone;
      break;
    default:
      timeCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
  * @brief  Transmit established stage.
  * @param  None.
  * @return None.
void Ymodem::transmitStageEstablished()
    case CodeNak:
      errorCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
      break;
    case CodeC:
      errorCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = dataCount;
        code       = CodeNone;
        stage      = (Stage)(stage + dataCount);
      break;
    case CodeAck:
      memset(&(txBuffer[YMODEM_PACKET_HEADER]), NULL, YMODEM_PACKET_1K_SIZE);
      switch(callback(StatusTransmit, &(txBuffer[YMODEM_PACKET_HEADER]), &(txLength)))
        case CodeAck:
          timeCount                                       = 0;
          errorCount                                      = 0;
          dataCount                                       = 1;
          code                                            = CodeNone;
          txBuffer[0]                                     = txLength > YMODEM_PACKET_SIZE ? CodeStx : CodeSoh;
          txBuffer[1]                                     = 0x01;
          txBuffer[2]                                     = 0xFE;
          break;
        case CodeEot:
          timeCount   = 0;
          errorCount  = 0;
          dataCount   = 2;
          code        = CodeNone;
          txBuffer[0] = CodeEot;
          txLength    = 1;
          break;
        default:
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
      break;
    case CodeA1:
    case CodeA2:
    case CodeCan:
      timeCount  = 0;
      errorCount = 0;
      dataCount  = 0;
      code       = CodeNone;
      stage      = StageNone;
      break;
    default:
      timeCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 21:55:01 | 显示全部楼层
[C++] 纯文本查看 复制代码
  * @brief  Transmit transmitting stage.
  * @param  None.
  * @return None.
void Ymodem::transmitStageTransmitting()
    case CodeNak:
      errorCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
      break;
    case CodeAck:
        case CodeAck:
          timeCount                                       = 0;
          errorCount                                      = 0;
          code                                            = CodeNone;
          txBuffer[1]                                     = dataCount;
          txBuffer[2]                                     = 0xFF - dataCount;
          break;
        case CodeEot:
          timeCount   = 0;
          errorCount  = 0;
          dataCount   = 0;
          code        = CodeNone;
          txLength    = 1;
          break;
        default:
          timeCount  = 0;
          errorCount = 0;
          dataCount  = 0;
          code       = CodeNone;
          stage      = StageNone;
      break;
    case CodeA1:
    case CodeA2:
    case CodeCan:
      timeCount  = 0;
      errorCount = 0;
      dataCount  = 0;
      code       = CodeNone;
      stage      = StageNone;
      break;
    default:
      timeCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
  * @brief  Transmit finishing stage.
  * @param  None.
  * @return None.
void Ymodem::transmitStageFinishing()
    case CodeNak:
      timeCount   = 0;
      errorCount  = 0;
      dataCount   = 0;
      code        = CodeNone;
      txLength    = 1;
      break;
    case CodeC:
      uint16_t crc = crc16(&(txBuffer[YMODEM_PACKET_HEADER]), YMODEM_PACKET_SIZE);
      timeCount                                                 = 0;
      errorCount                                                = 0;
      dataCount                                                 = 0;
      code                                                      = CodeNone;
      txBuffer[1]                                               = 0x00;
      txBuffer[2]                                               = 0xFF;
      txBuffer[YMODEM_PACKET_SIZE + YMODEM_PACKET_OVERHEAD - 2] = (uint8_t)(crc >> 8);
      txBuffer[YMODEM_PACKET_SIZE + YMODEM_PACKET_OVERHEAD - 1] = (uint8_t)(crc >> 0);
      txLength                                                  = YMODEM_PACKET_SIZE + YMODEM_PACKET_OVERHEAD;
      break;
    case CodeA1:
    case CodeA2:
    case CodeCan:
      timeCount  = 0;
      errorCount = 0;
      dataCount  = 0;
      code       = CodeNone;
      stage      = StageNone;
      break;
    default:
      timeCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
  * @brief  Transmit finished stage.
  * @param  None.
