查看: 9674|回复: 30
阿波罗使用HAL库USART2输出乱码
172
172
2015-11-12
28 小时
发表于 2017-8-28 17:17:30 | 显示全部楼层 |阅读模式
使用STM32CubeMX产生的代码,正常输出。自己新建的工程,拷贝STM32CubeMX生产的代码。结果USART2输出是乱码,GPIO口控制LED灯饰正常的。求解为什么?是不是工程建立的时候有什么要配置的。
第一次使用HAL库,以前使用STD库都很正常。代码就是很简单的,让USART2重复输出。
下面是代码:
“main.c”如下:
UART_HandleTypeDef huart2;
static void SystemClock_Config(void)
    RCC_OscInitTypeDef RCC_OscInitStruct;
    RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Configure the main internal regulator output voltage
    __HAL_RCC_PWR_CLK_ENABLE();
    __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
    /**Initializes the CPU, AHB and APB busses clocks
    RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
    RCC_OscInitStruct.HSEState = RCC_HSE_ON;
    RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
    RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
    RCC_OscInitStruct.PLL.PLLM = 25;
    RCC_OscInitStruct.PLL.PLLN = 360;
    RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
    RCC_OscInitStruct.PLL.PLLQ = 4;
    if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    /**Activate the Over-Drive mode
    if (HAL_PWREx_EnableOverDrive() != HAL_OK)
    RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                                  |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
    RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
    RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
    RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
    RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
    if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    /**Configure the Systick interrupt time
    HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
    HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
    /* SysTick_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
static void MX_GPIO_Init(void)
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
static void USART_Config(void)
    huart2.Instance = USART2;
    huart2.Init.BaudRate = 115200;
    huart2.Init.WordLength = UART_WORDLENGTH_8B;
    huart2.Init.StopBits = UART_STOPBITS_1;
    huart2.Init.Parity = UART_PARITY_NONE;
    huart2.Init.Mode = UART_MODE_TX_RX;
    huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
    huart2.Init.OverSampling = UART_OVERSAMPLING_16;
    if (HAL_UART_Init(&huart2) != HAL_OK)
int main(void)
好了,自己打开编译一下
265
693
693
2017-7-27
98 小时
发表于 2017-8-28 17:17:31 | 显示全部楼层
好了,自己打开编译一下
USART2.rar
5.1 MB, 下载次数: 206
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-28 17:18:49 | 显示全部楼层
int main(void)
        uint8_t buf[5] = {0x31,0x32,0x33,0x34,0x35};
        HAL_Init();
        SystemClock_Config();
        MX_GPIO_Init();
        USART_Config();
                HAL_UART_Transmit(&huart2,buf,5,1000);
                HAL_Delay(2000);
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-28 17:19:12 | 显示全部楼层
void HAL_MspInit(void)
    HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_2);
    /* System interrupt init*/
    /* MemoryManagement_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(MemoryManagement_IRQn, 0, 0);
    /* BusFault_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(BusFault_IRQn, 0, 0);
    /* UsageFault_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(UsageFault_IRQn, 0, 0);
    /* SVCall_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(SVCall_IRQn, 0, 0);
    /* DebugMonitor_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(DebugMonitor_IRQn, 0, 0);
    /* PendSV_IRQn interrupt configuration */
    HAL_NVIC_SetPriority(PendSV_IRQn, 0, 0);
void HAL_UART_MspInit(UART_HandleTypeDef* huart)
  GPIO_InitTypeDef GPIO_InitStruct;
  if(huart->Instance==USART2)
  /* USER CODE BEGIN USART2_MspInit 0 */
