查看: 6058|回复: 2
F407的SPI自主通信一直在GetStatus出问题
57
57
2017-7-28
15 小时
发表于 2017-8-8 15:03:25 | 显示全部楼层 |阅读模式
这个问题已经困扰我一个礼拜了。。。想做一个SPI1通讯SPI2的实验
然后目前有这么几个问题:
①while(SPI_I2S_GetFlagStatus(SPI2,SPI_I2S_FLAG_TXE)== RESET){};
   SPI_I2S_SendData(SPI2,0x01);
   这里在调试的时候一直卡在这。
②不知道SPI1的CS和SP2的CS该怎么搞。
贴代码:一共三个   spi1.h   spi2.h   main.c
①spi1.h
void SPI1_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  SPI_InitTypeDef  SPI_InitStructure;
  RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_SPI1, ENABLE);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_UP;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource4,GPIO_AF_SPI1); //PA4¸ SPI1  CS
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource5,GPIO_AF_SPI1); //PA5¸ SPI1  SCK
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource6,GPIO_AF_SPI1); //PA6¸ SPI1  MISO
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource7,GPIO_AF_SPI1); //PA7¸ SPI1  MOSI
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,ENABLE);
        RCC_APB2PeriphResetCmd(RCC_APB2Periph_SPI1,DISABLE);
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
        SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_16;
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
        SPI_InitStructure.SPI_CRCPolynomial = 7;
        SPI_Init(SPI1, &SPI_InitStructure);
        SPI_Cmd(SPI1, ENABLE); //ê1ÄüSPIíaéè
        SPI1_ReadWriteByte(0xff);
u8 SPI1_ReadWriteByte(u8 TxData)
  while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_TXE) == RESET){}//这里一直卡死
        SPI_I2S_SendData(SPI1, TxData); //这里也是
  while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET){}
        return SPI_I2S_ReceiveData(SPI1);
②spi2.h
和上面一样,管脚定义在
PB12     CS
PB13     SCK
PB14     MISO
PB15    MOSI
③main.c
int main(void)
        delay_init(168);
        uart_init(115200);
        LED_Init();
        SPI1_Init();
        SPI2_Init();
//若SPI之间通讯成功,那么temp的值会到GPIOF的PF9上,灯亮
                        u16 temp=0;
                                        delay_ms(3000);
                        while(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_RXNE)== RESET){};
                                        if(SPI_I2S_GetFlagStatus(SPI1,SPI_I2S_FLAG_BSY)==0)
                                        temp=SPI_I2S_ReceiveData(SPI1);
                                  GPIOF->BSRRH=temp<<9;
求大神帮我看一看,附连接图,
其中我把两个CS都接地了,其他三个管脚对应SCK-SCK   MISO-MISO   MOSI-MOSI
57
57
2017-7-28
15 小时
 楼主| 发表于 2017-8-8 15:04:01 | 显示全部楼层
我这里设置是SPI2主和SPI1从
57
57
2017-7-28
15 小时
 楼主| 发表于 2017-8-9 08:27:35 | 显示全部楼层
顶啊顶
GMT+8, 2026-10-30 21:50
