查看: 4706|回复: 9
LQFP64引脚怎么会变成绿色?
56
56
2015-3-2
发表于 2015-3-22 21:17:01 | 显示全部楼层 |阅读模式
请问stm32的芯片LQFP64的封装一放到PCB里引脚都是绿色,难道是10mil的clearance太大了?
改小点,8mil试试。
9万
136748
136748
1397 小时
发表于 2015-3-22 21:17:02 | 显示全部楼层
改小点,8mil试试。
56
56
2015-3-2
 楼主| 发表于 2015-3-22 21:17:02 | 显示全部楼层
回复【3楼】正点原子:
改成7mil才行,MiniStm32开发板的库里有这个LQFP64的封装吗?
51
6116
10180
10180
2014-4-1
972 小时
发表于 2015-3-22 22:23:13 | 显示全部楼层
clearance,意味着净空间。
42
42
2015-2-27
发表于 2015-3-24 16:22:50 | 显示全部楼层
应该有错误描述,可以看看
56
56
2015-3-2
 楼主| 发表于 2015-3-24 19:09:07 | 显示全部楼层
回复【4楼】cz215592259:
Errors and Warnings - 49 Errors 1 Warning 1 Hint
Error: ad U1-64 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: ad U1-63 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: ad U1-62 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: ad U1-61 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: ad U1-60 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: ad U1-59 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: ad U1-58 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: ad U1-57 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: ad U1-56 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: ad U1-55 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-54 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-48 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-47 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-43 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-42 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-41 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-40 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-39 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-38 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-37 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-36 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-35 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-34 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-33 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-32 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-31 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-30 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-29 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-28 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-27 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-26 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-23 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-22 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-21 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-19 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-18 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-16 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-13 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-12 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-11 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-10 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-9 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-8 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-7 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-6 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-5 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-4 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-3 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-1 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Warning: Rule - Width Width Constraint (Min=12mil) (Max=20mil) (Preferred=12mil) (All)
Preferred routing width is greater than some pad dimensions. Consider adding a new SMD Neckdown Rule.
Hint: no default SMDNeckDown rule exists.
Report Contents
Routing Widths
Routing Via Styles
Electrical Clearances
Fanout Styles
Layer Directions
Drill Pairs
Net Topologies
Net Layers
SMD Neckdown Rules
Unroutable pads
SMD Neckdown Width Warnings
Pad Entry Warnings
Routing Widths Affected Nets
Rule - Width Width Constraint (Min=12mil) (Max=20mil) (Preferred=12mil) (All) 63
Back to top
Routing Via Styles Affected Nets
Rule - RoutingVias Routing Via (MinHoleWidth=15mil) (MaxHoleWidth=15mil) (PreferredHoleWidth=15mil) (MinWidth=25mil) (MaxWidth=25mil) (PreferedWidth=25mil) (All) 63
Back to top
Clearance Rules
Back to top
Fanout Styles Affected Components
Rule - Fanout_Default Fanout Control Rule ( (All) ) 4
Rule - Fanout_Small Fanout Control Rule ( ((CompPinCount < 5)) ) 49
Rule - Fanout_SOIC Fanout Control Rule ( (IsSOIC) ) 1
Rule - Fanout_LCC Fanout Control Rule ( (IsLCC) ) 1
Back to top
Routing Directions
Layer Name
Direction
Top Layer Automatic
Bottom Layer Automatic
Back to top
Drill Layer Pairs
Start Layer
Stop Layer
Top Layer Bottom Layer
Back to top
Net Topologies Affected Nets
Rule - RoutingTopology Routing Topology Rule(Topology=Shortest) (All) 63
Back to top
Net Layers Affected Nets
Rule - RoutingLayers Routing Layers(All) 63
Back to top
SMD Neckdown Rules Affected Pads
Hint: no default SMDNeckDown rule exists. 234
Back to top
Unroutable pads
Error: Pad U1-64 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-63 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-62 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-61 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-60 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-59 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-58 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-57 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-56 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Error: Pad U1-55 Appears to be unroutable. Violation against Rule - Clearance Clearance Constraint (Gap=10mil) (All),(All) Detected.
Back to top
SMD Neckdown Width Warnings Affected Pads
Back to top
Pad Entry Warnings Affected Pads
Preferred routing width is greater than some pad dimensions. Consider adding a new SMD Neckdown Rule.  49
Back to top
9万
136748
136748
1397 小时
发表于 2015-3-24 23:04:57 | 显示全部楼层
回复【6楼】mycmos:
有啊
38
38
2014-7-10
发表于 2015-3-29 08:49:35 | 显示全部楼层
直接按快捷键T+M,搞定! 不过你得保证10mil不会焊开
56
56
2015-3-2
 楼主| 发表于 2015-4-3 19:02:46 | 显示全部楼层
这样DRC还是不行的。
57
146
146
2018-3-11
20 小时
发表于 2018-6-9 16:15:32 | 显示全部楼层
封装图能否分享一下
GMT+8, 2019-1-21 07:04
