查看: 7567|回复: 3
Imx6ul使用两条SPI DMA同时传输时,传输失败
2020-4-11
发表于 2020-4-11 13:59:37 | 显示全部楼层 |阅读模式
Hi:
问题描述:
Imx6ul单板在使用两条SPI同时传输时,内核打印如下错误:
[09:42:02][ 684.646483] spi_imx 2010000.ecspi: I/O Error in DMA TX
[09:42:02][ 684.654434] spidev spi2.0: SPI transfer failed: -110
[09:42:02][ 684.660489] spi_master spi2: failed to transfer one message from queue
测试指令:
./spidev_test -D /dev/spidev2.0  -s 30000000 -b 32 -S 1000 &
./spidev_test -D /dev/spidev3.0  -s 30000000 -b 32 -S 1000 &
内核版本:4.14.93+;
SPI配置30M时钟,32bit;
DTS配置:
ecspi2: ecspi@0200c000 {
#address-cells = <1>;
#size-cells = <0>;
compatible = "fsl,imx6ul-ecspi", "fsl,imx51-ecspi";
reg = <0x0200c000 0x4000>;
interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX6UL_CLK_ECSPI2>,
<&clks IMX6UL_CLK_ECSPI2>;
clock-names = "ipg", "per";
dmas = <&sdma 5 7 1>, <&sdma 6 7 2>;
dma-names = "rx", "tx";
status = "disabled";
ecspi3: ecspi@02010000 {
#size-cells = <0>;
reg = <0x02010000 0x4000>;
interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clks IMX6UL_CLK_ECSPI3>,
<&clks IMX6UL_CLK_ECSPI3>;
dmas = <&sdma 7 7 1>, <&sdma 8 7 2>;
2020-4-11
 楼主| 发表于 2020-4-11 14:57:19 | 显示全部楼层
单个SPI传输是正常的,两条SPI同时传输就会有问题。大佬们帮忙看看
2020-4-11
 楼主| 发表于 2020-4-13 09:14:57 | 显示全部楼层
顶一下,等大神解答
150
150
2020-8-11
53 小时
发表于 2021-7-26 09:58:47 | 显示全部楼层
楼主你好,请问您单个SPIDMA通信是怎么修改的,我看spi_dev.c和spidev_test.c中并没有DMA相关的代码?楼主可以提供一下这两个文件学习一下吗?
GMT+8, 2026-4-23 20:17
