查看: 5957|回复: 1
请问void KEY_Timer_Func(pTimer Timer)这种函数是什么意思?应该怎么写和怎么用呢?
2017-8-19
发表于 2017-8-19 19:24:12 | 显示全部楼层 |阅读模式
程序具体如下:
/*ÅäÖð′¼ügpioòy½ÅÎaía2¿ÖD¶Ï,*/
void EXTILine_Config(GPIO_TypeDef* GPIOx, uint16_t gpio_pin,uint32_t exti_line, uint8_t IRQChannel, uint32_t Level)
        /* Enable GPIOE clock */
        //RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
        /* Configure PE2/3/4 pin as input floating */
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
        if (Level)
          GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
                GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
        GPIO_InitStructure.GPIO_Pin = gpio_pin;
        GPIO_Init(GPIOx, &GPIO_InitStructure);
        /* Configure EXTI Line */
        EXTI_InitStructure.EXTI_Line = exti_line;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
        if (Level)
                EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
          EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
        EXTI_InitStructure.EXTI_LineCmd = ENABLE;
        EXTI_Init(&EXTI_InitStructure);
        /* Enable and set EXTI Line Interrupt*/
        NVIC_InitStructure.NVIC_IRQChannel = IRQChannel;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x01;//ÇàÕ¼ê½óÅÏè¼¶
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x01;//Ö¸¶¨′óóÅÏè¼¶
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
extern void blood_pressure_measurement_stop(void);
        uint8_t res;
        pKeyData Data = (pKeyData)Timer->Data;
        //é¨Ãè°′¼ü
        res=GPIO_ReadInputDataBit(Data->GPIOx, Data->GpioPin);
        if(res == Data->Level)
                if (KeyStatus[Data->KeyId - 1] & 1)
                        //printf("%s key Down\r\n", str[(Data->KeyId & 0xFF) - 1]);
                        EVENT_QueuePush(EVENT_KEYDOWN, (Data->KeyId & 0xFF), 0);
                        blood_pressure_measurement_stop();
                        //printf("%s key Repeat\r\n", str[(Data->KeyId & 0xFF) - 1]);
                        EVENT_QueuePush(EVENT_KEYREPEAT, (Data->KeyId & 0xFF), 0);
                KeyStatus[Data->KeyId - 1] &= ~1;
                if (!(KeyStatus[Data->KeyId - 1] & 1))
                        //printf("%s key Up\r\n", str[(Data->KeyId & 0xFF) - 1]);
                        EVENT_QueuePush(EVENT_KEYUP, (Data->KeyId & 0xFF), 0);
                        KeyStatus[Data->KeyId - 1] |= 1;
        //′ò¿aÖD¶Ï
        if (res != Data->Level)
                //Data->KeyStatus |= 3;
                SYS_TimerSetDelFlag(Timer->ID, SYS_TIMER_REMOVE);
                NVIC_InitStructure.NVIC_IRQChannel = Data->IrqType;
        } else {
                SYS_TimerModify(Timer->ID, 200);
void EXTI0_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line0) != RESET)
                        //½ûÖ1ÖD¶Ï
                        NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;
                        NVIC_InitStructure.NVIC_IRQChannelCmd = DISABLE;
                        //printf("\r\n EXTI2_IRQHandler\r\n");
                        SYS_TimerAdd(15, KEY_Timer_Func, SYS_TIMER_REPEAT, &KeyTimerData[4]);
                        SYS_TimerStart();
                /* Clear the EXTI line 2 pending bit */
                EXTI_ClearITPendingBit(EXTI_Line0);
void EXTI2_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line2) != RESET)
                //if (SYS_Timer_Lock == SYS_TIMER_UNLOCK)
                        //½ûÖ1ÖD¶Ï
                        NVIC_InitStructure.NVIC_IRQChannel = EXTI2_IRQn;
                        SYS_TimerAdd(15, KEY_Timer_Func, SYS_TIMER_REPEAT, &KeyTimerData[0]);
                        SYS_TimerStart();
                EXTI_ClearITPendingBit(EXTI_Line2);
void EXTI3_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line3) != RESET)
                //½ûÖ1ÖD¶Ï
                NVIC_InitStructure.NVIC_IRQChannel = EXTI3_IRQn;
                //printf("\r\n EXTI3_IRQHandler\r\n");
                SYS_TimerAdd(15, KEY_Timer_Func, SYS_TIMER_REPEAT, &KeyTimerData[1]);
                SYS_TimerStart();
                /* Clear the EXTI line 3 pending bit */
                EXTI_ClearITPendingBit(EXTI_Line3);
void EXTI4_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line4) != RESET)
                //½ûÖ1ÖD¶Ï
                NVIC_InitStructure.NVIC_IRQChannel = EXTI4_IRQn;
                NVIC_Init(&NVIC_InitStructure);;
                //printf("\r\n EXTI4_IRQHandler\r\n");
                SYS_TimerAdd(15, KEY_Timer_Func, SYS_TIMER_REPEAT, &KeyTimerData[2]);
                SYS_TimerStart();
                /* Clear the EXTI line 4 pending bit */
                EXTI_ClearITPendingBit(EXTI_Line4);
void EXTI9_5_IRQHandler(void)
        if(EXTI_GetITStatus(EXTI_Line6) != RESET)
                //½ûÖ1ÖD¶Ï
                NVIC_InitStructure.NVIC_IRQChannel = EXTI_Line6;
                SYS_TimerAdd(15, KEY_Timer_Func, SYS_TIMER_REPEAT, &KeyTimerData[3]);
                SYS_TimerStart();
                EXTI_ClearITPendingBit(EXTI_Line6);
发表于 2017-8-23 01:06:15 | 显示全部楼层
GMT+8, 2026-10-31 04:26
