查看: 2145|回复: 9
SM5852微压传感器 ,IIC写器件地址时得不到应答是怎么回事呀?
58
58
2014-9-20
发表于 2015-11-10 16:33:30 | 显示全部楼层 |阅读模式
[C] 纯文本查看 复制代码
#include \"SM5852.h\"
unsigned char test1;
//函 数: IICDelay
//功 能: 本文件内的延时程序调用
void IICDelay(volatile unsigned char DelayCount)
    while(DelayCount --)
      ;     //CLEARDOG;
//函 数: I2C_Start
//功 能: IIC驱动程序之起始位
void I2C_Start(void)
	Sensor_SDA_OUT;
	Sensor_SDA = 1;
	Sensor_SCL = 1;
	IICDelay(5);
	Sensor_SDA = 0;
	IICDelay(5);
	Sensor_SCL = 0;
//函 数: I2C_Stop
//功 能: IIC驱动程序之停止位
void I2C_Stop(void)
    Sensor_SDA_OUT;
	Sensor_SCL = 0;
	Sensor_SDA = 0;
	IICDelay(5);
	Sensor_SCL = 1;
	IICDelay(5);
	Sensor_SDA = 1;
	IICDelay(5);
//函 数: I2C_WaitACK
//功 能: IIC驱动程序之等待ACK
void I2C_WaitACK(void)
	unsigned char errtime;
	errtime = 40;
    Sensor_SDA_OUT;
    Sensor_SDA = 1;
    IICDelay(10);	//读ACK
    Sensor_SCL = 1;
	IICDelay(10);
	Sensor_SDA_IN;
	while(Sensor_SDA)
        errtime --;
        if(!errtime)
            I2C_Stop();
            test1 = 4;
            break;
    Sensor_SCL = 0;
    Sensor_SDA_OUT;
    IICDelay(5);
//函 数: I2C_SndAck
//功 能: IIC驱动程序之主机发送应答
void I2C_SndAck(void)
    Sensor_SDA_OUT;
	Sensor_SDA = 0;
	IICDelay(5);
	Sensor_SCL = 1;
	IICDelay(5);
	Sensor_SCL = 0;
//函 数: I2C_SndNoAck
//功 能: IIC驱动程序之主机发送非应答
void I2C_SndNoAck(void)
	Sensor_SDA_OUT;
	Sensor_SDA=1;
	IICDelay(5);
	Sensor_SCL=1;
	IICDelay(5);
	Sensor_SCL=0;
//函 数: I2C_WriteByte
//功 能: IIC写字节
void I2C_WriteByte(unsigned char data)
	unsigned char i;
	Sensor_SDA_OUT;
	for(i = 0; i < 8; i++)//以最高为传输数据
        if(data & 0x80)
            Sensor_SDA = 1;
            Sensor_SDA = 0;
        data <<= 1;
        Sensor_SCL = 1;
        IICDelay(5);
        Sensor_SCL = 0;
	I2C_WaitACK();   //如果通讯错误,将不能接收到ack
//函 数: I2C_ReadByte
//功 能: IIC读字节
unsigned char I2C_ReadByte(void)
	unsigned char i,bytedata;
	Sensor_SDA_IN;
		Sensor_SCL = 1;
        bytedata <<= 1;
        bytedata |= Sensor_SDA;
        Sensor_SCL = 0;
        IICDelay(5);
	Sensor_SDA_OUT;
	return(bytedata);
//函 数: InitSensor
//功 能: 初始化传感器
void InitSensor(void)
	Sensor_SCL_OUT;   //传感器时钟线
	Sensor_SCL = 1;   //传感器时钟线
	Sensor_SDA_OUT;   //传感器数据线
	Sensor_SDA = 1;   //传感器数据线
//函 数: Sensor_ReadOneByte
//功 能: 从片内指定地址读一个字节数据
unsigned char Sensor_ReadOneByte(unsigned char RegAddr)
	unsigned char mdata;
    I2C_Start();
    I2C_WriteByte(ADDRESS_SM5852_WR);
	I2C_WriteByte(RegAddr);
	I2C_Start();
    I2C_WriteByte(ADDRESS_SM5852_RE);
    mdata = I2C_ReadByte();
    I2C_SndNoAck();
    I2C_Stop(); //停止I2C
    IICDelay(100);//此处延时根据实际情况,如果不延时,可能会不正常
    return(mdata);
//函 数: Sensor_ReadMultiByte
//功 能: 从片内指定地址读出多个字节的数据
void Sensor_ReadMultiByte(unsigned char ucStartAddress,volatile unsigned char *datebuffer,unsigned char ucByteCounter)
    I2C_Start();
    I2C_WriteByte(ucStartAddress);
    I2C_Start();
    while(-- ucByteCounter)
        *datebuffer ++= I2C_ReadByte();
        I2C_SndAck();
    *datebuffer = I2C_ReadByte();
    I2C_SndNoAck();
    I2C_Stop();
    IICDelay(200);//此处延时根据实际情况,如果不延时,可能会不正常
1585
2552
2552
2014-7-17
339 小时
发表于 2015-11-10 22:32:39 | 显示全部楼层
帮顶!!!!
9万
138345
138345
1431 小时
发表于 2015-11-10 23:05:02 | 显示全部楼层
慢慢调试...
75
75
2013-6-5
发表于 2016-11-2 10:37:32 | 显示全部楼层
你写的地址是多少?
加油!
45
119
119
2014-7-4
发表于 2016-12-21 16:27:07 | 显示全部楼层
你好    你手里有SM5852的IIC手册吗  要是有我可以帮忙看看的
呵呵
93
93
2017-4-13
12 小时
发表于 2017-6-30 14:56:09 | 显示全部楼层
qujian55 发表于 2016-11-2 10:37
你写的地址是多少?
你好,你的IIC从机地址找到了吗,是多少?求告知
93
93
2017-4-13
12 小时
发表于 2017-6-30 14:58:24 | 显示全部楼层
你好,请问这个传感器挂在IIC上时,地址是多少?
93
93
2017-4-13
12 小时
发表于 2017-7-4 11:30:14 | 显示全部楼层
我把0-255都试了一下,没一个能得到应答的。。。
58
58
2014-9-20
 楼主| 发表于 2017-7-20 14:20:08 | 显示全部楼层
调试OK,是配置的问题
67
172
172
2016-9-1
31 小时
发表于 2018-2-5 10:30:04 | 显示全部楼层
地址95
GMT+8, 2019-3-21 16:14
