查看: 6992|回复: 1
HAL库I2C这两个函数问题。
60
881
3591
3591
2016-1-8
547 小时
发表于 2017-5-24 09:57:45 | 显示全部楼层 |阅读模式
[mw_shl_code=applescript,true]/**
  * @brief  Transmits in master mode an amount of data in blocking mode.
  * @param  hi2c : Pointer to a I2C_HandleTypeDef structure that contains
  *                the configuration information for the specified I2C.
  * @param  DevAddress: Target device address
  * @param  pData: Pointer to data buffer
  * @param  Size: Amount of data to be sent
  * @param  Timeout: Timeout duration
  * @retval HAL status
HAL_StatusTypeDef HAL_I2C_Master_Transmit(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint8_t *pData, uint16_t Size, uint32_t Timeout)
  uint32_t sizetmp = 0;
  if(hi2c->State == HAL_I2C_STATE_READY)
    if((pData == NULL ) || (Size == 0))
      return  HAL_ERROR;
    if(__HAL_I2C_GET_FLAG(hi2c, I2C_FLAG_BUSY) == SET)
      return HAL_BUSY;
    /* Process Locked */
    __HAL_LOCK(hi2c);
    hi2c->State = HAL_I2C_STATE_MASTER_BUSY_TX;
    hi2c->ErrorCode   = HAL_I2C_ERROR_NONE;
    /* Send Slave Address */
    /* Set NBYTES to write and reload if size > 255 and generate RESTART */
    /* Size > 255, need to set RELOAD bit */
    if(Size > 255)
      I2C_TransferConfig(hi2c,DevAddress,255, I2C_RELOAD_MODE, I2C_GENERATE_START_WRITE);
      sizetmp = 255;
      I2C_TransferConfig(hi2c,DevAddress,Size, I2C_AUTOEND_MODE, I2C_GENERATE_START_WRITE);
      sizetmp = Size;
    do
      /* Wait until TXIS flag is set */
      if(I2C_WaitOnTXISFlagUntilTimeout(hi2c, Timeout) != HAL_OK)
        if(hi2c->ErrorCode == HAL_I2C_ERROR_AF)
          return HAL_ERROR;
          return HAL_TIMEOUT;
      /* Write data to TXDR */
      hi2c->Instance->TXDR = (*pData++);
      sizetmp--;
      Size--;
      if((sizetmp == 0)&&(Size!=0))
        /* Wait until TXE flag is set */
        if(I2C_WaitOnFlagUntilTimeout(hi2c, I2C_FLAG_TCR, RESET, Timeout) != HAL_OK)
          return HAL_TIMEOUT;
        if(Size > 255)
          I2C_TransferConfig(hi2c,DevAddress,255, I2C_RELOAD_MODE, I2C_NO_STARTSTOP);
          sizetmp = 255;
          I2C_TransferConfig(hi2c,DevAddress,Size, I2C_AUTOEND_MODE, I2C_NO_STARTSTOP);
          sizetmp = Size;
    }while(Size > 0);
    /* No need to Check TC flag, with AUTOEND mode the stop is automatically generated */
    /* Wait until STOPF flag is set */
    if(I2C_WaitOnSTOPFlagUntilTimeout(hi2c, Timeout) != HAL_OK)
        return HAL_ERROR;
        return HAL_TIMEOUT;
    /* Clear STOP Flag */
    __HAL_I2C_CLEAR_FLAG(hi2c, I2C_FLAG_STOPF);
    /* Clear Configuration Register 2 */
    __HAL_I2C_RESET_CR2(hi2c);
    hi2c->State = HAL_I2C_STATE_READY;
    /* Process Unlocked */
    __HAL_UNLOCK(hi2c);
    return HAL_OK;
    return HAL_BUSY;
[/mw_shl_code]
  * @brief  Write an amount of data in blocking mode to a specific memory address
  * @param  MemAddress: Internal memory address
  * @param  MemAddSize: Size of internal memory address
HAL_StatusTypeDef HAL_I2C_Mem_Write(I2C_HandleTypeDef *hi2c, uint16_t DevAddress, uint16_t MemAddress, uint16_t MemAddSize, uint8_t *pData, uint16_t Size, uint32_t Timeout)
  uint32_t Sizetmp = 0;
  /* Check the parameters */
  assert_param(IS_I2C_MEMADD_SIZE(MemAddSize));
    if((pData == NULL) || (Size == 0))
      return  HAL_ERROR;
      return HAL_BUSY;
    __HAL_LOCK(hi2c);
    hi2c->State = HAL_I2C_STATE_MEM_BUSY_TX;
    /* Send Slave Address and Memory Address */
    if(I2C_RequestMemoryWrite(hi2c, DevAddress, MemAddress, MemAddSize, Timeout) != HAL_OK)
        __HAL_UNLOCK(hi2c);
        return HAL_ERROR;
        __HAL_UNLOCK(hi2c);
        return HAL_TIMEOUT;
    /* Set NBYTES to write and reload if size > 255 */
    if(Size > 255)
      Sizetmp = 255;
      Sizetmp = Size;
    do
          return HAL_ERROR;
          return HAL_TIMEOUT;
      /* Write data to DR */
      Sizetmp--;
      Size--;
      if((Sizetmp == 0)&&(Size!=0))
        /* Wait until TCR flag is set */
          return HAL_TIMEOUT;
        if(Size > 255)
          Sizetmp = 255;
          Sizetmp = Size;
    }while(Size > 0);
    /* Wait until STOPF flag is reset */
    if(I2C_WaitOnSTOPFlagUntilTimeout(hi2c, I2C_TIMEOUT_STOPF) != HAL_OK)
        return HAL_ERROR;
        return HAL_TIMEOUT;
    __HAL_UNLOCK(hi2c);
    return HAL_OK;
    return HAL_BUSY;
}[/mw_shl_code]
这两个函数给I2C设备写数据,
第一个只需要I2C设备的地址
第二个函数需要I2C设备地址和寄存器地址,这个好理解给固定寄存器写数据
但是第一个函数是什么意思,直接给设备写数据?
同理还有一个读取数据的  直接读取设备数据,没有指定哪个寄存器,可是我需要读取固定寄存器的数据
但实验证明两个函数都可以读取数据或者写数据,有人知道原理吗
结贴晚了,现在才想起来,第一个函数是写到I2C一串数据,第二个函数是写到固定地址数据
60
881
3591
3591
2016-1-8
547 小时
 楼主| 发表于 2017-5-24 09:57:46 | 显示全部楼层
GMT+8, 2026-10-30 23:04
