查看: 4707|回复: 2
EXTI进入不了中断
29
29
2017-7-28
发表于 2017-7-31 19:51:42 | 显示全部楼层 |阅读模式
2金钱
求问,EXTI进入不了中断函数,灯一直亮着。
IC:STM32F103VET6
灯是PB5控制,拉高为亮,低为灭
按键是PB15,按下去是直接接地,PB15上拉
主函数:
int main(void)
        //初始化用的GPIO口
        LED_GPIO_Config();
        //KEY_GPIO_Config();
        EXTI_GPIO_Config();
        LED3(ON);
        while (1);
函数exti.h:
#ifndef _EXTI_H
#define _EXTI_H
//头文件引用
#include "stm32f10x.h"
#include "led.h"
#include "delay.h"
#include "key.h"
void EXTI_GPIO_Config(void)
        //GPIO的复用功能必须打开
       RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
       RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
       //GPIO结构体
       GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
       GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
       //配置外部中断源并进行中断源和GPIO的连接
       EXTI_InitTypeDef  EXTI_InitStructure;
       //清空中断标志
       //EXTI_ClearITPendingBit(EXTI_Line15);
       GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource15);
       EXTI_InitStructure.EXTI_Line = EXTI_Line15;//选择中断线路15
       EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;//设置为中断请求,非事件请求
       EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling; //设置中断触发方式为上下降沿触发
       EXTI_InitStructure.EXTI_LineCmd = ENABLE;//外部中断使能
       EXTI_Init(&EXTI_InitStructure);
       //配置NVIC
       NVIC_InitTypeDef   NVIC_InitStructure;
       NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
       NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;//选择中断通道5
       NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority =2; //抢占式中断优先级设置为1
       NVIC_InitStructure.NVIC_IRQChannelSubPriority =2;  //响应式中断优先级设置为1
       NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;  //使能中断
/*键盘中断(EXTI15)服务程序*/
void EXTI15_10_IRQHandler(void)
     LED_GPIO_Config();
    //if (EXTI_GetITStatus(EXTI_Line15) == SET)
    //if(key0=0)
        delay_ms(100);
        LED3(OFF);
        delay_ms(100);
        EXTI_ClearITPendingBit(EXTI_Line15);//清除标志
#endif
函数led.h:
#ifndef _LED_H
#define _LED_H
//初始化LED对应的GPIO,并设置为高电平,点亮对应的LED
void LED_GPIO_Config(void)
        RCC_APB2PeriphClockCmd (RCC_APB2Periph_GPIOB ,ENABLE);
        GPIO_InitStructure.GPIO_Mode   = GPIO_Mode_Out_PP ;
        GPIO_InitStructure.GPIO_Pin    = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
        GPIO_Init (GPIOB,&GPIO_InitStructure);
        GPIO_SetBits(GPIOB,GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5);
#define ON  1
#define OFF 0
#define LED1(a) if (a) \
GPIO_SetBits(GPIOB,GPIO_Pin_3); \
else \
GPIO_ResetBits (GPIOB,GPIO_Pin_3);
#define LED2(a) if (a) \
GPIO_SetBits(GPIOB,GPIO_Pin_4); \
else \
GPIO_ResetBits (GPIOB,GPIO_Pin_4);
#define LED3(a) if (a) \
GPIO_SetBits(GPIOB,GPIO_Pin_5); \
else \
GPIO_ResetBits (GPIOB,GPIO_Pin_5);
#endif
204
204
2017-7-16
24 小时
发表于 2017-7-31 21:25:31 | 显示全部楼层
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);改成
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);试一下
29
29
2017-7-28
 楼主| 发表于 2017-8-1 10:02:34 | 显示全部楼层
问题解决了,原来是因为我没有加启动文件startup_stm32f10x_hd.s,谢谢各位帮忙
GMT+8, 2026-10-31 19:50
