查看: 1234|回复: 5
求助原子哥,这个还是没懂,不知道哪里错了(gm8142模块)
44
44
2014-8-1
发表于 2014-8-3 22:20:48 | 显示全部楼层 |阅读模式
[C] 纯文本查看 复制代码
#include<stc12c5a.h>
#define BYTE unsigned char
#define WORD unsigned int
#define HIGH	1
#define LOW		0
#define FALSE	0
#define TRUE	1
sbit SCLK=P1^7;
sbit DIN=P1^5;
sbit DOUT=P1^6;
void ClrCS(void)
{P14=0;}
void SetCS(void)
{P14=1;}
void Delay(unsigned int nTime)
	while(--nTime) {;}
 Function:	Delay
 Describe:	Time delay
 Input:		Byte formated time
 Output:	void
 Function:	SPI_Initial
 Describe:	Initialize the SPI interface
 Input:		void
 Output:	void
void SPI_Initial(void)
	SCLK = LOW;
	DIN = LOW;
	DOUT = LOW;
	Delay(5);
 Function:	SPI_Transmit
 Describe:	Send and receive 16-bit data from the SPI interface
 Input:		16-bit data to be send
 Output:	16-bit data of read, user analyse the validity
WORD SPITransmit(WORD wSendData)
	BYTE i;
	WORD wReadData;
	wReadData = 0;
	for(i = 0; i < 16; i++)
		if(wSendData & 0x8000)
			DIN = 1;
			DIN = 0;
		wReadData<<=1;			//Shift first, then fill the bit
		SCLK = HIGH;
		wSendData<<= 1;
		wReadData |= DOUT;		//Receive the 16-bit data
		Delay(5);
		SCLK = LOW;
		Delay(5);		//Can be comment by acture use
	return(wReadData);
unsigned int SendTo814X(unsigned char chigh,unsigned char clow)
	unsigned int cTempHigh,cTempLow;
	unsigned int RevData;
	ClrCS();    //置814x片选有效
	Delay(10);         //延时时间参考814x数据手册的要求
	cTempHigh=SPITransmit(chigh);      //向814X发送高位数据
	cTempLow=SPITransmit(clow);        //向814X发送低位数据
	SetCS();    //置814x片选无效
	RevData=cTempHigh<<8|cTempLow;
	return RevData;      //返回从814x读出的数据
unsigned int Write814xConfig(unsigned char n,unsigned char high,unsigned char low)   //n 表示设置的串口号,high表示给配置寄存器的高位字节(低三位有效),low表示给配置寄存器的低位字节
	unsigned char ch;
	high=high&0x07;
	ch= 0xc0 | (n<< 3);
	high=high|ch;
	RevData=SendTo814X(high,low);   //向指定的串口功能设置寄存器写配置
	Delay(5);
	return RevData;
unsigned int SendToAllCom(unsigned char c,bit Pt)   //c为需要发送的数据,Pt为第九位数据
	unsigned char ch;
	if(Pt)
		ch=0xa1;
		ch=0xa0;
	RevData=SendTo814X(ch,c);
	return RevData;      //向所有串口发送数据并读出接收FIFO数据
void main()
	Write814xConfig(1,0xc0,0xaa);
	//SendToAllCom(0xaa,0);
SX-UART-KB资料.zip
943.04 KB, 下载次数: 297
44
44
2014-8-1
 楼主| 发表于 2014-8-3 22:27:01 | 显示全部楼层
[C] 纯文本查看 复制代码
#define HIGH	1
#define LOW		0
#define FALSE	0
#define TRUE	1
sbit SCLK=P1^7;
sbit DIN=P1^5;
sbit DOUT=P1^6;
void ClrCS(void)
{P14=0;}
void SetCS(void)
{P14=1;}
	while(--nTime) {;}
 Function:	Delay
 Output:	void
 Input:		void
 Output:	void
	SCLK = LOW;
	DIN = LOW;
	DOUT = LOW;
	Delay(5);
	BYTE i;
	WORD wReadData;
	wReadData = 0;
			DIN = 1;
			DIN = 0;
		SCLK = HIGH;
		wSendData<<= 1;
		Delay(5);
		SCLK = LOW;
	return(wReadData);
	SetCS();
	Delay(10);
	ClrCS();
	Delay(10);
		//延时时间参考814x数据手册的要求
	unsigned char ch;
	high=high&0x07;
	ch= 0xc0 | (n<< 3);
	high=high|ch;
	Delay(5);
	return RevData;
	unsigned char ch;
	if(Pt)
		ch=0xa1;
		ch=0xa0;
void main()
44
44
2014-8-1
 楼主| 发表于 2014-8-3 22:27:15 | 显示全部楼层
我改了一下代码
44
44
2014-8-1
 楼主| 发表于 2014-8-3 22:30:32 | 显示全部楼层
而且在debug里面的P1^6 P1^5 P1^4都是没有的,但是用示波器却能看到
512
9万
133851
133851
1287 小时
发表于 2014-8-3 23:56:42 | 显示全部楼层
帮顶。。。。
98
98
2012-10-18
发表于 2017-10-15 19:59:43 | 显示全部楼层
很想请教下这个芯片的问题
报名原子哥新品发布会&粉丝见面会上一条 /1 下一条
GMT+8, 2018-10-23 08:47
