查看: 6705|回复: 4
命令行输入shutdown命令后,板子没反应了,断电上电也不行(核心板重新拔插后,恢复正常)
90
90
2017-9-10
17 小时
发表于 2019-11-10 23:38:17 | 显示全部楼层 |阅读模式
执行命令如下:
  1. root@ALIENTEK-IMX6U:~# shutdown -h now
  2. INIT: Switching to runlevel: 0
  3. INIT: Sending processes the TERM signal
  4. The system is going down for system halt NOW!tymxc0) (Tue Aug 20 13:29:37 201
  5. root@ALIENTEK-IMX6U:~# Stopping XServer
  6. Stopping Dropbear SSH server: stopped /usr/sbin/dropbear (pid 538)
  7. dropbear.
  8. * Stopping Avahi mDNS/DNS-SD Daemon: avahi-daemon                                     [ ok ]
  9. Stopping advanced power management daemon: no /usr/sbin/apmd found; none killed
  10. apmd.
  11. Stopping atd: OK
  12. Stopping bluetooth
  13. /usr/libexec/bluetooth/bluetoothd
  14. Stopping system message bus: dbus.
  15. stopping mountd: done
  16. stopping nfsd: done
  17. Stopping system log daemon...0
  18. Stopping kernel log daemon...0
  19. stopping statd: done
  20. Stopping Connection Manager
  21. Stopping Telephony daemon
  22. ALSA: Storing mixer settings...
  23. Stopping crond: OK
  24. Stopping rpcbind daemon...
  25. done.
  26. Stopping Linux NFC daemon
  27. Deconfiguring network interfaces... done.
  28. Sending all processes the TERM signal...
  29. logout
  30. [ 7776.117179] RTL871X: indicate disassoc
  31. [ 7776.121071] RTL871X: set bssid:00:00:00:00:00:00
  32. ·1X£Z%]X蟔«2Ά′TtA!=܇򜽔′] fw_state=0x00000008
  33. Xshell[ 7776.182905] RTL871X: set bssid:00:00:00:00:00:00
  34. [ 7776.187636] RTL871X: set ssid [p羡A⻧>~뛫8\*쮻򭻔ꙛ\򜽔′] fw_state=0x00000808
  35. [ 7776.205260] RTL871X: indicate disassoc
  36. [ 7777.469529] RTL871X: indicate disassoc
  37. Sending all processes the KILL signal...
  38. Unmounting remote filesystems...
  39. Deactivating swap...
  40. Unmounting local filesystems...
  41. [ 7781.332480] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
  42. [ 7784.124404] reboot: Power down
到这里重新断电上电就没反应了,核心板上电源灯不亮,总电源灯是亮的。。。断电重新上电后也没有打印信息。
下边说一下自己测试的信息:
1、打开电源开关,有12V电压,5V电压,但是没有3.3V电压(大概只有0.8V);
2、总电源指示灯亮,核心板上的灯不亮,程序运行指示灯也不亮。也就是说,正常有三个灯亮,现在只有一个灯亮;
测试过程中,尝试重新把核心板重新拔掉,然后插上,就又好了,就当记录一下问题吧
问题原因暂时未知,有大神知道的可以告诉我一下,十分感谢!
poweroff关机可以看这个帖子http://www.openedv.com/forum.php?mod=viewthread&tid=302145&extra=
88
7369
14980
14980
2013-11-13
1823 小时
发表于 2019-11-10 23:38:18 | 显示全部楼层
poweroff关机可以看这个帖子http://www.openedv.com/forum.php ... d=302145&extra=
90
90
2017-9-10
17 小时
 楼主| 发表于 2019-11-11 13:39:46 | 显示全部楼层
好的,谢谢,之前没看到这个帖子。不过这样很吓人,一时不知道啥情况。
2020-2-28
发表于 2020-6-8 11:14:34 | 显示全部楼层
这个应该是一个系统的BUG,虽然按照poweroff关机贴管用,但仍是很不方便。直接关电总不太好吧
779
5341
5341
2019-9-25
444 小时
发表于 2020-6-9 09:28:53 | 显示全部楼层
是芯片那么设计的,不是系统的bug,不知道nxp为什么 要这么设计,你可以看看手册6U ONOFF章节
想思考的时候,有时还可以用屁股,QQ 1252699831
GMT+8, 2026-4-23 21:33
