查看: 2899|回复: 6
利用rt-thread已经串口通讯的问题
2016-4-10
发表于 2016-4-26 17:16:59 | 显示全部楼层 |阅读模式
这个程序为什么每次都读写一个字符,但最后能够完成多字符传输
#include <rtthread.h>
struct rx_msg
  rt_device_t dev;
  rt_size_t size;
/* 用于接收消息的消息队列*/
static rt_mq_t rx_mq;
/* 接收线程的接收缓冲区*/
static char uart_rx_buffer[512];
static char uart_sx_buffer[512];
/* 数据到达回调函数*/
rt_err_t uart_input(rt_device_t dev, rt_size_t size)
  struct rx_msg msg;
  msg.dev = dev;
  msg.size = size;
  /* 发送消息到消息队列中*/
  rt_mq_send(rx_mq, &msg, sizeof(struct rx_msg));
  return RT_EOK;
void device_thread_entry(void* parameter)
  struct rx_msg msg;
  int count = 0;
  rt_device_t device, write_device;
  rt_err_t result = RT_EOK;
  /* 查找系统中的串口1设备 */
  device = rt_device_find("uart1");
  if (device!= RT_NULL)
    /* 设置回调函数及打开设备*/
    rt_device_set_rx_indicate(device, uart_input);
    rt_device_open(device, RT_DEVICE_OFLAG_RDWR);
  /* 设置写设备为uart1设备 */
  write_device = device;
  /* 查找系统中的串口2设备 */
  device= rt_device_find("uart2");
  if (device != RT_NULL)
    /* 设置回调函数及打开设备*/
  while (1)
    /* 从消息队列中读取消息*/
    result = rt_mq_recv(rx_mq, &msg,
      sizeof(struct rx_msg), 50);
//    if (result == -RT_ETIMEOUT)
//      /* 接收超时*/
//      rt_kprintf("timeout count:%d\n", ++count);
    /* 成功收到消息*/
    if (result == RT_EOK)
      rt_uint32_t rx_length;
      rx_length = (sizeof(uart_rx_buffer) - 1) >
msg.size ? msg.size : sizeof(uart_rx_buffer) - 1;
      /* 读取消息*/
      rx_length = rt_device_read(msg.dev, 0,
&uart_rx_buffer[0], rx_length);
      uart_rx_buffer[rx_length] = '\0';
      /* 写到写设备中*/
      if (write_device != RT_NULL)
        rt_device_write(write_device, 0,
static struct rt_messagequeue s_your_mq;//消息队列控制块对象
static char s_msg_pool[1024];//消息池
int rt_application_init()
        /* 创建devt线程*/
  rt_thread_t thread = rt_thread_create("devt",
    device_thread_entry, RT_NULL,
    1024, 25, 7);
          rt_mq_init(&s_your_mq,"test",&s_msg_pool[0],sizeof(struct rx_msg),sizeof(s_msg_pool),RT_IPC_FLAG_FIFO);//初始化消息队列控制块
  rx_mq =&s_your_mq;//将rx_mq再指向s_your_mq
  /* 创建成功则启动线程*/
  if (thread != RT_NULL)
    rt_thread_startup(thread);
9万
137334
137334
1413 小时
发表于 2016-5-1 12:18:49 | 显示全部楼层
2016-11-13
发表于 2016-11-13 22:12:49 | 显示全部楼层
&uart_rx_buffer[0], rx_length);  读取的长度是rx_length,并且是以块为单位的
2017-5-5
发表于 2017-5-5 16:08:39 | 显示全部楼层
您好,同时使用两个串口设备的话必须要再建立一个线程吗?
2017-5-5
发表于 2017-5-5 16:10:17 | 显示全部楼层
我用一个串口通信的话可以,但是两个设备一起用的话就有一个不好用了
73
73
2017-10-27
发表于 2017-10-27 16:55:29 | 显示全部楼层
学习,帮顶
50
50
2017-10-26
发表于 2017-12-29 16:49:40 | 显示全部楼层
我现在一个产品上用6个串口,STM32F407,裸奔功能已经实现了,现在在学RT-THREAD,头大啊!
GMT+8, 2019-2-23 06:21
