查看: 6816|回复: 0
stm32cubemx stm32f4 i2s2 发送不能直接发送buffer1,buffer2的数据
265
693
693
2017-7-27
98 小时
发表于 2017-8-4 13:39:32 | 显示全部楼层 |阅读模式
BUFF_MAX_SS=1024;
void Audio_Play(uint32_t I2S_AudioFreq)
{   uint16_t res,i=0;
        uint8_t buffer_switch = 1;
        XferCplt = 0;
        printf("Welcome to use UDA1380 I2S test:\r\n");
//        UDA1380_Configuration();
        f_lseek(&fileR, WaveCounter);
    f_read (&fileR, buffer1, BUFF_MAX_SS, &BytesRead);
    f_read (&fileR, buffer2, BUFF_MAX_SS, &BytesRead);
        I2S_AudioFreq_Config(I2S_AudioFreq);
  /* Start playing wave */
        res=HAL_I2S_Transmit_DMA(&hi2s2,buffer1, BUFF_MAX_SS/2);
        printf("  >WaveDataLength : %fM\r\n",(float)WaveDataLength/1000/1000);
        while(WaveDataLength != 0)
                while(XferCplt == 0)  //DMA传输完成中断里 XferCplt == 1
                        /* wait for DMA transfert complete */
                        /* You can write some code for operate on UDA1380 */
                XferCplt = 0;
                if(buffer_switch == 0)
                        /* Play data from buffer1 */
                        HAL_I2S_Transmit_DMA(&hi2s2,buffer_ctl.tmp1, BUFF_MAX_SS);
                        /* Store data in buffer2 */
                        res=f_read (&fileR, buffer2, BUFF_MAX_SS, &BytesRead);
                        for(i=0;i<512;i++)
                                buffer_ctl.tmp2[i]=buffer2[i];
                        buffer_switch = 1;
                        /* Play data from buffer2 */
                        HAL_I2S_Transmit_DMA(&hi2s2,buffer_ctl.tmp2, BUFF_MAX_SS);
                        /* Store data in buffer1 */
                        res=f_read (&fileR, buffer1, BUFF_MAX_SS, &BytesRead);
                        for(i=0;i<512;i++)
                                buffer_ctl.tmp1[i]=buffer1[i];
                        buffer_switch = 0;
           if(BytesRead!=1024||res!=0)
                break;
        printf("Transfer Complete\r\n");
GMT+8, 2026-10-30 19:18
