查看: 5856|回复: 4
GPRS数据发送失败
109
348
348
2016-6-13
65 小时
发表于 2017-5-2 17:00:56 | 显示全部楼层 |阅读模式
20金钱
我用原子哥的代码做GPRS实验 因为用了花生壳 所以把映射的域名直接给出了 就做了这方面的修改 测试时显示连接成功 但按key0后过一段时间显示数据发送失败 为什么呢?
u8 sim900a_gprs_test(void)
        const u8 *port="8086";        //¶Ë¿ú1춨Îa8086,μ±ÄãμÄμçÄÔ8086¶Ë¿ú±»ÆäËû3ìDòÕ¼óÃμÄê±oò,ÇëDT¸ÄÎaÆäËû¿ÕÏD¶Ë¿ú
        const u8 *ipaddr="k169t56564.imwork.net:16833";
        u8 mode=0;                                //0,TCPᬽó;1,UDPᬽó
        //u8 key;
        u8 timex=0;
        //u8 ipbuf[16];                 //IP»o′æ
        //u8 iplen=0;                        //IP3¤¶è
        sim900a_gprs_ui();        //¼óÔØÖ÷½çÃæ
        Show_Str(30+72,90,200,16,(u8*)modetbl[mode],16,0);        //ÏÔê¾á¬½ó·½ê½
        Show_Str(30+40,130,200,16,(u8*)port,16,0);                        //ÏÔê¾¶Ë¿ú
        sim900a_send_cmd("AT+CIPCLOSE=1","CLOSE OK",100);        //1رÕᬽó
        sim900a_send_cmd("AT+CIPSHUT","SHUT OK",100);                //1رÕòƶˉ3¡¾°
        if(sim900a_send_cmd("AT+CGCLASS=\"B\"","OK",1000))return 1;                                //éèÖÃGPRSòƶˉì¨àà±eÎaB,Ö§3Ö°ü½»»»oíêy¾Y½»»»
        if(sim900a_send_cmd("AT+CGDCONT=1,\"IP\",\"CMNET\"","OK",1000))return 2;//éèÖ&#195DPéÏÏÂÎÄ,»¥áaíø½óD-òé,½óèëμãμèDÅÏ¢
        if(sim900a_send_cmd("AT+CGATT=1","OK",500))return 3;                                        //¸½×ÅGPRSòμÎñ
        if(sim900a_send_cmd("AT+CIPCSGP=1,\"CMNET\"","OK",500))return 4;                 //éèÖÃÎaGPRSᬽóÄ£ê½
        if(sim900a_send_cmd("AT+CIPHEAD=1","OK",500))return 5;                                         //éèÖýóêÕêy¾YÏÔê¾IPí·(·½±ãÅD¶Ïêy¾Yà′Ô′)
        if(sim900a_send_cmd("AT+CLPORT=\"TCP\",\"2000\"","OK",500))return 6;
        if(sim900a_send_cmd("AT+CIPSTART=\"TCP\",\"k169t56564.imwork.net:16833 \",\"8080\"","OK",500))return 7;
        sim900a_tcpudp_test(mode,(u8*)ipaddr,(u8*)port);
        Show_Str(30+72,90,200,16,(u8*)modetbl[mode],16,0);         //ÏÔê¾á¬½óÄ£ê½
        //Show_Str(30+40,130,200,16,(u8*)port,16,0);//ÏÔê¾¶Ë¿ú
        USART2_RX_STA=0;
        Show_Str(30+56,110,200,16,(u8*)ipaddr,16,0);                        //ÏÔê¾IPμØÖ·
        /*ipbuf[0]=0;
                key=KEY_Scan(0);
                if(key==WKUP_PRES)
                        mode=!mode;                //ᬽóÄ£ê½ÇD»»
                key=sim900a_get_keynum(0,180);
                if(key)
                        if(key<12)
                                if(iplen<15)
                                        ipbuf[iplen++]=kbd_tbl[key-1][0];
                                        u2_printf("AT+CLDTMF=2,\"%c\"\r\n",kbd_tbl[key-1][0]);
                        }else
                                if(key==13)if(iplen)iplen--;        //é&#190;3y
                                if(key==14&&iplen)                                //&#214;′DDGPRSá&#172;&#189;ó
                                        sim900a_tcpudp_test(mode,ipbuf,(u8*)port);
                                        sim900a_gprs_ui();                        //&#188;ó&#212;&#216;&#214;÷&#189;&#231;&#195;&#230;
                                        Show_Str(30+72,90,200,16,(u8*)modetbl[mode],16,0);         //&#207;&#212;ê&#190;á&#172;&#189;ó&#196;£ê&#189;
                                        Show_Str(30+40,130,200,16,(u8*)port,16,0);//&#207;&#212;ê&#190;&#182;&#203;&#191;ú
                                        USART2_RX_STA=0;
                                if(key==15)break;
                        ipbuf[iplen]=0;
                        LCD_Fill(30+56,110,239,110+16,WHITE);
                        Show_Str(30+56,110,200,16,ipbuf,16,0);                        //&#207;&#212;ê&#190;IPμ&#216;&#214;·
                timex++;
                if(timex==20)
                        timex=0;
                        LED0=!LED0;
                delay_ms(10);
                sim_at_response(1);//&#188;ì2éGSM&#196;£&#191;é·¢&#203;í1yà′μ&#196;êy&#190;Y,&#188;°ê±é&#207;′&#171;&#184;&#248;μ&#231;&#196;&#212;
        return 0;
const u8 *port="8086"; //¶Ë¿ú1춨Îa8086,μ±ÄãμÄμçÄÔ8086¶Ë¿ú±»ÆäËû3ìDòÕ¼óÃμÄê±oò,ÇëDT¸ÄÎaÆäËû¿ÕÏD¶Ë¿ú const u8 *ipaddr="k169t56564.imwork.net:16833"; 16833是端口号
87
87
2014-12-1
12 小时
发表于 2017-5-2 17:00:57 | 显示全部楼层
const u8 *port="8086";        //&#182;&#203;&#191;ú1ì&#182;¨&#206;a8086,μ±&#196;&#227;μ&#196;μ&#231;&#196;&#212;8086&#182;&#203;&#191;ú±&#187;&#198;&#228;&#203;&#251;3ìDò&#213;&#188;ó&#195;μ&#196;ê±oò,&#199;&#235;DT&#184;&#196;&#206;a&#198;&#228;&#203;&#251;&#191;&#213;&#207;D&#182;&#203;&#191;ú
16833是端口号
109
348
348
2016-6-13
65 小时
 楼主| 发表于 2017-5-2 20:13:22 | 显示全部楼层
乐在其中 发表于 2017-5-2 18:12
const u8 *port="8086";        //&#182;&#203;&#191;ú1ì&#182;¨&#206;a8086,μ±&#196;&#227;μ&#196; ...
这样呀 是替代我这的8086吗?
109
348
348
2016-6-13
65 小时
 楼主| 发表于 2017-5-2 20:15:21 | 显示全部楼层
109
348
348
2016-6-13
65 小时
 楼主| 发表于 2017-5-2 20:43:40 | 显示全部楼层
弄通了 非常感谢
GMT+8, 2026-11-23 21:57