  * @return None.
void Ymodem::transmitStageFinished()
    case CodeC:
    case CodeNak:
      errorCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
      break;
    case CodeAck:
      timeCount  = 0;
      errorCount = 0;
      dataCount  = 0;
      code       = CodeNone;
      stage      = StageNone;
      break;
    case CodeA1:
    case CodeA2:
    case CodeCan:
      timeCount  = 0;
      errorCount = 0;
      dataCount  = 0;
      code       = CodeNone;
      stage      = StageNone;
      break;
    default:
      timeCount++;
        timeCount  = 0;
        errorCount = 0;
        dataCount  = 0;
        code       = CodeNone;
        stage      = StageNone;
  * @brief  Calculate CRC16 checksum.
  * @param  [in] buff: The data to be calculated.
  * @param  [in] len:  The length of the data to be calculated.
  * @return Calculated CRC16 checksum.
uint16_t Ymodem::crc16(uint8_t *buff, uint32_t len)
  uint16_t crc = 0;
  while(len--)
    crc ^= (uint16_t)(*(buff++)) << 8;
    for(int i = 0; i < 8; i++)
      if(crc & 0x8000)
        crc = (crc << 1) ^ 0x1021;
        crc = crc << 1;
  return crc;
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 21:55:48 | 显示全部楼层
      YmodemFileReceive.h文件
[C++] 纯文本查看 复制代码
#ifndef YMODEMFILERECEIVE_H
#define YMODEMFILERECEIVE_H
#include <QFile>
#include <QTimer>
#include <QObject>
#include <QSerialPort>
#include "Ymodem.h"
class YmodemFileReceive : public QObject, public Ymodem
    Q_OBJECT
public:
    explicit YmodemFileReceive(QObject *parent = 0);
    ~YmodemFileReceive();
    void setFilePath(const QString &path);
    void setPortName(const QString &name);
    void setPortBaudRate(qint32 baudrate);
    bool startReceive();
    void stopReceive();
    int getReceiveProgress();
    Status getReceiveStatus();
signals:
    void receiveProgress(int progress);
    void receiveStatus(YmodemFileReceive::Status status);
private slots:
    void readTimeOut();
    void writeTimeOut();
private:
    Code callback(Status status, uint8_t *buff, uint32_t *len);
    uint32_t read(uint8_t *buff, uint32_t len);
    uint32_t write(uint8_t *buff, uint32_t len);
    QFile       *file;
    QTimer      *readTimer;
    QTimer      *writeTimer;
    QSerialPort *serialPort;
    int      progress;
    Status   status;
    QString  filePath;
    QString  fileName;
    uint64_t fileSize;
    uint64_t fileCount;
#endif // YMODEMFILERECEIVE_H
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 21:56:23 | 显示全部楼层
      YmodemFileReceive.cpp文件
[C++] 纯文本查看 复制代码
#include "YmodemFileReceive.h"
#define READ_TIME_OUT   (10)
#define WRITE_TIME_OUT  (100)
YmodemFileReceive::YmodemFileReceive(QObject *parent) :
    QObject(parent),
    file(new QFile),
    readTimer(new QTimer),
    writeTimer(new QTimer),
    serialPort(new QSerialPort)
    setTimeDivide(499);
    setTimeMax(5);
    setErrorMax(999);
    serialPort->setPortName("COM1");
    serialPort->setBaudRate(115200);
    serialPort->setDataBits(QSerialPort::Data8);
    serialPort->setStopBits(QSerialPort::OneStop);
    serialPort->setParity(QSerialPort::NoParity);
    serialPort->setFlowControl(QSerialPort::NoFlowControl);
    connect(readTimer, SIGNAL(timeout()), this, SLOT(readTimeOut()));
    connect(writeTimer, SIGNAL(timeout()), this, SLOT(writeTimeOut()));
YmodemFileReceive::~YmodemFileReceive()
    delete file;
    delete readTimer;
    delete writeTimer;
    delete serialPort;
void YmodemFileReceive::setFilePath(const QString &path)
    filePath = path + "/";
void YmodemFileReceive::setPortName(const QString &name)
    serialPort->setPortName(name);
void YmodemFileReceive::setPortBaudRate(qint32 baudrate)
    serialPort->setBaudRate(baudrate);
bool YmodemFileReceive::startReceive()
    progress = 0;
    status   = StatusEstablish;
    if(serialPort->open(QSerialPort::ReadWrite) == true)
        readTimer->start(READ_TIME_OUT);
        return true;
        return false;
void YmodemFileReceive::stopReceive()
    file->close();
    abort();
    status = StatusAbort;
    writeTimer->start(WRITE_TIME_OUT);
int YmodemFileReceive::getReceiveProgress()
