查看: 6840|回复: 2
使用两个串口发送相同的数据时,USART2发送的数据有时会包含乱码,USART1正常。
2017-8-4
发表于 2017-8-4 13:52:52 | 显示全部楼层 |阅读模式
//重定义fputc函数
int fputc(int ch, FILE *f)
        while((USART1->SR&0X40)==0);//循环发送,直到发送完毕
        USART1->DR = (u8) ch;
        while((USART2->SR&0X40)==0);//循环发送,直到发送完毕
        USART2->DR = (u8) ch;
        return ch;
void uart_init(u32 bound){
   //GPIO端口设置
USART_InitTypeDef USART_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE); //使能GPIOA时钟
         /* Enable USART1 clocks */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
/* Enable USART2 clocks */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
        //串口1对应引脚复用映射
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource9,GPIO_AF_USART1); //GPIOA9复用为USART1
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource10,GPIO_AF_USART1); //GPIOA10复用为USART1
        //串口2对应引脚复用映射
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource2,GPIO_AF_USART2);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource3,GPIO_AF_USART2);
        //USART1端口配置
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_2 | GPIO_Pin_3; //GPIOA9与GPIOA10
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        //速度50MHz
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽复用输出
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; //上拉
        GPIO_Init(GPIOA,&GPIO_InitStructure); //初始化PA9,PA10
/* USART1  Configure */
  USART_InitStructure.USART_BaudRate = 19200;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No ;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  /* Configure the USART1 */
  USART_Init(USART1, &USART_InitStructure);
  /* INIT  USART1 */
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Enable the USART1 */
  USART_Cmd(USART1, ENABLE);
/* USART2  Configure */
  /* Configure the USART2 */
  USART_Init(USART2, &USART_InitStructure);
  /* INIT  USART2 */
  USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
  /* Enable the USART2 */
  USART_Cmd(USART2, ENABLE);
#if EN_USART1_RX
        USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);//开启相关中断
        //Usart1 NVIC 配置
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;//串口1中断通道
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;//抢占优先级3
        NVIC_InitStructure.NVIC_IRQChannelSubPriority =3;                //子优先级3
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
        NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器、
#endif
#if EN_USART2_RX
        USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);//开启相关中断
        //Usart2 NVIC 配置
        NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;//串口2中断通道
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3;//抢占优先级1
        NVIC_InitStructure.NVIC_IRQChannelSubPriority =3;                //子优先级1
#endif
这是USART的主要代码,其他的包含在附件的,求大佬们看看是哪里的问题。
图片上以1.293为分界线,上面是USART1正常的数据,下面是USART2有问题的数据。
实验34 FLASH模拟EEPROM实验.zip
5.56 MB, 下载次数: 66
文件
250
250
2017-7-20
51 小时
发表于 2017-8-4 15:01:43 | 显示全部楼层
GPIOA不是挂在APB2上的吗?
发表于 2017-8-7 02:19:04 | 显示全部楼层
仿真找bug
GMT+8, 2026-10-30 21:50
