查看: 12101|回复: 4
STM32F767开发板学习串口接收试验报错:HAL_UART_RxCpltCallback multiply defined和USART1_IRQHandler multiply defined
2017-8-27
发表于 2017-8-27 20:47:25 | 显示全部楼层 |阅读模式
我在使用STM32F767开发板,学习《35.UART接收-串口接收测试小实验》视频教程中遇到两个编译问题
1...\OBJ\Template.axf: Error: L6200E: Symbol HAL_UART_RxCpltCallback multiply defined (by usart.o and main.o);
2...\OBJ\Template.axf: Error: L6200E: Symbol USART1_IRQHandler multiply defined (by usart.o and main.o)。
我是按照楼主的教程代码编写,他用STM32F429编译的没有问题,我使用STM32F767编译出现以上两处错误。经过仔细核对没有解决,以下是我的代码,请高手帮忙指导指导。
#include "sys.h"
#include "delay.h"
#include "usart.h"
u8 rdata[1];
UART_HandleTypeDef usart1_handler;
void uart1_init()
usart1_handler.Instance = USART1;
usart1_handler.Init.BaudRate = 115200;
usart1_handler.Init.WordLength = UART_WORDLENGTH_8B;
usart1_handler.Init.StopBits = UART_STOPBITS_1;
usart1_handler.Init.HwFlowCtl = UART_HWCONTROL_NONE;
usart1_handler.Init.Mode = UART_MODE_TX_RX;
usart1_handler.Init.Parity = UART_PARITY_NONE;
HAL_UART_Init(&usart1_handler);
void HAL_UART_MspInit(UART_HandleTypeDef *huart)
GPIO_InitTypeDef GPIO_Initure;
if(huart->Instance == USART1)
  __HAL_RCC_GPIOA_CLK_ENABLE();   //ʹÄÜGPIOAʱÖÓ
  __HAL_RCC_USART1_CLK_ENABLE();   //ʹÄÜUSART1ʱÖÓ
  GPIO_Initure.Pin = GPIO_PIN_9;
  GPIO_Initure.Mode = GPIO_MODE_AF_PP;
  GPIO_Initure.Pull = GPIO_PULLUP;
  GPIO_Initure.Speed = GPIO_SPEED_HIGH;
  GPIO_Initure.Alternate = GPIO_AF7_USART1;
  HAL_GPIO_Init(GPIOA,&GPIO_Initure);
  GPIO_Initure.Pin = GPIO_PIN_10;
  HAL_NVIC_SetPriority(USART1_IRQn,3,3);
  HAL_NVIC_EnableIRQ(USART1_IRQn);
void USART1_IRQHandler(void)
HAL_UART_IRQHandler(&usart1_handler);
HAL_UART_Receive_IT(&usart1_handler,rdata,sizeof(rdata));
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
u8 rec;
  rec = *( (huart->pRxBuffPtr)-1 );
  //rec = rdata[0];
  HAL_UART_Transmit(&usart1_handler,&rec,1,1000);
int main(void)
//u8 buff[] = "test&My name is yaojun";
Cache_Enable();                 //´ò¿ªL1-Cache
HAL_Init();            //³õʼ»¯HAL¿â
Stm32_Clock_Init(432,25,2,9);   //ÉèÖÃʱÖÓ,216Mhz
delay_init(216);
uart1_init();
// HAL_UART_Transmit(&usart1_handler,buff,sizeof(buff),1000);
// delay_ms(500);
提示的都这么明显了!重复定义!
88
7369
14980
14980
2013-11-13
1823 小时
发表于 2017-8-27 20:47:26 | 显示全部楼层
提示的都这么明显了!重复定义!
72
72
2020-5-11
14 小时
发表于 2020-7-8 16:58:39 | 显示全部楼层
请问,重复定义该怎么解决?
77
77
2020-3-10
14 小时
发表于 2020-7-18 18:26:25 | 显示全部楼层
在左侧SYSTEM文件夹里面移除正点原子编写的usart   是这个文件里面代码重复了
2017-8-27
 楼主| 发表于 2022-5-26 12:05:38 | 显示全部楼层
谢谢!
GMT+8, 2026-11-14 10:59