    return progress;
Ymodem::Status YmodemFileReceive::getReceiveStatus()
    return status;
void YmodemFileReceive::readTimeOut()
    readTimer->stop();
    receive();
    if((status == StatusEstablish) || (status == StatusTransmit))
void YmodemFileReceive::writeTimeOut()
    writeTimer->stop();
    serialPort->close();
    receiveStatus(status);
Ymodem::Code YmodemFileReceive::callback(Status status, uint8_t *buff, uint32_t *len)
    switch(status)
        case StatusEstablish:
            if(buff[0] != 0)
                int  i         =  0;
                char name[128] = {0};
                char size[128] = {0};
                for(int j = 0; buff[i] != 0; i++, j++)
                    name[j] = buff[i];
                i++;
                    size[j] = buff[i];
                fileName  = QString::fromLocal8Bit(name);
                fileSize  = QString(size).toULongLong();
                fileCount = 0;
                file->setFileName(filePath + fileName);
                if(file->open(QFile::WriteOnly) == true)
                    YmodemFileReceive::status = StatusEstablish;
                    receiveStatus(StatusEstablish);
                    return CodeAck;
                    YmodemFileReceive::status = StatusError;
                    return CodeCan;
                return CodeCan;
        case StatusTransmit:
            if((fileSize - fileCount) > *len)
                file->write((char *)buff, *len);
                fileCount += *len;
                file->write((char *)buff, fileSize - fileCount);
                fileCount += fileSize - fileCount;
            progress = (int)(fileCount * 100 / fileSize);
            YmodemFileReceive::status = StatusTransmit;
            receiveProgress(progress);
            receiveStatus(StatusTransmit);
            return CodeAck;
        case StatusFinish:
            file->close();
            YmodemFileReceive::status = StatusFinish;
            return CodeAck;
        case StatusAbort:
            file->close();
            YmodemFileReceive::status = StatusAbort;
            return CodeCan;
        case StatusTimeout:
            YmodemFileReceive::status = StatusTimeout;
            return CodeCan;
        default:
            file->close();
            return CodeCan;
uint32_t YmodemFileReceive::read(uint8_t *buff, uint32_t len)
    return serialPort->read((char *)buff, len);
uint32_t YmodemFileReceive::write(uint8_t *buff, uint32_t len)
    return serialPort->write((char *)buff, len);
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 21:57:08 | 显示全部楼层
      YmodemFileTransmit.h文件
[C++] 纯文本查看 复制代码
#ifndef YMODEMFILETRANSMIT_H
#define YMODEMFILETRANSMIT_H
#include <QFile>
#include <QTimer>
#include <QObject>
#include "Ymodem.h"
class YmodemFileTransmit : public QObject, public Ymodem
    Q_OBJECT
public:
    explicit YmodemFileTransmit(QObject *parent = 0);
    ~YmodemFileTransmit();
    void setFileName(const QString &name);
    bool startTransmit();
    void stopTransmit();
    int getTransmitProgress();
    Status getTransmitStatus();
signals:
    void transmitProgress(int progress);
    void transmitStatus(YmodemFileTransmit::Status status);
private slots:
    void readTimeOut();
private:
    QFile       *file;
    QTimer      *readTimer;
    QTimer      *writeTimer;
    int      progress;
    Status   status;
    uint64_t fileSize;
    uint64_t fileCount;
#endif // YMODEMFILETRANSMIT_H
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 21:57:47 | 显示全部楼层
      YmodemFileTransmit.cpp文件
[C++] 纯文本查看 复制代码
#include "YmodemFileTransmit.h"
#include <QFileInfo>
YmodemFileTransmit::YmodemFileTransmit(QObject *parent) :
    QObject(parent),
    file(new QFile),
    setTimeDivide(499);
    setTimeMax(5);
    setErrorMax(999);
YmodemFileTransmit::~YmodemFileTransmit()
    delete file;
    delete readTimer;
    delete writeTimer;
    delete serialPort;
void YmodemFileTransmit::setFileName(const QString &name)
    file->setFileName(name);
void YmodemFileTransmit::setPortName(const QString &name)
