查看: 1001|回复: 2
USB声卡把16位描述符改成24位出错
51
123
323
323
2018-5-3
115 小时
发表于 2018-7-2 17:33:48 | 显示全部楼层 |阅读模式
/* Configuration 1 */
  0x09,                                 /* bLength */
  0x02,                                 /* bDescriptorType */
  LOBYTE(AUDIO_CONFIG_DESC_SIZE),       /* wTotalLength  109 bytes*/
  HIBYTE(AUDIO_CONFIG_DESC_SIZE),
  0x03,                                 /* bNumInterfaces */
  0x01,                                 /* bConfigurationValue */
  0x00,                                 /* iConfiguration */
  0xC0,                                 /* bmAttributes  BUS Powred*/
  0x32,                                 /* bMaxPower = 100 mA*/
  /* 09 byte*/
  /* USB Speaker Standard interface descriptor */
  0x09,                                     /* bLength */
  0x04,                                     /* bDescriptorType */
  0x00,                                 /* bInterfaceNumber */
  0x00,                                 /* bAlternateSetting */
  0x00,                                 /* bNumEndpoints */
  0x01,                                /* bInterfaceClass */
  0x01,                                   /* bInterfaceSubClass */
  0x00,                               /* bInterfaceProtocol */
  0x00,                                 /* iInterface */
  /* 09 byte*/
  /* USB Speaker Class-specific AC Interface Descriptor */
  0x0a,                                 /* bLength */
  0x24,                              /* bDescriptorType */
  0x01,                                  /* bDescriptorSubtype */
  0x00,          /* 1.00 */             /* bcdADC */
  0x01,
  0x46,                                 /* wTotalLength = 0x27*/
  0x00,
  0x02, //0x02                                /* bInCollection */
  0x02,  //0x02                               /* baInterfaceNr */
        0x01,  //0x01
  /* 0x0a byte*/
  /* USB Speaker Input Terminal Descriptor */
  0x0c,                                 /* bLength */
  0x02,                                 /* bDescriptorSubtype */
  0x01,                                 /* bTerminalID */
  0x01,                                 /* wTerminalType AUDIO_TERMINAL_USB_STREAMING   0x0101 */
  0x01,
  0x00,                                 /* bAssocTerminal */
  0x01,                                 /* bNrChannels */
  0x00,                                 /* wChannelConfig 0x0000  Mono */
  0x00,
  0x00,                                 /* iChannelNames */
  0x00,                                 /* iTerminal */
  /* 12 byte*/
  /* USB Speaker Audio Feature Unit Descriptor */
  0x09,                                 /* bLength */
  0x06,                                  /* bDescriptorSubtype */
  0x02,                                  /* bUnitID */
  0x01,                                 /* bSourceID */
  0x01,                                 /* bControlSize */
  0x0001,                                /* bmaControls(0) */
  0x00,                                 /* bmaControls(1) */
  /* 09 byte*/
  /*USB Speaker Output Terminal Descriptor */
  0x09,                                 /* bLength */
  0x03,                                 /* bDescriptorSubtype */
  0x03,                                 /* bTerminalID */
  0x01,                                 /* wTerminalType  0x0301*/
  0x03,
  0x02,                                 /* bSourceID */
  /* 09 byte*/
        /* USB Microphone Input Terminal Descriptor */
        0x0c,                                 /* bLength */
        0x05,                                  /* bTerminalID */
        0x01,                                 /* wTerminalType : Microphone 0x0201 */
        0x02,
        0x02,                                 /* bNrChannels í¨μàêyÄ¿*/
        0x00,                                 /* wChannelConfig : Mono sets no position bits */
        0x00,
        /* 12 byte*/
        /* USB Microphone Audio Feature Unit Descriptor */
        0x09,                                 /* bLength */
        0x06,                                 /* bUnitID */
        0x05,                                 /* bSourceID */
        0x02,                                 /* bmaControls(0) Mute & Volume */
        0x00,                                 /* ?? bmaControls(1) / iTerminal */
        0x00,
        /* 9 byte*/
        /*USB Microphone Output Terminal Descriptor */
        0x09,                                 /* bLength */
        0x07,                            /* bTerminalID */
        0x01,                                 /* wTerminalType : USB Streaming */
        0x01,
        0x06,                            /* bSourceID */
        /* 09 byte*/
  /* USB Speaker Standard AS Interface Descriptor - Audio Streaming Zero Bandwith */
  /* Interface 1, Alternate Setting 0                                             */
  AUDIO_INTERFACE_DESC_SIZE,  /* bLength */
  0x01,                                 /* bInterfaceNumber */
  0x02,                                  /* bInterfaceSubClass */
  /* 09 byte*/
