查看: 4722|回复: 3
FATFS 写文件,打开空白
90
90
2017-8-2
19 小时
发表于 2017-8-25 19:53:46 | 显示全部楼层 |阅读模式
FATFS 写文件, f_open 成功,f_write 也显示成功,但是打开 SD 卡,文件内容却是空白?
main 函数部分代码如下:
[mw_shl_code=c,true]u8 senddata[20];
FRESULT fr;
mmemset(senddata, 'b', sizeof(senddata));
mmeminit(SRAMIN);
FATFS_Init();
f_mount(fs[0], "0:", 1);
key = KEY_Scan();
if(key == KEY_UP)
fr = f_open(file, "test.txt", FA_CREATE_ALWAYS|FA_WRITE);
if(fr) printf("Create File Fail\n");
printf("Create File Success\n");
fr = f_write(file, senddata, sizeof senddata, (UINT *)&temp);
if(fr) printf("Write Error. Error number:%d\n", fr);
else printf("Write OK. Write number:%d. Write data:%s\n", temp, senddata);
f_close(file);
[/mw_shl_code]
printf 显示 Create File Success,Write OK. Write number:20. Write data: 20个b
但是打开文件,空白。。。
底层是用 SPI 驱动 SD 的,应该没有问题。
底层 Write 代码:
[mw_shl_code=applescript,true]// Write single sector to SD
// @retval 0-success 1-SD not ready 2-SD Write overtime
u8 SD_WriteSector(u8 *p, u8 datatoken)
        u16 i, retry = 0XFFFF;
        u8 r1;
        if(SD_WaitReady()) return 1;
        SPI2_ReadWriteByte(datatoken);        // Data token
        if(datatoken != 0XFD)        // Stop token for CMD25
                for(i = 0; i < 512; i++) SPI2_ReadWriteByte(p);                // Write 512 Bytes
                SPI2_ReadWriteByte(0XFF);        // CRC1
                SPI2_ReadWriteByte(0XFF);        // CRC2
                r1 =  SPI2_ReadWriteByte(0XFF);                                                        // Data response
                if((r1&0X1F) != 0X05) return r1;
                while(!SPI2_ReadWriteByte(0XFF) && retry)
                        retry--;
                if(!retry) return 2;
        return 0;
u8 SD_WriteDisk(u8 *p, u32 sector, u8 cnt)
        u8 r1;
        if(SD_Type != SD_TYPE_V2HC) sector <<= 9;                // change to sector address
        if(cnt == 1)
                printf("Sector 1\n");
                if(!SD_WriteCmd(CMD24, sector))                                // Send block write command
                        r1 = SD_WriteSector(p, 0XFE);                        // Write block in data paacket form
                        printf("Write Single Sector, result:%d\n", r1);
                printf("Sector 2\n");
                if(SD_Type != SD_TYPE_MMC)
                        SD_WriteCmd(CMD55, 0);
                        SD_WriteCmd(ACMD23, cnt);
                if(!SD_WriteCmd(CMD25, sector))                                // Send multiple block write command
                        do
                                r1 = SD_WriteSector(p, 0XFC);
                                p += 512;
                                cnt--;
                        }while(!r1 && cnt);
                        r1 = SD_WriteSector(0, 0XFD);                                // Send Stop Token
        SD_DeSelect();
        return r1;
}[/mw_shl_code]
输出:Sector 1. Write Single Sector, result: 0
发表于 2017-8-26 00:19:41 | 显示全部楼层
f_close正常么?
123
1185
1185
2016-9-17
140 小时
发表于 2017-9-11 16:54:06 | 显示全部楼层
file:///C:/Documents%20and%20Settings/Administrator/桌面/7.png
123
1185
1185
2016-9-17
140 小时
发表于 2017-9-11 16:54:48 | 显示全部楼层
GMT+8, 2026-10-31 10:22