void YmodemFileTransmit::setPortBaudRate(qint32 baudrate)
bool YmodemFileTransmit::startTransmit()
    progress = 0;
        return true;
        return false;
void YmodemFileTransmit::stopTransmit()
    file->close();
    abort();
int YmodemFileTransmit::getTransmitProgress()
    return progress;
Ymodem::Status YmodemFileTransmit::getTransmitStatus()
    return status;
void YmodemFileTransmit::readTimeOut()
    readTimer->stop();
    transmit();
void YmodemFileTransmit::writeTimeOut()
    writeTimer->stop();
    transmitStatus(status);
Ymodem::Code YmodemFileTransmit::callback(Status status, uint8_t *buff, uint32_t *len)
    switch(status)
            if(file->open(QFile::ReadOnly) == true)
                QFileInfo fileInfo(*file);
                fileSize  = fileInfo.size();
                fileCount = 0;
                strcpy((char *)buff, fileInfo.fileName().toLocal8Bit().data());
                strcpy((char *)buff + fileInfo.fileName().toLocal8Bit().size() + 1, QByteArray::number(fileInfo.size()).data());
                *len = YMODEM_PACKET_SIZE;
                YmodemFileTransmit::status = StatusEstablish;
                transmitStatus(StatusEstablish);
                return CodeAck;
                YmodemFileTransmit::status = StatusError;
                return CodeCan;
            if(fileSize != fileCount)
                if((fileSize - fileCount) > YMODEM_PACKET_SIZE)
                    fileCount += file->read((char *)buff, YMODEM_PACKET_1K_SIZE);
                    *len = YMODEM_PACKET_1K_SIZE;
                    fileCount += file->read((char *)buff, YMODEM_PACKET_SIZE);
                YmodemFileTransmit::status = StatusTransmit;
                transmitProgress(progress);
                transmitStatus(StatusTransmit);
                return CodeAck;
                return CodeEot;
        case StatusFinish:
            file->close();
            YmodemFileTransmit::status = StatusFinish;
            return CodeAck;
        case StatusAbort:
            file->close();
            YmodemFileTransmit::status = StatusAbort;
            return CodeCan;
        case StatusTimeout:
            YmodemFileTransmit::status = StatusTimeout;
            return CodeCan;
        default:
            file->close();
            return CodeCan;
uint32_t YmodemFileTransmit::read(uint8_t *buff, uint32_t len)
uint32_t YmodemFileTransmit::write(uint8_t *buff, uint32_t len)
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 21:58:36 | 显示全部楼层
      widget.ui文件
[XML] 纯文本查看 复制代码
<?xml version="1.0" encoding="UTF-8"?>
<ui version="4.0">
 <class>Widget</class>
 <widget class="QWidget" name="Widget">
  <property name="geometry">
   <rect>
    <x>0</x>
    <y>0</y>
    <width>444</width>
    <height>255</height>
   </rect>
  </property>
  <property name="minimumSize">
   <size>
    <width>444</width>
   </size>
  </property>
  <property name="maximumSize">
   <size>
    <width>444</width>
   </size>
  </property>
  <property name="windowTitle">
   <string>SerialPortYmodem</string>
  </property>
  <layout class="QVBoxLayout" name="verticalLayout_3">
   <item>
    <widget class="QGroupBox" name="groupBox">
     <property name="title">
      <string>串口配置</string>
     </property>
     <layout class="QHBoxLayout" name="horizontalLayout">
      <item>
       <widget class="QLabel" name="label">
        <property name="text">
         <string>端口:</string>
        </property>
       </widget>
      </item>
      <item>
       <widget class="QComboBox" name="comPort">
        <property name="maxVisibleItems">
         <number>12</number>
        </property>
       </widget>
      </item>
      <item>
       <spacer name="horizontalSpacer">
        <property name="orientation">
         <enum>Qt::Horizontal</enum>
        </property>
        <property name="sizeHint" stdset="0">
         <size>
          <width>40</width>
          <height>20</height>
         </size>
        </property>
       </spacer>
      </item>
      <item>
       <widget class="QLabel" name="label_2">
         <string>波特率:</string>
        </property>
       </widget>
