查看: 811|回复: 3
RT 1050 链接错误
220
220
2016-1-19
58 小时
发表于 2018-5-14 11:29:47 | 显示全部楼层 |阅读模式
10金钱
跑emwin 后 链接时出现错误:  Error: L6406E  No space in execution regions with .ANY selector matching.....
这个是分散加载文件
[AppleScript] 纯文本查看 复制代码
#define m_interrupts_start             0x60002000
#define m_interrupts_size              0x00000400
#define m_text_start                   0x60002400
#define m_text_size                    0x1F7FDC00
#define m_data_start                   0x20000000
#define m_data_size                    0x00020000 //0x00020000//0x003F0000
/* Sizes */
#if (defined(__stack_size__))
  #define Stack_Size                   __stack_size__
#else
  #define Stack_Size                   0x0400
#endif
#if (defined(__heap_size__))
  #define Heap_Size                    __heap_size__
#else
  #define Heap_Size                    0x08000
#endif
LR_m_text m_text_start m_text_size {   ; load region size_region
  ER_m_text m_text_start m_text_size { ; load address = execution address
    * (InRoot$$Sections)
    .ANY (+RO)
  RW_m_data m_data_start m_data_size-Stack_Size-Heap_Size { ; RW data
    .ANY (+RW +ZI)
    * (NonCacheable.init)
    * (NonCacheable)
  ARM_LIB_HEAP +0 EMPTY Heap_Size {    ; Heap region growing up
  ARM_LIB_STACK m_data_start+m_data_size EMPTY -Stack_Size { ; Stack region growing down
LR_m_interrupts m_interrupts_start m_interrupts_size {
  VECTOR_ROM m_interrupts_start m_interrupts_size { ; load address = execution address
    * (RESET,+FIRST)
初始化好SDRAM,然后修改链接脚本,将一些数据链接到外部的SDRAM!下面是我自己板子上的链接脚本,跑FreeRTOS和emwin的。 #define m_flash_config_start 0x60000000 #define m_flash_config_size 0x00001000 #define m_ivt_start 0x60001000 #define m_ivt_size 0x00001000 #define m_interrupts_start 0x60002000 #define m_interrupts_size ...
78
78
2012-8-16
发表于 2018-5-14 11:29:48 | 显示全部楼层
#define m_text_size                    0x01FFDC00
#define m_ncache_start                 0x81000000
#define m_ncache_size                  0x01000000
#define m_data_start                   0x80000000
#define m_data_size                    0x01000000
#define m_data2_start                  0x20000000
#define m_data2_size                   0x00020000
#define m_data3_start                  0x20200000
#define m_data3_size                   0x00040000
/* Sizes */
#else
#endif
#else
  #define Heap_Size                    0x0400
#endif
LR_m_rom_config m_flash_config_start m_flash_config_size {   ; load region size_region
        RW_m_config_text m_flash_config_start m_flash_config_size { ; load address = execution address
        * (.boot_hdr.conf, +FIRST)
LR_m_rom_ivt m_ivt_start m_ivt_size {   ; load region size_region
        RW_m_ivt_text m_ivt_start m_ivt_size { ; load address = execution address
        * (.boot_hdr.ivt, +FIRST)
        * (.boot_hdr.boot_data)
        * (.boot_hdr.dcd_data)
LR_m_text m_interrupts_start m_text_start+m_text_size-m_interrupts_size {   ; load region size_region
    * (RESET,+FIRST)
    .ANY (+RO)
    .ANY (+RW +ZI)
  ;LCD Cache
  RW_m_ncache m_ncache_start m_ncache_size { ; ncache RW data
    * (NonCacheable)
  ARM_LIB_STACK m_data2_start+m_data2_size EMPTY -Stack_Size { ; Stack region growing down
76
6724
13566
13566
2013-11-13
1678 小时
发表于 2018-5-14 12:47:14 | 显示全部楼层
内存不够或者flash不够,修改你工程的链接脚本
220
220
2016-1-19
58 小时
 楼主| 发表于 2018-5-14 13:58:36 | 显示全部楼层
keil 如何修改呢?
GMT+8, 2019-3-24 19:49
