查看: 6288|回复: 2
定时器配置PWM问题--开发板例程
2017-7-31
发表于 2017-8-6 17:10:39 | 显示全部楼层 |阅读模式
我把定时器编号由开发板自带的TIM14改为TIM12
void TIM12_PWM_Init(u32 arr,u32 psc)
        //′Ë2¿·ÖDèêÖ¶ˉDT¸ÄIO¿úéèÖÃ
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM12,ENABLE);          //TIM14ê±Öóê1Äü
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF, ENABLE);         //ê1ÄüPORTFê±Öó
        GPIO_PinAFConfig(GPIOF,GPIO_PinSource9,GPIO_AF_TIM12); //GPIOF9¸′óÃÎa¶¨ê±Æ÷14
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;           //GPIOF9
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;        //¸′óÃ1|Äü
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;        //Ëù¶è100MHz
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;      //íÆíì¸′óÃêä3ö
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;        //éÏà-
        GPIO_Init(GPIOF,&GPIO_InitStructure);              //3õê¼»ˉPF9
        TIM_TimeBaseStructure.TIM_Prescaler=psc;  //¶¨ê±Æ÷·ÖÆμ
        TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up; //ÏòéϼÆêyÄ£ê½
        TIM_TimeBaseStructure.TIM_Period=arr;   //×Ô¶ˉÖØ×°ÔØÖμ
        TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseInit(TIM12,&TIM_TimeBaseStructure);//3õê¼»ˉ¶¨ê±Æ÷14
        //3õê¼»ˉTIM14 Channel1 PWMģ꽠
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //Ñ¡Ôñ¶¨ê±Æ÷Ä£ê½:TIMÂö3å¿í¶èμ÷ÖÆÄ£ê½2
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //±è½Ïêä3öê1Äü
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //êä3ö¼«DÔ:TIMêä3ö±è½Ï¼«DÔμí
        TIM_OC1Init(TIM12, &TIM_OCInitStructure);  //¸ù¾YTÖ¸¶¨μÄ2Îêy3õê¼»ˉíaéèTIM1 4OC1
        TIM_OC1PreloadConfig(TIM12, TIM_OCPreload_Enable);  //ê1ÄüTIM14ÔúCCR1éÏμÄÔ¤×°ÔØ¼Ä′æÆ÷
  TIM_ARRPreloadConfig(TIM12,ENABLE);//ARPEê1Äü
        TIM_Cmd(TIM12, ENABLE);  //ê1ÄüTIM14
然后查看了引脚复用连接
  *            @arg GPIO_AF_TIM12: Connect TIM12 pins to AF9
  *            @arg GPIO_AF_TIM13: Connect TIM13 pins to AF9
  *            @arg GPIO_AF_TIM14: Connect TIM14 pins to AF9
没有问题
然后主函数简单修改
int main(void)
        u16 led0pwmval=0;
        u8 dir=1;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//éèÖÃÏμí3ÖD¶ÏóÅÏè¼¶·Ö×é2
        delay_init(168);  //3õê¼»ˉÑóê±oˉêy
        uart_init(115200);//3õê¼»ˉ′®¿ú2¨ìØÂêÎa115200
        //TIM14_PWM_Init(500-1,84-1);        //84M/84=1MhzμļÆêyÆμÂê,ÖØ×°ÔØÖμ500£¬Ëùò&#212WMÆμÂêÎa 1M/500=2Khz.
        TIM12_PWM_Init(500-1,84-1);
   while(1) //êμÏÖ±è½ÏÖμ′ó0-300μYÔö£¬μ½300oó′ó300-0μY¼õ£¬Ñ-»·
                delay_ms(10);
                if(dir)led0pwmval++;//dir==1 led0pwmvalμYÔö
                else led0pwmval--;        //dir==0 led0pwmvalμY¼õ
                if(led0pwmval>300)dir=0;//led0pwmvalμ½′ï300o󣬷½ÏòÎaμY¼õ
                if(led0pwmval==0)dir=1;        //led0pwmvalμY¼õμ½0o󣬷½Ïò¸ÄÎaμYÔö
                //TIM_SetCompare1(TIM14,led0pwmval);        //DT¸Ä±è½ÏÖ죬DT¸ÄÕ¼¿Õ±è
                TIM_SetCompare1(TIM12,led0pwmval);        //DT¸Ä±è½ÏÖ죬DT¸ÄÕ¼¿Õ±è
可是为什么不能正常实现GPIOF9的缓慢变化效果呢?灯都不亮,不知道是怎么回事,求指导
发表于 2017-8-6 19:36:42 | 显示全部楼层
看有没有PWM输出,如果没输出就找配置问题
2017-7-31
 楼主| 发表于 2017-8-6 19:58:43 | 显示全部楼层
谢谢原子哥的回答,我没有示波器,没办法看到是否有PWM输出,但GPIOF9的LED灯没有像TIM14配置后的缓慢变化,配置我就是把TIM14改为了TIM12,不知道是怎么回事呢
GMT+8, 2026-10-30 20:28