      </item>
      <item>
       <widget class="QComboBox" name="comBaudRate">
        <property name="currentText">
         <string>115200</string>
        </property>
        <property name="currentIndex">
         <number>3</number>
        </property>
         <number>12</number>
        </property>
        <item>
          <string>921600</string>
         </property>
        </item>
        <item>
          <string>460800</string>
         </property>
        </item>
        <item>
          <string>230400</string>
         </property>
        </item>
        <item>
         </property>
        </item>
        <item>
          <string>57600</string>
         </property>
        </item>
        <item>
          <string>38400</string>
         </property>
        </item>
        <item>
          <string>19200</string>
         </property>
        </item>
        <item>
          <string>9600</string>
         </property>
        </item>
        <item>
          <string>4800</string>
         </property>
        </item>
        <item>
          <string>2400</string>
         </property>
        </item>
        <item>
          <string>1200</string>
         </property>
        </item>
       </widget>
      </item>
      <item>
       <spacer name="horizontalSpacer_2">
        </property>
         <size>
          <width>40</width>
          <height>20</height>
         </size>
        </property>
       </spacer>
      </item>
      <item>
       <widget class="QPushButton" name="comButton">
         <string>打开</string>
        </property>
       </widget>
      </item>
     </layout>
    </widget>
   </item>
   <item>
    <widget class="QGroupBox" name="groupBox_2">
      <string>文件发送</string>
     </property>
     <layout class="QVBoxLayout" name="verticalLayout">
      <item>
       <layout class="QHBoxLayout" name="horizontalLayout_2">
        <item>
         <widget class="QLabel" name="label_3">
           <string>文件路径:</string>
          </property>
         </widget>
        </item>
        <item>
         <widget class="QLineEdit" name="transmitPath">
          <property name="readOnly">
           <bool>true</bool>
          </property>
         </widget>
        </item>
        <item>
         <widget class="QPushButton" name="transmitBrowse">
          <property name="enabled">
           <bool>false</bool>
          </property>
           <string>浏览...</string>
          </property>
         </widget>
        </item>
        <item>
         <widget class="QPushButton" name="transmitButton">
           <bool>false</bool>
          </property>
           <string>发送</string>
          </property>
         </widget>
        </item>
       </layout>
      </item>
      <item>
       <layout class="QHBoxLayout" name="horizontalLayout_3">
        <item>
         <widget class="QLabel" name="label_5">
           <string>传输进度:</string>
          </property>
         </widget>
        </item>
        <item>
         <widget class="QProgressBar" name="transmitProgress">
          <property name="value">
           <number>0</number>
          </property>
         </widget>
        </item>
       </layout>
      </item>
     </layout>
    </widget>
   </item>
   <item>
    <widget class="QGroupBox" name="groupBox_3">
      <string>文件接收</string>
     </property>
     <layout class="QVBoxLayout" name="verticalLayout_2">
      <item>
       <layout class="QHBoxLayout" name="horizontalLayout_4">
        <item>
         <widget class="QLabel" name="label_4">
          </property>
         </widget>
        </item>
        <item>
         <widget class="QLineEdit" name="receivePath">
           <bool>true</bool>
          </property>
         </widget>
        </item>
        <item>
         <widget class="QPushButton" name="receiveBrowse">
           <bool>false</bool>
          </property>
          </property>
         </widget>
        </item>
        <item>
         <widget class="QPushButton" name="receiveButton">
           <bool>false</bool>
          </property>
           <string>接收</string>
