查看: 6773|回复: 2
(stm32f4 HAL)万能的原子啊,请告诉我 串口接收中这段代码的意思
71
698
698
2017-8-14
131 小时
发表于 2017-8-21 16:26:45 | 显示全部楼层 |阅读模式
  * @brief  Receives an amount of data in non blocking mode
  * @param  huart: pointer to a UART_HandleTypeDef structure that contains
  *                the configuration information for the specified UART module.
  * @retval HAL status
static HAL_StatusTypeDef UART_Receive_IT(UART_HandleTypeDef *huart)
  uint16_t* tmp;
  /* Check that a Rx process is ongoing */
  if(huart->RxState == HAL_UART_STATE_BUSY_RX)
    if(huart->Init.WordLength == UART_WORDLENGTH_9B)
      tmp = (uint16_t*) huart->pRxBuffPtr;
      if(huart->Init.Parity == UART_PARITY_NONE)
        *tmp = (uint16_t)(huart->Instance->DR & (uint16_t)0x01FFU);
        huart->pRxBuffPtr += 2U;
        *tmp = (uint16_t)(huart->Instance->DR & (uint16_t)0x00FFU);
        huart->pRxBuffPtr += 1U;
        *huart->pRxBuffPtr++ = (uint8_t)(huart->Instance->DR & (uint8_t)0x00FFU);
        *huart->pRxBuffPtr++ = (uint8_t)(huart->Instance->DR & (uint8_t)0x007FU);
    if(--huart->RxXferCount == 0U)
      /* Disable the UART Parity Error Interrupt and RXNE interrupt*/
      CLEAR_BIT(huart->Instance->CR1, (USART_CR1_RXNEIE | USART_CR1_PEIE));
      /* Disable the UART Error Interrupt: (Frame error, noise error, overrun error) */
      CLEAR_BIT(huart->Instance->CR3, USART_CR3_EIE);
      /* Rx process is completed, restore huart->RxState to Ready */
      huart->RxState = HAL_UART_STATE_READY;
      HAL_UART_RxCpltCallback(huart);
      return HAL_OK;
    return HAL_OK;
    return HAL_BUSY;
那个2U,1U,0x00FFU的是啥意思啊???
就是2 1 0x00FF这些数字,后面的U表示unsigned
yi?我的二哈哪去了
88
7369
14980
14980
2013-11-13
1823 小时
发表于 2017-8-21 16:26:46 | 显示全部楼层
71
698
698
2017-8-14
131 小时
 楼主| 发表于 2017-8-21 16:53:06 | 显示全部楼层
啊啊啊,十分感谢,谢谢大佬
yi?我的二哈哪去了
GMT+8, 2026-10-31 04:26
