查看: 459|回复: 4
有人做过pruse sensor 开源心率传感器的开发吗?
49
49
2018-3-5
发表于 2018-4-17 13:25:30 | 显示全部楼层 |阅读模式
这段代码测量  用了什么原理去检测心率的?
void TIM3_IRQHandler(void)
        uint16_t runningTotal=0;
        uint8_t i;
        uint16_t Num;
        if(TIM_GetITStatus(TIM3,TIM_IT_Update)!=RESET)
                Signal = ADC_GetConversionValue(ADC1)/4;     // read the Pulse Senso
                sampleCounter += 2;                          // keep track of the time in mS with this variable
                Num = sampleCounter - lastBeatTime;          // monitor the time since the last beat to avoid noise
                //  find the peak and trough of the pulse wave
                if(Signal < thresh && Num > (IBI/5)*3)                         // avoid dichrotic noise by waiting 3/5 of last IBI
                        if (Signal < T)                                       // T is the trough
                                        T = Signal;                           // keep track of lowest point in pulse wave
                if(Signal > thresh && Signal > P)                               // thresh condition helps avoid noise      thresh ìõ¼tóDÖúóú±üÃaÔëòô
                        P = Signal;                                     // P is the peak   P êÇò»¸ö¼a·å
                }                                                 // keep track of highest point in pulse wave  ¸ú×ùÂö2«2¨μÄ×î¸ßμã
                //  NOW IT'S TIME TO LOOK FOR THE HEART BEAT
                // signal surges up in value every time there is a pulse
                if (Num > 250)                                 // avoid high frequency noise
                        if ( (Signal > thresh) && (Pulse == false) && (Num > (IBI/5)*3) )
                                        Pulse = true;                               // set the Pulse flag when we think there is a pulse
                                        IBI = sampleCounter - lastBeatTime;         // measure time between beats in mS
                                        lastBeatTime = sampleCounter;               // keep track of time for next pulse
                                        if(secondBeat)                        // if this is the second beat, if secondBeat == TRUE
                                                secondBeat = false;                  // clear second Beat flag
                                                for(i=0; i<=9; i++)                 // seed the running total to get a realisitic BPM at startup
                                                        rate[i] = IBI;                     //rate[0]-rate[9]
                                        if(firstBeat)                         // if it's the first time we found a beat, if firstBeat == TRUE
                                                firstBeat = false;                   // clear firstBeat flag
                                                secondBeat = true;                   // set the second beat flag
                                                return;                              // IBI value is unreliable so discard it  IBI
                                        // keep a running total of the last 10 IBI values
                                        // runningTotal = 0;                                  // clear the runningTotal variable
                                        for(i=0; i<=8; i++)                    // shift data in the rate array
                                                rate[i] = rate[i+1];                  // and drop the oldest IBI value
                                                runningTotal += rate[i];              // add up the 9 oldest IBI values
                                        rate[9] = IBI;                          // add the latest IBI to the rate array
                                        runningTotal += rate[9];                // add the latest IBI to runningTotal
                                        runningTotal /= 10;                     // average the last 10 IBI values
                                        BPM = 60000/runningTotal;               // how many beats can fit into a minute? that's BPM
                                        QS = true;                              // set Quantified Self flag
                                        // QS FLAG IS NOT CLEARED INSIDE THIS ISR
                if (Signal < thresh && Pulse == true)   // when the values are going down, the beat is over
                        Pulse = false;                         // reset the Pulse flag so we can do it again
                        amp = P - T;                           // get amplitude of the pulse wave
                        thresh = amp/2 + T;                    // set thresh at 50% of the amplitude
                        P = thresh;                            // reset these for next time
                        T = thresh;
                if (Num > 2500)                        // if 2.5 seconds go by without a beat
                        thresh = 512;                          // set thresh default
                        P = 512;                               // set P default
                        T = 512;                               // set T default
                        lastBeatTime = sampleCounter;          // bring the lastBeatTime up to date
                        firstBeat = true;                      // set these to avoid noise
                        secondBeat = false;                    // when we get the heartbeat back
        TIM_ClearITPendingBit(TIM3,TIM_IT_Update);
49
49
2018-3-5
 楼主| 发表于 2018-4-17 14:04:45 | 显示全部楼层
pulsesensor
60
545
545
2017-5-11
72 小时
发表于 2018-4-17 15:48:17 | 显示全部楼层
这个官方手册上面讲的很清楚,怎么计算的也有,官网地址:https://pulsesensor.com/
49
49
2018-3-5
 楼主| 发表于 2018-4-18 09:39:39 | 显示全部楼层
要登陆外网才可以看的吗???????????????
60
545
545
2017-5-11
72 小时
发表于 2018-4-18 16:53:42 | 显示全部楼层
应该是的,我用流量上去很慢,有时候还进不去
必看,必学:"原子哥”力荐上一条 /1 下一条
GMT+8, 2018-9-23 00:43
