查看: 6914|回复: 4
STM32F334使用SPI1配置NRF2401遇到问题
2017-7-25
发表于 2017-8-6 17:03:05 | 显示全部楼层 |阅读模式
我按照原子哥F4上NRF2401的程序改写到F334上,为了验证好不好用,同样借鉴了原子哥的写法:              while(NRF24L01_Check())   //这是F4的程序        {
                LCD_ShowString(30,130,200,16,16,"NRF24L01 Error");
                delay_ms(200);
                LCD_Fill(30,130,239,130+16,WHITE);
                delay_ms(200);
        LCD_ShowString(30,130,200,16,16,"NRF24L01 OK");
改写之后,显示"NRF24L01 Error",然后我仿真发现,读取寄存器GPIOA->ODR一直是0x0000,我感觉应该是SPI1有问题,怀疑的地方有两个,一是我改写的初始化配置:
void SPI1_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  SPI_InitTypeDef  SPI_InitStructure;
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE );        //使能GPIOB时钟
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);//使能SPI1时钟
  //GPIOFB3,4,5初始化设置
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//PB3~5复用功能输出
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用功能
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//100MHz
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉
  GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource3,GPIO_AF_5); //PB3复用为 SPI1
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource4,GPIO_AF_5); //PB4复用为 SPI1
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource5,GPIO_AF_5); //PB5复用为 SPI1
        //这里只针对SPI口初始化
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,ENABLE);//复位SPI1
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,DISABLE);//停止复位SPI1
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;  //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;                //设置SPI工作模式:设置为主SPI
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;                //设置SPI的数据大小:SPI发送接收8位帧结构
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;                //串行同步时钟的空闲状态为高电平
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;        //串行同步时钟的第二个跳变沿(上升或下降)数据被采样
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;                //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;                //定义波特率预分频的值:波特率预分频值为256
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;        //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
        SPI_InitStructure.SPI_CRCPolynomial = 7;        //CRC值计算的多项式
        SPI_Init(SPI1, &SPI_InitStructure);  //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
        SPI_Cmd(SPI1, ENABLE); //使能SPI外设
        SPI1_ReadWriteByte(0xff);//启动传输
此外原子哥的NRF24L01_SPI_Init(void)函数我没有改动;
第二个地方是原子哥的程序需要调用        SPI_I2S_SendData(SPI1, TxData);
但F3库函数没有相同函数名的,我找到了替代的  SPI_I2S_SendData16(SPI1, TxData); //通过外设SPIx发送一个byte 数据
除了软件之外,我看了原子哥的手册,NRF2401的VCC和GND加了一个104的电容,我不懂硬件,但队友说是滤波作用,可以不加。另外IRO关键需要一个1K电阻,因为这段验证程序没有需要判断IRQ,所以我暂时没有加电阻。
以上是我能想出的所有疑点了,因为还是新手,所以请大家援手。
[img]file:///C:\Users\Think\AppData\Roaming\Tencent\Users\1152946532\QQ\WinTemp\RichOle\AD(Q3N7F4DM[P157HCV{DYP.png[/img]
2017-7-25
 楼主| 发表于 2017-8-6 17:12:42 | 显示全部楼层
自己给自己顶一下
2017-7-25
 楼主| 发表于 2017-8-6 17:15:29 | 显示全部楼层
试过各种办法都不行,还是功力不行,虚心请教大家的意见
2017-7-25
 楼主| 发表于 2017-8-6 17:35:05 | 显示全部楼层
自己查出一处BUG,
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource5,GPIO_AF_5); //PB3复用为 SPI1
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource6,GPIO_AF_5); //PB4复用为 SPI1
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource7,GPIO_AF_5); //PB5复用为 SPI1
然而目前还是不好用
发表于 2017-8-6 19:37:42 | 显示全部楼层
从命不忿 发表于 2017-8-6 17:35
自己查出一处BUG,
        GPIO_PinAF ...
继续慢慢改
GMT+8, 2026-10-31 19:26