          </property>
         </widget>
        </item>
       </layout>
      </item>
      <item>
       <layout class="QHBoxLayout" name="horizontalLayout_5">
        <item>
         <widget class="QLabel" name="label_6">
          </property>
         </widget>
        </item>
        <item>
         <widget class="QProgressBar" name="receiveProgress">
           <number>0</number>
          </property>
         </widget>
        </item>
       </layout>
      </item>
     </layout>
    </widget>
   </item>
  </layout>
 </widget>
 <layoutdefault spacing="6" margin="11"/>
 <resources/>
 <connections/>
</ui>
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 21:59:13 | 显示全部楼层
      widget.h文件
[C++] 纯文本查看 复制代码
#ifndef WIDGET_H
#define WIDGET_H
#include <QWidget>
namespace Ui {
class Widget;
class Widget : public QWidget
    Q_OBJECT
public:
    explicit Widget(QWidget *parent = 0);
    ~Widget();
private slots:
    void on_comButton_clicked();
    void on_transmitBrowse_clicked();
    void on_receiveBrowse_clicked();
    void on_transmitButton_clicked();
    void on_receiveButton_clicked();
private:
    Ui::Widget *ui;
    YmodemFileTransmit *ymodemFileTransmit;
    YmodemFileReceive *ymodemFileReceive;
    bool transmitButtonStatus;
    bool receiveButtonStatus;
#endif // WIDGET_H
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 21:59:58 | 显示全部楼层
      widget.cpp文件
[C++] 纯文本查看 复制代码
#include "widget.h"
#include "ui_widget.h"
#include <QMessageBox>
#include <QFileDialog>
#include <QSerialPortInfo>
Widget::Widget(QWidget *parent) :
    QWidget(parent),
    ui(new Ui::Widget),
    serialPort(new QSerialPort),
    ymodemFileTransmit(new YmodemFileTransmit),
    ymodemFileReceive(new YmodemFileReceive)
    transmitButtonStatus = false;
    receiveButtonStatus  = false;
    ui->setupUi(this);
    QSerialPortInfo serialPortInfo;
    foreach(serialPortInfo, QSerialPortInfo::availablePorts())
        ui->comPort->addItem(serialPortInfo.portName());
    connect(ymodemFileTransmit, SIGNAL(transmitProgress(int)), this, SLOT(transmitProgress(int)));
    connect(ymodemFileReceive, SIGNAL(receiveProgress(int)), this, SLOT(receiveProgress(int)));
    connect(ymodemFileTransmit, SIGNAL(transmitStatus(YmodemFileTransmit::Status)), this, SLOT(transmitStatus(YmodemFileTransmit::Status)));
    connect(ymodemFileReceive, SIGNAL(receiveStatus(YmodemFileReceive::Status)), this, SLOT(receiveStatus(YmodemFileReceive::Status)));
Widget::~Widget()
    delete ui;
    delete serialPort;
    delete ymodemFileTransmit;
    delete ymodemFileReceive;
void Widget::on_comButton_clicked()
    static bool button_status = false;
    if(button_status == false)
        serialPort->setPortName(ui->comPort->currentText());
        serialPort->setBaudRate(ui->comBaudRate->currentText().toInt());
            button_status = true;
            ui->comPort->setDisabled(true);
            ui->comBaudRate->setDisabled(true);
            ui->comButton->setText(u8"关闭串口");
            ui->transmitBrowse->setEnabled(true);
            ui->receiveBrowse->setEnabled(true);
            if(ui->transmitPath->text().isEmpty() != true)
                ui->transmitButton->setEnabled(true);
            if(ui->receivePath->text().isEmpty() != true)
                ui->receiveButton->setEnabled(true);
            QMessageBox::warning(this, u8"串口打开失败", u8"请检查串口是否已被占用!", u8"关闭");
        ui->comPort->setEnabled(true);
        ui->comBaudRate->setEnabled(true);
        ui->comButton->setText(u8"打开串口");
        ui->transmitBrowse->setDisabled(true);
        ui->transmitButton->setDisabled(true);
        ui->receiveBrowse->setDisabled(true);
        ui->receiveButton->setDisabled(true);
void Widget::on_transmitBrowse_clicked()
    ui->transmitPath->setText(QFileDialog::getOpenFileName(this, u8"打开文件", ".", u8"任意文件 (*.*)"));
void Widget::on_receiveBrowse_clicked()
    ui->receivePath->setText(QFileDialog::getExistingDirectory(this, u8"选择目录", ".", QFileDialog::ShowDirsOnly));
void Widget::on_transmitButton_clicked()
    if(transmitButtonStatus == false)
