查看: 7080|回复: 5
LWIP客户端发送数据,总是丢失或一次发好几个
52
334
560
560
2016-4-12
230 小时
发表于 2017-8-4 15:57:44 | 显示全部楼层 |阅读模式
如题,我用的LWIP官网例程改的,参考原子例程改了tcp_client_poll函数,如下:static err_t tcp_echoclient_connected(void *arg, struct tcp_pcb *tpcb, err_t err)
  struct echoclient *es = NULL;
  es = (struct echoclient *)mem_malloc(sizeof(struct echoclient));
  if (es != NULL)
    es->state = ES_CONNECTED;
    es->pcb = tpcb;
                es->p_tx = NULL;
                tcp_arg(tpcb, es);
                //tcp_sent(tpcb, tcp_echoclient_sent);
                tcp_poll(tpcb, tcp_echoclient_poll, 1);
                err = ERR_OK;
static err_t tcp_echoclient_poll(void *arg, struct tcp_pcb *tpcb)
  err_t ret_err;
  struct echoclient *es;
  es = (struct echoclient*)arg;
        test6_init();
  if (es != NULL)
                es->p_tx = pbuf_alloc(PBUF_TRANSPORT, strlen((char*)test) , PBUF_POOL);
    pbuf_take(es->p_tx, (char *)test, strlen((char *)test));
                led_onf();
                tcp_echoclient_send_test(tpcb, es);
                //tcp_echoclient_send(tpcb, es);
                if (es->p_tx)
                        pbuf_free(es->p_tx);
                if(es->state == ES_CLOSING) tcp_echoclient_connection_close(tpcb, es);
    ret_err = ERR_OK;
    tcp_abort(tpcb);
    ret_err = ERR_ABRT;
  return ret_err;
static void tcp_echoclient_send_test(struct tcp_pcb *tpcb, struct echoclient * es)
  struct pbuf *ptr;
  err_t wr_err = ERR_OK;
                while ((wr_err == ERR_OK) && ( es->p_tx != NULL) && (es->p_tx->len <= tcp_sndbuf(tpcb)))
                ptr = es->p_tx;
                wr_err = tcp_write(tpcb, ptr->payload, ptr->len, 0);
                if (wr_err == ERR_OK)
                        es->p_tx = ptr->next;
                        if(es->p_tx != NULL)
                                pbuf_ref(es->p_tx);
                        pbuf_free(ptr);
                else if(wr_err == ERR_MEM)
                 es->p_tx = ptr;
                tcp_output(tpcb);
其实和原子例程一模一样的,我每次回调cp_echoclient_poll的时候,重新复制es->p_tx,然后发送,可是会出现下图所示,要么接受不到,要么一下发好几个,接触LWIP已经两个周了,大概了解了下,有好多不懂的地方,求大神不吝赐教!
52
334
560
560
2016-4-12
230 小时
 楼主| 发表于 2017-8-4 16:01:36 | 显示全部楼层
[mw_shl_code=applescript,true]static err_t tcp_echoclient_connected(void *arg, struct tcp_pcb *tpcb, err_t err)
  if (es != NULL)
    es->pcb = tpcb;
                es->p_tx = NULL;
                tcp_arg(tpcb, es);
                err = ERR_OK;
  struct pbuf *ptr;
                ptr = es->p_tx;
                                pbuf_ref(es->p_tx);
                        pbuf_free(ptr);
                 es->p_tx = ptr;
                tcp_output(tpcb);
  err_t ret_err;
        test6_init();
  if (es != NULL)
                led_onf();
                if (es->p_tx)
    ret_err = ERR_OK;
    tcp_abort(tpcb);
    ret_err = ERR_ABRT;
  return ret_err;
}[/mw_shl_code]
52
334
560
560
2016-4-12
230 小时
 楼主| 发表于 2017-8-4 16:02:04 | 显示全部楼层
为了方便看代码,我重新贴了下,刚找到怎么黏代码
52
334
560
560
2016-4-12
230 小时
 楼主| 发表于 2017-8-4 16:03:43 | 显示全部楼层
自己顶自己吧,tcp_echoclient_connected函数里,还有一段else代码,关掉连接的,我没粘好,大神们可以忽略
119
439
1185
1185
2015-9-18
422 小时
发表于 2017-8-4 16:21:22 | 显示全部楼层
当时玩lwip的时候,记得tcp协议有这样一个设置,我描述下:
可以设置缓冲区接收数据到达指定上限才回送数据;也可以设置只要接收到数据(哪怕只接收到一个字节)就回送数据。
你查下,看有无这种可能。
电子爱好者
2017-10-17
发表于 2018-1-2 11:11:44 | 显示全部楼层
可以设置缓冲区接收数据到达指定上限才回送 ...
你好,这个设置在哪可以找到
GMT+8, 2026-11-4 06:08
