查看: 4856|回复: 8
STM32F051C8进入睡眠唤醒后不能再次SWD下载程序,要重新按复位按键后才能下载
71
71
2014-11-4
发表于 2014-11-17 11:21:59 | 显示全部楼层 |阅读模式
在做STM32F051C8的睡眠测试时发现一个问题,请大家指点下
问题描述:
单片机可以进入睡眠,也能被外部中断唤醒,唤醒后程序也接着往下运行,但是程序不能下载了,需要再次按一下复位按键才能下载
这是什么原因,要怎么排除?请大家指点
主程序
[C] 纯文本查看 复制代码
#include \"stm32f0xx.h\"
#include \"delay.h\"
#include \"led.h\"
#include \"lpm.h\"
void Delay(uint32_t t)
	while(t--)
int main(void)
  uint8_t i;
  Delay_Init(48);
  LED_Init();
  LED_Open(0);	//启动标志
  //延时10秒
  for(i=0; i<10; i++)
	Delay_ms(1000);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_PWR, ENABLE);
  PWR_BackupAccessCmd(ENABLE);
  RCC_BackupResetCmd(ENABLE);
  RCC_BackupResetCmd(DISABLE);
	LED_Close(0);	//进入模式标志
	Delay_ms(500);
	SleepMode_Measure();
	LED_Init();
		for(i=0; i<4; i++)
			LED_Not(i);
			Delay(0x8FFFF);
睡眠函数程序
[C] 纯文本查看 复制代码
void Ekey_Init(void)
	EXTI_InitTypeDef EXTI_InitStructure;
	NVIC_InitTypeDef   NVIC_InitStructure;
	RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
	/* Enable and set EXTI0 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI2_3_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPriority = 0x00;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  /* Enable SYSCFG clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
  /* Connect EXTI0 Line to PA0 pin */
  SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOB, EXTI_PinSource3);
  /* Configure EXTI0 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line3;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
void SleepMode_Measure(void)
  __IO uint32_t index = 0;
	//开启所有的时钟
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOB | RCC_AHBPeriph_GPIOC, ENABLE);
  //对所有的IO进行设置
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA | RCC_AHBPeriph_GPIOB | RCC_AHBPeriph_GPIOC, DISABLE);
	//使能外部中断使其可以唤醒MCU
  Ekey_Init();
	//进入睡眠模式
  __WFI();
中断程序
[C] 纯文本查看 复制代码
void EXTI2_3_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line3) != RESET)
    EXTI_ClearITPendingBit(EXTI_Line3);
请大家指点,谢谢
我用过STOP模式,唤醒之后,貌似没有这个问题。 即使是进入了STOP模式,也可以用SWD接口下载程序。 请问你的SWD接口,有没有接reset引脚,如果没有,建议接上。 试试看是否就能解决 。
48
129
129
2014-10-4
发表于 2014-11-17 11:22:00 | 显示全部楼层
试试看是否就能解决
57
195
446
446
2013-2-20
嗯,你这个应该是把SW下载口设置设置改了。SW下载口默认是下载口,如果你不小心把他设置成其他模式,那么你就要外加一根RESET共5根线来激活下载口。
创新超越梦想,拼搏创造奇迹....
71
71
2014-11-4
 楼主| 发表于 2014-11-17 11:22:00 | 显示全部楼层
原来如此,我明白了,其实我在开板的时候SWD是有RESET的,但是下载的时候一般都没有接这个线,也没有问题,今天查看了下手册,看到手册中写着  “复位后,这些引脚被配置为SWDAT和SWCLK备用功能,对SWDAT引脚的内部上拉和对SWCLK脚的内部下拉功能是打开的”原来本身就要求复位后才能下载只是奇怪之前没用也行
71
71
2014-11-4
 楼主| 发表于 2014-11-17 11:23:33 | 显示全部楼层
这是什么原因,要怎么排除?请大家指点
492
492
2017-10-5
发表于 2017-10-20 16:20:34 | 显示全部楼层
确实遇到过这种问题。九块邮官网  新百伦正品折扣店
492
492
2017-10-5
发表于 2017-10-25 09:45:37 | 显示全部楼层
感谢感谢分享
492
492
2017-10-5
发表于 2018-7-12 17:23:01 | 显示全部楼层
1393
2516
2516
2018-5-11
465 小时
发表于 2018-7-12 19:38:43 | 显示全部楼层
应该是没有接RESET线的原因
GMT+8, 2019-2-21 20:17