  /* USB Speaker Standard AS Interface Descriptor - Audio Streaming Operational */
  /* Interface 1, Alternate Setting 1                                           */
  0x01,                                 /* bAlternateSetting */
  0x01,                                 /* bNumEndpoints CCCCCCCCCCC*/
  /* 09 byte*/
  /* USB Speaker Audio Streaming Interface Descriptor */
  AUDIO_STREAMING_INTERFACE_DESC_SIZE,  /* bLength */
  0x01,                                 /* bTerminalLink */
  0x01,                                 /* bDelay */
  0x01,                                 /* wFormatTag AUDIO_FORMAT_PCM  0x0001*/
  0x00,
  /* 07 byte*/
  /* USB Speaker Audio Type III Format Interface Descriptor */
  0x0B,                                 /* bLength */
  0x01,                                 /* bFormatType */
  0x02,                                 /* bNrChannels */
  0x02,                                 /* bSubFrameSize :  2 Bytes per frame (16bits) */
  16,                                   /* bBitResolution (16-bits per sample) */
  0x01,                                 /* bSamFreqType only one frequency supported */
  SAMPLE_FREQ(96000),  /* Audio sampling frequency coded on 3 bytes */
  /* 11 byte*/
  /* Endpoint 1 - Standard Descriptor */
  AUDIO_STANDARD_ENDPOINT_DESC_SIZE,    /* bLength */
  0x05,                                   /* bDescriptorType */
  0x01,                                      /* bEndpointAddress 1 out endpoint*/
  //USB_ENDPOINT_TYPE_ISOCHRONOUS,        /* bmAttributes CCCCCCC*/
        0x01,
  LOBYTE(AUDIO_OUT_PACKET),    /* wMaxPacketSize in Bytes (Freq(Samples)*2(Stereo)*2(HalfWord)) */
  HIBYTE(AUDIO_OUT_PACKET),
        0x01,                                 /* bInterval */
  0x00,                                 /* bRefresh */
  0x00,                                 /* bSynchAddress */
  /* 09 byte*/
  /* Endpoint - Audio Streaming Descriptor*/
  AUDIO_STREAMING_ENDPOINT_DESC_SIZE,   /* bLength */
  0x25,                                 /* bDescriptorType */
  0x01,                                  /* bDescriptor */
  0x00,                                 /* bmAttributes */
  0x00,                                 /* bLockDelayUnits */
  0x00,                                 /* wLockDelay */
  0x00,
  /* 07 byte*/
        /* USB Microphone Standard AS Interface Descriptor - Audio Streaming Zero Bandwith */
  /* Interface 2, Alternate Setting 0                                             */
        0x09,                                /* bLength */
        0x02,                                 /* bInterfaceNumber */
        /* 09 byte*/
  /* USB Microphone Standard AS Interface Descriptor - Audio Streaming Operational */
  /* Interface 2, Alternate Setting 1                                           */
        0x09,                                 /* bLength */
        0x01,                                 /* bNumEndpoints */
        /* 09 byte*/
  /* USB Microphone Audio Streaming Class-Specific Interface Descriptor */
        0x07,                                    /* bLength */
        0x07,                                    /* bTerminalLink : Unit ID of the Output Terminal*/
        0x01,                                    /* bDelay */
        0x02,                                    /* wFormatTag : AUDIO_FORMAT_PCM */
        0x00,
        /* 07 byte*/
  /* USB Microphone Audio Type I Format Interface Descriptor */
        0x0B+12,                              /* bLength */
        0x02,                                 /* bNrChannels í¨μàêyÄ¿ */
        0x03,                                 /* bSubFrameSize : 2 Bytes per audio subframe */
        0x18,                                 /* bBitResolution : 16 bits per sample */
  0x05,                                 /* bSamFreqType only one frequency supported */
  SAMPLE_FREQ(96000),
        SAMPLE_FREQ(48000),
        SAMPLE_FREQ(44100),
        SAMPLE_FREQ(32000),
        SAMPLE_FREQ(16000),/* Audio sampling frequency coded on 3 bytes */
  /* 8 + 3*N byte*/
  /* USB Microphone Streaming Standard Endpoint Descriptor */
        0x09,                                    /* bLength */
        0x81,                                /* bEndpointAddress : IN endpoint 1 */
        0x05,                                 /* bmAttributes ?????? */
        LOBYTE(AUDIO_IN_PACKET),              /* wMaxPacketSize */
        HIBYTE(AUDIO_IN_PACKET),
        0x01,                                 /* bInterval : one packet per frame */
        /* 09 byte*/
        /* USB Microphone Class-specific Isoc. Audio Data Endpoint Descriptor */
        0x07,                                  /* bLength */
        0x01,                                 /* bmAttributes */
        0x00,
        /* 07 byte*/
配置的USB声卡的描述符,把16位的描述符改成24位的,描述符里面配置的是多频的,但是在电脑上面显示是单个的,而且下拉框也无法打开。
51
123
323
323
2018-5-3
115 小时
 楼主| 发表于 2019-3-13 10:46:54 | 显示全部楼层
问题已解决是BUFF大小没设置对
286
310
310
2019-3-26
发表于 2019-3-27 13:01:39 | 显示全部楼层
谢谢分享!
GMT+8, 2019-4-20 22:28