        ymodemFileTransmit->setFileName(ui->transmitPath->text());
        ymodemFileTransmit->setPortName(ui->comPort->currentText());
        ymodemFileTransmit->setPortBaudRate(ui->comBaudRate->currentText().toInt());
        if(ymodemFileTransmit->startTransmit() == true)
            transmitButtonStatus = true;
            ui->comButton->setDisabled(true);
            ui->transmitButton->setText(u8"取消");
            ui->transmitProgress->setValue(0);
            QMessageBox::warning(this, u8"失败", u8"文件发送失败!", u8"关闭");
        ymodemFileTransmit->stopTransmit();
void Widget::on_receiveButton_clicked()
    if(receiveButtonStatus == false)
        ymodemFileReceive->setFilePath(ui->receivePath->text());
        ymodemFileReceive->setPortName(ui->comPort->currentText());
        ymodemFileReceive->setPortBaudRate(ui->comBaudRate->currentText().toInt());
        if(ymodemFileReceive->startReceive() == true)
            receiveButtonStatus = true;
            ui->receiveButton->setText(u8"取消");
            ui->receiveProgress->setValue(0);
            QMessageBox::warning(this, u8"失败", u8"文件接收失败!", u8"关闭");
        ymodemFileReceive->stopReceive();
void Widget::transmitProgress(int progress)
    ui->transmitProgress->setValue(progress);
void Widget::receiveProgress(int progress)
    ui->receiveProgress->setValue(progress);
void Widget::transmitStatus(Ymodem::Status status)
    switch(status)
        case YmodemFileTransmit::StatusEstablish:
            break;
        case YmodemFileTransmit::StatusTransmit:
            break;
        case YmodemFileTransmit::StatusFinish:
            ui->comButton->setEnabled(true);
            ui->transmitButton->setText(u8"发送");
            QMessageBox::warning(this, u8"成功", u8"文件发送成功!", u8"关闭");
            break;
        case YmodemFileTransmit::StatusAbort:
            break;
        case YmodemFileTransmit::StatusTimeout:
            break;
        default:
void Widget::receiveStatus(YmodemFileReceive::Status status)
    switch(status)
        case YmodemFileReceive::StatusEstablish:
            break;
        case YmodemFileReceive::StatusTransmit:
            break;
        case YmodemFileReceive::StatusFinish:
            ui->receiveButton->setText(u8"接收");
            QMessageBox::warning(this, u8"成功", u8"文件接收成功!", u8"关闭");
            break;
        case YmodemFileReceive::StatusAbort:
            break;
        case YmodemFileReceive::StatusTimeout:
            break;
        default:
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 22:00:31 | 显示全部楼层
      main.cpp文件
[C++] 纯文本查看 复制代码
#include "widget.h"
#include <QApplication>
int main(int argc, char *argv[])
    QApplication a(argc, argv);
    Widget w;
    w.show();
    return a.exec();
      SerialPortYmodem.pro文件
[C++] 纯文本查看 复制代码
# Project created by QtCreator 2018-01-20T23:00:46
QT       += core gui
QT       += serialport
greaterThan(QT_MAJOR_VERSION, 4): QT += widgets
TARGET = SerialPortYmodem
TEMPLATE = app
# The following define makes your compiler emit warnings if you use
# any feature of Qt which as been marked as deprecated (the exact warnings
# depend on your compiler). Please consult the documentation of the
# deprecated API in order to know how to port your code away from it.
DEFINES += QT_DEPRECATED_WARNINGS
# You can also make your code fail to compile if you use deprecated APIs.
# In order to do so, uncomment the following line.
# You can also select to disable deprecated APIs only up to a certain version of Qt.
#DEFINES += QT_DISABLE_DEPRECATED_BEFORE=0x060000    # disables all the APIs deprecated before Qt 6.0.0
SOURCES += main.cpp\
        widget.cpp \
    YmodemFileReceive.cpp \
    Ymodem.cpp \
HEADERS  += widget.h \
    Ymodem.h \
    YmodemFileReceive.h \
FORMS    += widget.ui
RC_ICONS = SerialPortYmodem.ico
      SerialPortYmodem.ico文件
3,运行效果
58
193
193
2018-2-1
36 小时
 楼主| 发表于 2018-3-6 22:04:00 | 显示全部楼层
可以用来做用户程序升级的上位机软件。
859
859
2017-8-13
73 小时
发表于 2018-3-10 12:01:13 | 显示全部楼层
顶一下。
105
518
1304
1304
2012-10-23
80 小时
发表于 2018-5-30 10:02:33 | 显示全部楼层
放一个编译好的exe
GMT+8, 2019-1-22 10:40
