查看: 8870|回复: 17
emWin 小工具 ICONNIEW的使用
49
311
311
2012-8-28
21 小时
发表于 2014-9-16 16:04:08 | 显示全部楼层 |阅读模式
使用这个软件生成的代码
Add ICONVIEW_AddStreamedBitmapItem();  中添加了一个BMP图片的指针,这个图片是用
生成的*.Dta,通过GUIBuilder加载到函数中生成的十六进制码,
但是显示出来的是一个蓝色的图标,并不是实际的加载进去的图标,如下图:
(实际显示出来的)
代码如下:
static U8 _acImage_0[20016] = {
  0x42, 0x4D, 0x08, 0x00, 0x64, 0x00,。。。。。。。。。。。。。
*       Defines
#define ID_WINDOW_0     (GUI_ID_USER + 0x01)
#define ID_ICONVIEW_0   (GUI_ID_USER + 0x02)
#define ID_ICONVIEW_0_IMAGE_0  0x00
*       _aDialogCreate
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] =
    { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 1024, 768, 0, 0, 0 },
    { ICONVIEW_CreateIndirect, "Iconview",ID_ICONVIEW_0, 317, 34, 400, 700, 0, 0x00640064, 0},
*       _GetImageById
static const void * _GetImageById(U32 Id, U32 * pSize)
    switch (Id)
    case ID_ICONVIEW_0_IMAGE_0:
        *pSize = sizeof(_acImage_0);
        return (const void *)_acImage_0;
    return NULL;
*       _cbDialog
static void _cbDialog(WM_MESSAGE * pMsg)
    WM_HWIN hItem;
    const void * pData;
    int NCode,Id;
    U32          FileSize;
    switch (pMsg->MsgId)
    case WM_INIT_DIALOG:     // 初始化空间
        hItem = WM_GetDialogItem(pMsg->hWin, ID_ICONVIEW_0);
        pData = _GetImageById(ID_ICONVIEW_0_IMAGE_0, &FileSize);
        ICONVIEW_SetFont(hItem,&GUI_FontHZ16);
        ICONVIEW_AddStreamedBitmapItem(hItem, pData, "测试");
        break;
    case WM_NOTIFY_PARENT:
        Id    = WM_GetId(pMsg->hWinSrc);
        NCode = pMsg->Data.v;
        switch(Id)
        case ID_ICONVIEW_0: // Notifications sent by 'Iconview'
            switch(NCode)
            case WM_NOTIFICATION_CLICKED:
                break;
            case WM_NOTIFICATION_RELEASED:
                break;
            case WM_NOTIFICATION_MOVED_OUT:
                break;
            case WM_NOTIFICATION_SCROLL_CHANGED:
                break;
            case WM_NOTIFICATION_SEL_CHANGED:
                break;
            break;
        break;
    default:
        WM_DefaultProc(pMsg);
        break;
*       Public code
*       CreateWindow
void ItemSetFramewin(void) {
    WM_HWIN hWin;
    hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbDialog, WM_HBKWIN, 0, 0);
        GUI_Delay(1);
        ReadEvent();
        switch(CurrEvent.event)
        case K_DOWN:
            break;
        case K_UP:
            break;
        case K_nRIGHT:
            break;
        case K_nLEFT:
            break;
        case K_ENTER:
            break;
        case K_RETURN:
            break;
    WM_DeleteWindow(hWin);
不知道怎么使用这个小工具,有大神提供个DEMO吗?不胜感激。
首先用BmpCvt生成c文件; 其次用ICONVIEW_AddBitmapItem 而不是ICONVIEW_AddStreamBitmapItem; 然后函数里面用BmpCvt生成C文件中结构体的地址。 如下:ICONVIEW_AddBitmapItem(hItem, &bmsettingIcon_128, "");
2015-10-9
发表于 2014-9-16 16:04:09 | 显示全部楼层
首先用BmpCvt生成c文件;
497
9万
128098
128098
1130 小时
发表于 2014-9-16 16:35:26 | 显示全部楼层
帮顶。。。。
429
719
719
2012-6-21
57 小时
发表于 2014-9-16 16:59:59 | 显示全部楼层
看看安富莱有一个例程,是不是要转成PNG啊?
呵呵。
275
336
336
2013-12-3
发表于 2014-9-16 17:47:54 | 显示全部楼层
你这是位图流文件? 可以用位图.c 文件来显示就容易了。
不用谢了……
49
311
311
2012-8-28
21 小时
 楼主| 发表于 2014-9-17 15:00:49 | 显示全部楼层
回复【4楼】eling13:
谢谢eling13     你说的确实对,我换成.C的就可以了,但是dta什么的转换的还是不行。
72
265
265
2014-8-12
26 小时
发表于 2015-3-8 18:17:24 | 显示全部楼层
 回复【5楼】 lushp88 :
我的换成了.c还是一样不显示,你用的是显示图片的那种方式吗
36
293
293
2014-4-3
11 小时
发表于 2015-6-12 15:12:14 | 显示全部楼层
这个函数ICONVIEW_EnableStreamAuto,添加后是可以的。
50
159
426
426
2014-8-15
26 小时
发表于 2015-7-25 11:19:54 | 显示全部楼层
请问这个GUIBuilder是哪个版本的?为什么我的没有IConview这个?
初学STM32,很多不懂,但是我相信坚持一定可以成功,向原子哥学习
50
159
426
426
2014-8-15
26 小时
发表于 2015-7-25 12:44:24 | 显示全部楼层
回复【5楼】lushp88:
怎么换成C?他打不开.C的
2014-12-13
发表于 2016-3-31 19:55:51 | 显示全部楼层
张氏拉都 发表于 2015-7-25 12:44
回复【5楼】lushp88:
怎么换成C?他打不开.C的
请问你的问题解决了吗?我用V5.22版本的GUIBilder添加图标也是一片蓝色
50
159
426
426
2014-8-15
26 小时
发表于 2016-4-14 21:53:37 | 显示全部楼层
我最后就没用这个方案了~~
2016-4-19
发表于 2016-4-19 09:57:35 | 显示全部楼层
// Initialization of 'Iconview'
    ICONVIEW_EnableStreamAuto();
    ICONVIEW_AddStreamedBitmapItem(hItem, pData, "");
53
53
2015-10-19
发表于 2017-1-19 12:20:37 | 显示全部楼层
谢谢你的方法,添加了 ICONVIEW_EnableStreamAuto(); 这行代码就行了
166
2231
2231
2014-11-5
326 小时
发表于 2017-2-8 16:18:04 | 显示全部楼层
加了 ICONVIEW_EnableStreamAuto();还是不行呢,vs下怎么使用FramewinDLG.c文件呢?
166
2231
2231
2014-11-5
326 小时
发表于 2017-2-8 16:18:41 | 显示全部楼层
166
2231
2231
2014-11-5
326 小时
发表于 2017-2-8 16:49:49 | 显示全部楼层
翻看emwin5中文手册,知道怎么做了!!
70
161
161
2013-8-15
33 小时
发表于 6 天前 | 显示全部楼层
亲,你的问题解决了吗?
GMT+8, 2018-6-18 21:15
