查看: 8113|回复: 11
F4ZGT6 TIM1 用编码器模式 只有PA8输入方波脉冲 ( 一通道)才能进入中断
238
238
2017-4-17
60 小时
发表于 2017-7-21 14:12:29 | 显示全部楼层 |阅读模式
void TIM1_Mode_Config(void)
                TIM_ICInitTypeDef        TIM1_ICInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1,ENABLE);          //TIM5时钟使能
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);         //使能PORTA时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_11; //GPIOC6/7
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;        //速度100MHz
        //GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出
        //GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN; //下拉
        GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PAC
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource8,GPIO_AF_TIM1); //PC6复用位定时器8
       GPIO_PinAFConfig(GPIOA,GPIO_PinSource11,GPIO_AF_TIM1); //PC7复用位定时器8
        TIM_TimeBaseStructure.TIM_Prescaler=0;  //定时器分频
        TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up; //向上计数模式
        TIM_TimeBaseStructure.TIM_Period=(390)-1;   //自动重装载值
        TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
        TIM_EncoderInterfaceConfig(TIM1, TIM_EncoderMode_TI12,TIM_ICPolarity_Rising,TIM_ICPolarity_Rising);
        TIM_ICStructInit(&TIM1_ICInitStructure);
        TIM1_ICInitStructure.TIM_Channel = TIM_Channel_1;
        TIM1_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI1上
        TIM1_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;         //配置输入分频,不分频
        TIM1_ICInitStructure.TIM_ICFilter = 0x6;
        TIM_ICInit(TIM1, &TIM1_ICInitStructure);
        TIM1_ICInitStructure.TIM_Channel = TIM_Channel_4;
        TIM1_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI2上
        TIM_SetCounter(TIM1,0);
  //TIM_ITConfig(TIM8,TIM_IT_Update|TIM_IT_CC1,ENABLE);//允许更新中断 ,允许CC1IE捕获中断
                TIM_ITConfig(TIM1,TIM_IT_Update,ENABLE);//允许更新中断 ,允许CC1IE捕获中断
                TIM_Cmd(TIM1,ENABLE );         //使能定时器5
                NVIC_EnableIRQ(TIM1_UP_TIM10_IRQn);
                direction1 = (TIM1->CR1 & TIM_CR1_DIR ? FORWARD1 : BACKWARD1);
//      NVIC_InitStructure.NVIC_IRQChannel = TIM8_UP_TIM13_IRQn;
//        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2;//抢占优先级3
//        NVIC_InitStructure.NVIC_IRQChannelSubPriority =0;                //子优先级3
//        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
//        NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器、
//        TIM_ITConfig(TIM8, TIM_IT_CC1 |TIM_IT_CC2,ENABLE);
//        NVIC_EnableIRQ(TIM8_CC_IRQn);
正解是PA11是ch4,编码器接口是ch1和ch2,倒不是外设复用
101
254
254
2017-5-10
55 小时
发表于 2017-7-21 14:12:30 | 显示全部楼层
清诚 发表于 2017-7-23 12:07
拔掉了  但是PA11还是不能捕获到方波  PA9 PA10没拔  因为我用XCOM看采集到的方波个数
238
238
2017-4-17
60 小时
 楼主| 发表于 2017-7-21 14:16:37 | 显示全部楼层
与TIM8  一起采集  平衡小车的编码器  但就是TIM1只有一个(PA8)才能进入中断  PA9 PA10  在串口函数里面复用了  但PA11为什么不能进入中断????麻烦原子哥讲解一下
发表于 2017-7-23 00:35:04 | 显示全部楼层
238
238
2017-4-17
60 小时
 楼主| 发表于 2017-7-23 09:42:53 | 显示全部楼层
F4 TIM1有两组  四通道  我换到PE组通道就可以采集了   PA11应该是被外设复用了,,,
38
84
84
2017-3-16
21 小时
发表于 2017-7-23 10:11:30 | 显示全部楼层
。。。。你这是自问自答。。。
101
254
254
2017-5-10
55 小时
发表于 2017-7-23 10:26:21 | 显示全部楼层
PA11是USB和can的接口啊……要把那组跳线拔掉的
238
238
2017-4-17
60 小时
 楼主| 发表于 2017-7-23 12:07:53 | 显示全部楼层
91
261
261
2017-7-19
31 小时
发表于 2017-7-23 16:26:52 | 显示全部楼层
好像没有通道的初始化配置吧
101
254
254
2017-5-10
55 小时
发表于 2017-7-23 20:24:08 来自手机 | 显示全部楼层
SunMike 发表于 2017-7-23 16:26
好像没有通道的初始化配置吧
因为定时器的编码器接口用的是ch1和ch2,而pa11是ch4自然没反应了……我之前都是用cubemx的自动配置没注意到这点……
91
261
261
2017-7-19
31 小时
发表于 2017-7-23 21:14:35 | 显示全部楼层
cromarti 发表于 2017-7-23 20:24
因为定时器的编码器接口用的是ch1和ch2,而pa11是ch4自然没反应了……我之前都是用cubemx的自动配置没注 ...
好的,学到了,谢谢
238
238
2017-4-17
60 小时
 楼主| 发表于 2017-8-2 17:58:59 | 显示全部楼层
GMT+8, 2026-10-30 06:59
