查看: 3294|回复: 5
mega169 ADS1100转换问题
2012-6-2
发表于 2012-7-10 00:36:58 | 显示全部楼层 |阅读模式
        ADS1100原理图
以下是我编的程序
//ICC-AVR application builder : 2012-7-7 19:30:59
// Target : M169
// Crystal: 8.0000Mhz
#include <iom169v.h>
#include <macros.h>
#define  uchar unsigned char
#define  uint unsigned  int
#define SCL_OUT    DDRF |= (1<<F6)
#define SCL_OUT_H  ORTF |= (1<<F6)
#define SCL_OUT_L  ORTF &=~ (1<<F6)
#define SDA_OUT    DDRF |= (1<<F7)
#define SDA_OUT_H  ORTF |= (1<<F7)
#define SDA_OUT_L  ORTF &=~ (1<<F7)
#define SDA_IN     DDRF &=~ (1<<PF7)
#define SDA_IN_D   (PINF&0x80)
#define DELAY_NOP asm("NOP\n")
void port_init(void)
 PORTA = 0x00;
 DDRA  = 0x00;
 PORTB = 0x00;
 DDRB  = 0x00;
 PORTC = 0x00;
 DDRC  = 0x00;
 PORTD = 0x00;
 DDRD  = 0x00;
 PORTE = 0x00;
 DDRE  = 0x00;
 PORTF = 0xc0;//
 DDRF  = 0x00;
 PORTG = 0x00;
 DDRG  = 0x00;
void delay_10us(void)
  uchar delay_num;
for(delay_num=0;delay_num<=10;delay_num++){DELAY_NOP;}
void delay250ms(void)
uchar delay_num1,delay_num2;
for(delay_num1=0;delay_num1<=250;delay_num1++)
for(delay_num2=0;delay_num2<=250;delay_num2++) {}  //1ms
void delayms(uint d)      //ms
uint c,e;
for(e=0;e<d;e++)
    for(c=1;c<143*1-2;c++);
///////////////////////////////////////////////////////AD程序
void     ads1100_start(void)
//inital:scl=1,data=1,data =>out
SDA_OUT;
SCL_OUT;
SDA_OUT_L; //=0
delay_10us();
SCL_OUT_L;//insure scl=0
delay_10us();
//finally :scl=0,data=0,data =>out
void     ads1100_stop(void)
SDA_OUT;
SCL_OUT;
SDA_OUT_L;
delay_10us();
delay_10us();
// scl=1 data=0=>data=1
SCL_OUT_H;
delay_10us();
delay_10us();
SDA_OUT_H;
delay_10us();
delay_10us();
uchar    ackby_ads1100(void)
unsigned char times=0;
//start:scl=0 data=>out
//give up bus     setup data in
SDA_IN;
SCL_OUT;
delay_10us(); //wait for ads1100 ready data
//wait ads1100 ack
SCL_OUT_H;
while((SDA_IN_D==1)&&(times<100))           //wait for ads ack   data=0
    times++;
SCL_OUT_L; //ready for next
delay_10us();
//fianlly:scl=0;data <in
if(times>90)
    return 0;
    return 1;
void     ackby_master(void)
//start:scl=0
//get bus
SDA_OUT;
SCL_OUT;
//ready ack data
SDA_OUT_L;
delay_10us();  //ready data
SCL_OUT_H;        //wait for ads1100 receive
delay_10us();
delay_10us();
delay_10us();
//fianlly:scl=0,data >out
void     send_frame(uchar framedata)
unsigned char i;
//initial:scl=0
SDA_OUT;
SCL_OUT;
delay_10us();
delay_10us();
for(i=0;i<8;i++)
     SCL_OUT_L;             //read for next scl=0
     if( ( (framedata << i) & 0x80) ==0 )
         SDA_OUT_L;
         SDA_OUT_H;
    delay_10us();     //稳定数据
