查看: 4764|回复: 4
stm adcdma采样到的数据是不变的
64
64
2017-3-5
25 小时
发表于 2017-7-25 11:04:17 | 显示全部楼层 |阅读模式
20金钱
直接po程序吧,看了两天了数据一直是错的
void  A#define ADC1_DR_Address    ((uint32_t)0x4001244C)
u16 AD_Value[5][2];
void  ADKey_Init(void)
        ADC_InitTypeDef ADC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC |RCC_APB2Periph_ADC1        , ENABLE );          //使能ADC1通道时钟
        RCC_ADCCLKConfig(RCC_PCLK2_Div6);   //设置ADC分频因子6 72M/6=12,ADC最大时间不能超过14M
        //PA1 作为模拟通道输入引脚
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;                //模拟输入引脚
        GPIO_Init(GPIOC, &GPIO_InitStructure);
        DMA_ADC1_Init();
        ADC_DeInit(ADC1);  //复位ADC1,将外设 ADC1 的全部寄存器重设为缺省值
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;        //ADC工作模式:ADC1和ADC2工作在独立模式
        ADC_InitStructure.ADC_ScanConvMode = ENABLE;        //模数转换工作在道模式
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;        //模数转换工作转换模式
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //转换由软件而不是外部触发启动
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;        //ADC数据右对齐
        ADC_InitStructure.ADC_NbrOfChannel = 2;        //顺序进行规则转换的ADC通道的数目
        ADC_Init(ADC1, &ADC_InitStructure);        //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5 );
  ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_55Cycles5 );
        ADC_DMACmd(ADC1, ENABLE);
        ADC_Cmd(ADC1, ENABLE);        //使能指定的ADC1
        ADC_ResetCalibration(ADC1);        //使能复位校准
        while(ADC_GetResetCalibrationStatus(ADC1));        //等待复位校准结束
        ADC_StartCalibration(ADC1);         //开启AD校准
        while(ADC_GetCalibrationStatus(ADC1));         //等待校准结束
        //ADC_SoftwareStartConvCmd(ADC1, ENABLE);
u16 AD_Value[5][2];
void DMA_ADC1_Init()
        DMA_InitTypeDef  DMA_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
         DMA_DeInit(DMA1_Channel1);        //开启DMA1的第一通道
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1->DR; //DMA对应的外设基地址
    DMA_InitStructure.DMA_MemoryBaseAddr = (uint32_t)&AD_Value;//内存存储基地址 自己开僻的数组
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;//DMA的转换模式为SRC模式,由外设搬移到内存
    DMA_InitStructure.DMA_BufferSize = 10; //DMA缓存大小,N个
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;    //接收一次数据后,设备地址禁止后移
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //关闭接收一次数据后,目标内存地址后移
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;  //定义外设数据宽度为16位
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;  //DMA搬移数据尺寸,HalfWord就是为16位
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;   //转换模式,循环缓存模式。
    DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA优先级高
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;          //M2M模式禁用
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    /* Enable DMA1 channel1 */
    DMA_Cmd(DMA1_Channel1, ENABLE);
   // DMA_ITConfig(DMA1_Channel1,  DMA_IT_TC , ENABLE);
void Get_Key_Adcdma(void)
         ADC_SoftwareStartConvCmd(ADC1, ENABLE);                //使能指定的ADC1的软件转换启动功能
        while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待转换结束
u16  adcx1[2]={0};
u16  adcx[2]={0};
void Get_Key_AdcDma_Average(void)
        u32 temp_val=0;
        u32 temp_val1=0;
         u8 t,i,j;
        Get_Key_Adcdma();
        for(t=0;t<5;t++)
                temp_val+=AD_Value[t][0];
                temp_val1+=AD_Value[t][1];
                //delay_ms(5);
        adcx[0]=temp_val/5;
        adcx1[0]=temp_val1/5;
        printf("%d,%d\r\n",adcx[0],adcx1[0]);
        temp_val=0;
        temp_val1=0;
        for(i=0;i<5;i++)
         for(j=0;j<2;j++)
           AD_Value[i][j]=0;
         ADC_SoftwareStartConvCmd(ADC1, DISABLE);
在中断中调用检测一次AD转换的值
void key_run(void)
        Get_Key_AdcDma_Average();
        Key_Check();
  Key_Check2();
  keyaction();
测到数据这一只这个样子
测到数据这一只这个样子
发表于 2017-7-26 01:20:59 | 显示全部楼层
2017-8-21
发表于 2017-8-21 17:40:35 | 显示全部楼层
这个地址是不是应该这样的(u32)(&ADC1->DR);
48
48
2017-8-20
发表于 2017-8-21 18:00:20 | 显示全部楼层
!!!终于找到同胞有同样的问题了,!!!有没有大神可以回答一下的
发表于 2017-8-22 00:17:16 | 显示全部楼层
参考论坛其他网友的,都有现成的参考
GMT+8, 2026-10-31 04:01
