查看: 4904|回复: 13
求助,探索板输出pwm波后电机不转且屏幕会亮
43
43
2017-8-11
发表于 2017-8-11 15:05:59 | 显示全部楼层 |阅读模式
新人,以前是学机械的,虽然看过正点原子的视频自学单片机,但是还是不能解决,请各位帮帮忙
板子是探索版F4,电调是天行者60A,电机是天蝎星的。
用PB15输出高电平,PD12输出pwm波。
电源连好线插好之后,电机不转只会“哔~”的响,而且屏幕会白屏亮起来,在把电调插在板子上之前是不会亮的。
这是pwm波的程序
#include "pwm.h"
void TIM4_PWM_Init(u32 arr,u32 psc)
不能了 看探索者的原理图 PB15接的是液晶的BL引脚 用其他的输出通道吧
109
5532
10608
10608
2017-2-18
1921 小时
发表于 2017-8-11 15:06:00 | 显示全部楼层
43
43
2017-8-11
 楼主| 发表于 2017-8-11 15:10:05 | 显示全部楼层
上面程序没发出来
#include "pwm.h"
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4,ENABLE);
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOF, ENABLE);
        GPIO_PinAFConfig(GPIOD,GPIO_PinSource12,GPIO_AF_TIM4);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_Init(GPIOD,&GPIO_InitStructure);
        TIM_DeInit(TIM4);
        TIM_TimeBaseStructure.TIM_Prescaler=psc;
        TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
        TIM_TimeBaseStructure.TIM_Period=arr;   //×Ô¶ˉÖØ×°ÔØÖμ
        TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
        TIM_TimeBaseInit(TIM4,&TIM_TimeBaseStructure);
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
        TIM_OC1Init(TIM4, &TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM4,ENABLE);
        TIM_Cmd(TIM4, ENABLE);
PB15输出高电平的程序
#include "PB15output.h"
void PB15_Init(void)
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB,ENABLE);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_OUT;
        GPIO_InitStructure.GPIO_PuPd=GPIO_PuPd_UP;
        GPIO_InitStructure.GPIO_OType=GPIO_OType_PP;
        GPIO_InitStructure.GPIO_Speed=GPIO_Speed_100MHz;
        GPIO_Init(GPIOB,&GPIO_InitStructure);
        GPIO_SetBits(GPIOB,GPIO_Pin_15);
主程序
#include "stm32f4xx.h"
#include "pwm.h"
#include "delay.h"
int main (void)
        u16 pwmval=0;
        delay_init(168);
        TIM4_PWM_Init(500-1,21-1);        //PWM频率选8kHz是因为电机参数有一行是drive frequency----8kHz
        pwmval=300;
        TIM_SetCompare1(TIM4,pwmval);
发表于 2017-8-11 23:47:46 | 显示全部楼层
43
43
2017-8-11
 楼主| 发表于 2017-8-14 10:07:39 | 显示全部楼层
自己顶一下
43
43
2017-8-11
 楼主| 发表于 2017-8-14 10:11:35 | 显示全部楼层
我想问一下会不会是板子上应该哪个接线帽应该拔掉什么之类的
349
1046
1046
2017-5-19
335 小时
发表于 2017-8-14 10:21:33 | 显示全部楼层
加上这句试试 RCC_APB2PeriphClockCmd( RCC_APB2Periph_AFIO |RCC_APB2Periph_GPIOD ,ENABLE);
93
212
212
2016-1-15
64 小时
发表于 2017-8-14 10:28:00 | 显示全部楼层
用示波器量一下PB15 PD12波形对吗?
43
43
2017-8-11
 楼主| 发表于 2017-8-14 12:23:40 | 显示全部楼层
APB2里没有AFIO 和GPIOD啊
2017-5-31
发表于 2017-8-14 12:41:57 | 显示全部楼层
可能是频率错了吧,,PWM频率跟电机没有任何关系,只跟电调有关  ,低端电调的PWM频率都是50HZ的,,,     也就是20ms的周期,里面高电平时间是0.5---2.5ms(或者1---2ms)
349
1046
1046
2017-5-19
335 小时
发表于 2017-8-14 12:47:51 | 显示全部楼层
活尸化严重 发表于 2017-8-14 12:23
APB2里没有AFIO 和GPIOD啊
哦,我看错芯片了
43
43
2017-8-11
 楼主| 发表于 2017-8-14 14:25:46 | 显示全部楼层
原子哥,我发现PB15一接5V,屏幕就会亮,那我PB15还能用来输出高电平么
43
43
2017-8-11
 楼主| 发表于 2017-8-14 17:01:31 | 显示全部楼层
ylmf56 发表于 2017-8-14 12:41
可能是频率错了吧,,PWM频率跟电机没有任何关系,只跟电调有关  ,低端电调的PWM频率都是50HZ的,,,     也就是 ...
改到50HZ还是不行
43
43
2017-8-11
 楼主| 发表于 2017-8-14 18:06:25 | 显示全部楼层
谢谢
GMT+8, 2026-10-30 23:38