    SCL_OUT_H;           //suo shuju
     delay_10us();   //wait for ads1100 receive data
//finally:scl=0,data getbus
uchar    read_frame(void)
uchar data=0,i;
//start:scl=0; data no confire
SDA_IN;
SCL_OUT;
delay_10us();          //wait for ads ready data
for(i=0;i<8;i++)
     SCL_OUT_H;
     data=data<<1;           //bit0=0
     delay_10us();      //等待数据稳定
     if(SDA_IN_D!=0)
         data=data+1;
     SCL_OUT_L;
//fially:scl=0 data <in
return data;
函数功能:写一个命令码到ADS1100
参数说明:addr器件地址,command命令码
          此为ads1100用函数
void     ads1100_write(unsigned char addr,unsigned char command)
//addr=0x90;                          //1001(固定) 000(器件编号) 0(写)
//a start
ads1100_start();
//sent for a frame    addr
send_frame(addr);
ackby_ads1100();
//sent for a frame    command
send_frame(command);
ackby_ads1100();
//a stop
ads1100_stop();
函数功能:读写一次转换数据从ADS1100
参数说明:addr器件地址
          此为ads1100用函数
unsigned int     ads1100_read(unsigned char addr)
uint data;
uchar datah,datal,datac;
//addr=0x91;                          //1001(固定) 000(器件编号) 1(读)
//a start
ads1100_start();
send_frame(addr);
ackby_ads1100();
//read a 8bit data for ads1100 datah
datah=read_frame();
ackby_master();
//read a 8bit data for ads1100 datal
datal=read_frame();
ackby_master();
datac=read_frame();
ackby_master();
//a stop
ads1100_stop();
// UART_TXD0(datac);
data=(((uint)datah)<<8) + datal;
return data;
void init_devices(void)
 //stop errant interrupts until set up
 CLI(); //disable all interrupts
 port_init();
 CLKPR=0x80;
 //CLKPR=0x05;//软件分频1/32
 //CLKPR=0x01;//软件分频1/2
// CLKPR=0x08;//软件分频1/256
 //CLKPR=0x07;//软件分频1/128
 //CLKPR=0x06;//软件分频1/64
 //SMCR=0x05;
 SEI(); //re-enable interrupts
 //all peripherals are now initialized
void main()
   uint data;
   init_devices();
   ads1100_write(0x90,0x8c);//写地址:1001 000 0  固定码1001,地址为000,写命令为0 写配置字:连续转换,转换速率为8SPS,增益为1
    data = 0;
data=ads1100_read(0x91); //写地址:1001 000 1  固定码1001,地址为000,读命令为1
delayms(500);
delayms(500);
        //最后将结果data显示出来,程序此处未写
问题:上面程序下载烧写后,ads1100转换结果总是显示0x0000,即不转换,不知道程序问题出在哪?大家帮我看看是什么原因。谢谢了!
9万
136932
136932
1401 小时
发表于 2012-7-10 09:02:32 | 显示全部楼层
看代码最郁闷了.尤其是有问题的代码.
你先看看你的iic通讯是否正常吧,检查写入的值和读出的值是否一致!如果iic都不正常,读数当然就不正确了.
68
271
271
2011-12-17
发表于 2012-7-10 11:48:05 | 显示全部楼层
楼主先分析自己程序的操作步骤以及时序是不是正确,应该自己找个示波器一点点的测量信号查看!就能找出原因,不然以后操作这样的器件还是没法解决!
与其相濡以沫,不如相望江湖!
2012-6-2
 楼主| 发表于 2012-7-11 17:02:05 | 显示全部楼层
回复【2楼】正点原子:
找到问题了,熔丝位设置的问题。
2012-6-2
 楼主| 发表于 2012-7-11 17:04:58 | 显示全部楼层
回复【3楼】相识在天涯:
恩,程序没问题,熔丝位设置有误,刚开始没在意。
85
85
2012-10-30
发表于 2018-3-7 16:01:04 | 显示全部楼层
能提供一下代码参考一下吗?
GMT+8, 2019-1-24 19:28
