查看: 2611|回复: 6
求解--移植MPU6050,自检始终失败
36
36
2016-7-30
发表于 2016-8-5 00:10:53 | 显示全部楼层 |阅读模式
移植MPU6050,发现在初始化时自检始终失败
[AppleScript] 纯文本查看 复制代码
res=run_self_test();		//自检
printf("自检--res---%d\r\n",res);
if(res)return 8;
res=mpu_set_dmp_state(1);	//使能DMP
printf("使能DMP--res---%d\r\n",res);
发现在函数 run_self_test检测,需要result=0x03;
uint8_t run_self_test(void)
	int result;
	//char test_packet[4] = {0};
	long gyro[3], accel[3];
	result = mpu_run_self_test(gyro, accel);
	printf("result %d\r\n",result);
	if (result == 0x3)
		/* Test passed. We can trust the gyro data here, so let's push it down
		* to the DMP.
		float sens;
		unsigned short accel_sens;
		mpu_get_gyro_sens(&sens);
		gyro[0] = (long)(gyro[0] * sens);
		gyro[1] = (long)(gyro[1] * sens);
		gyro[2] = (long)(gyro[2] * sens);
		dmp_set_gyro_bias(gyro);
		mpu_get_accel_sens(&accel_sens);
		accel[0] *= accel_sens;
		accel[1] *= accel_sens;
		accel[2] *= accel_sens;
		dmp_set_accel_bias(accel);
		return 0;
	}else return 1;
但是在mpu_run_self_test函数中,根本没有等于result=0x03的值
int mpu_run_self_test(long *gyro, long *accel)
#ifdef MPU6050
    const unsigned char tries = 2;
    long gyro_st[3], accel_st[3];
    unsigned char accel_result, gyro_result;
#ifdef AK89xx_SECONDARY
    unsigned char compass_result;
#endif
    int ii;
#endif
    int result;
    unsigned char accel_fsr, fifo_sensors, sensors_on;
    unsigned short gyro_fsr, sample_rate, lpf;
    unsigned char dmp_was_on;
    if (st.chip_cfg.dmp_on) {
        mpu_set_dmp_state(0);
        dmp_was_on = 1;
    } else
        dmp_was_on = 0;
        printf("dmp_was_on =%d \r\n",dmp_was_on);
    /* Get initial settings. */
    mpu_get_gyro_fsr(&gyro_fsr);
        printf("gyro_fsr = %X \r\n",gyro_fsr);
    mpu_get_accel_fsr(&accel_fsr);
        printf("accel_fsr = %X \r\n",accel_fsr);
    mpu_get_lpf(&lpf);
        printf("lpf = %X \r\n",lpf);
    mpu_get_sample_rate(&sample_rate);
        printf("sample_rate = %X \r\n",sample_rate);
    sensors_on = st.chip_cfg.sensors;
        printf("sensors_on = %X \r\n",sensors_on);
    mpu_get_fifo_config(&fifo_sensors);
        printf("fifo_sensors = %X \r\n",fifo_sensors);
    /* For older chips, the self-test will be different. */
#if defined MPU6050
    for (ii = 0; ii < tries; ii++)
        if (!get_st_biases(gyro, accel, 0))
            break;
    if (ii == tries) {
        /* If we reach this point, we most likely encountered an I2C error.
         * We'll just report an error for all three sensors.
        result = 0;
        goto restore;
        if (!get_st_biases(gyro_st, accel_st, 1))
            break;
    if (ii == tries) {
        /* Again, probably an I2C error. */
        result = 0;
        goto restore;
    accel_result = accel_self_test(accel, accel_st);
    gyro_result = gyro_self_test(gyro, gyro_st);
    result = 0;
    if (!gyro_result)
        result |= 0x01;
    if (!accel_result)
        result |= 0x02;
    compass_result = compass_self_test();
    if (!compass_result)
        result |= 0x04;
#endif
restore:
#elif defined MPU6500
    /* For now, this function will return a "pass" result for all three sensors
     * for compatibility with current test applications.
    get_st_biases(gyro, accel, 0);
    result = 0x7;
#endif
    /* Set to invalid values to ensure no I2C writes are skipped. */
    st.chip_cfg.gyro_fsr = 0xFF;
    st.chip_cfg.accel_fsr = 0xFF;
    st.chip_cfg.lpf = 0xFF;
    st.chip_cfg.sample_rate = 0xFFFF;
    st.chip_cfg.sensors = 0xFF;
    st.chip_cfg.fifo_enable = 0xFF;
    st.chip_cfg.clk_src = INV_CLK_PLL;
    mpu_set_gyro_fsr(gyro_fsr);
    mpu_set_accel_fsr(accel_fsr);
    mpu_set_lpf(lpf);
    mpu_set_sample_rate(sample_rate);
    mpu_set_sensors(sensors_on);
    mpu_configure_fifo(fifo_sensors);
    if (dmp_was_on)
    return result;
原子哥,帮忙看下是否我移植的有问题
508
9万
132665
132665
1239 小时
发表于 2016-8-6 20:17:18 | 显示全部楼层
这个看不出问题。你看是不是模块没放平导致的?
47
180
180
2015-2-28
26 小时
发表于 2016-10-27 10:47:11 | 显示全部楼层
我也是自测没通过,accel_result = accel_self_test(accel, accel_st);    gyro_result = gyro_self_test(gyro, gyro_st);,这两个数都为7;
36
36
2016-7-30
 楼主| 发表于 2017-1-25 11:15:18 | 显示全部楼层
这部分我是直接将自检部分代码给屏蔽掉了
sun008 该用户已被删除
发表于 2017-3-16 13:39:39 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
sun008 该用户已被删除
发表于 2017-3-16 14:25:24 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
43
43
2017-7-4
发表于 2017-11-13 20:07:55 | 显示全部楼层
当然没有result=3的程序,3就是0x11呗,这段程序是吧每个位用来检测一个功能,说明gyro_result出问题了,但是具体什么问题就不清楚了,我也出了这个问题
必看,必学:"原子哥”力荐上一条 /1 下一条
GMT+8, 2018-9-18 23:17