  /* USER CODE END USART2_MspInit 0 */
    /* Peripheral clock enable */
    __HAL_RCC_USART2_CLK_ENABLE();
    /**USART2 GPIO Configuration
    PA2     ------> USART2_TX
    PA3     ------> USART2_RX
    GPIO_InitStruct.Pin = GPIO_PIN_2|GPIO_PIN_3;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_PULLUP;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF7_USART2;
    HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
    /* USART2 interrupt Init */
    HAL_NVIC_SetPriority(USART2_IRQn, 1, 1);
    HAL_NVIC_EnableIRQ(USART2_IRQn);
  /* USER CODE BEGIN USART2_MspInit 1 */
  /* USER CODE END USART2_MspInit 1 */
void HAL_UART_MspDeInit(UART_HandleTypeDef* huart)
  /* USER CODE BEGIN USART2_MspDeInit 0 */
  /* USER CODE END USART2_MspDeInit 0 */
    /* Peripheral clock disable */
    __HAL_RCC_USART2_CLK_DISABLE();
    HAL_GPIO_DeInit(GPIOA, GPIO_PIN_2|GPIO_PIN_3);
    /* USART2 interrupt DeInit */
    HAL_NVIC_DisableIRQ(USART2_IRQn);
  /* USER CODE BEGIN USART2_MspDeInit 1 */
  /* USER CODE END USART2_MspDeInit 1 */
265
693
693
2017-7-27
98 小时
发表于 2017-8-28 17:33:49 | 显示全部楼层
HAL_UART_Transmit(&huart2,buf,5,1000);这个是串口发送函数,不是printf串口打印函数
int main(void)
        uint8_t buf[5] = {"a","b","c","d","e"};
        HAL_Init();
        MX_GPIO_Init();
        USART_Config();
                HAL_Delay(2000);
这样发,串口打印就是abcde
171
171
2016-1-19
44 小时
发表于 2017-8-29 00:12:44 | 显示全部楼层
我调试的也是乱码,求解
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-29 08:24:06 | 显示全部楼层
有什么区别?
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 08:29:13 | 显示全部楼层
HAL_UART_Transmit(&huart2,buf,5,1000);相当于下面这个发送函数,多了些判断,增添了接收超时等等,这说得不够清楚,你找到这函数进看看什么都明白了
void Uart2_SendData(u8 *data, u16 count)//用于发数据给CPU
u16 i = 0;
while(USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET);
for(i = 0;i<count;i++)
  USART_SendData(USART1, *(data+i));
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 08:37:32 | 显示全部楼层
说一下芯片型号,给建一个工程,2分钟搞定
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-29 08:53:35 | 显示全部楼层
stm32f429,用hal库驱动usart2
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 08:55:36 | 显示全部楼层
stm32f429 后面的后缀什么,说具体点
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-29 09:00:01 | 显示全部楼层
阿波罗的板子stm32f429igt6
43
480
1352
1352
2014-12-24
321 小时
发表于 2017-8-29 09:12:24 | 显示全部楼层
乱码的问题一般都是波特率不对,可能是波特率没有计算正确,可能是时钟没有配置正确。
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 09:14:05 | 显示全部楼层
好了,下载测试一下
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 09:17:53 | 显示全部楼层
文件太大上传不了
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 09:23:12 | 显示全部楼层
波特频率 115200
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-29 09:28:25 | 显示全部楼层
huanghan 发表于 2017-8-29 09:21
好了,自己打开编译一下
用软件STM32CubeMX生产的代码,我也可以,因为我不喜欢这个代码风格,就自建一个工程,把STM32CubeMX相应代码原封不动拷贝到工程里,输出就是乱码了。应该不是这个printf的原因。
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 09:36:45 | 显示全部楼层
HAL_UART_Transmit(&huart2,buf,5,1000);  你用的这个函数不是串口打印函数,相当于这个USART_SendData(USART2, *(data+i));
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-29 09:41:10 | 显示全部楼层
huanghan 发表于 2017-8-29 09:36
HAL_UART_Transmit(&huart2,buf,5,1000);  你用的这个函数不是串口打印函数,相当于这个USART_SendData(USA ...
用STM32CubeMX生成的代码,用HAL_UART_Transmit直接可以输出。
printf使用了fputc,
int fputc(int ch, FILE *f)
  HAL_UART_Transmit(&huart2, (uint8_t *)&ch, 1, 0xFFFF);
  return ch;
这里面不还是使用了HAL_UART_Transmit。
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 09:46:18 | 显示全部楼层
printf使用了fputc,
int fputc(int ch, ...
USART2重定义了
你看看这篇文章就明白了http://www.waveshare.net/study/article-644-1.html
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-29 09:50:23 | 显示全部楼层
你可以试试,用HAL_UART_Transmit能不能输出。。。
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 09:52:36 | 显示全部楼层
能输出,USB转串口打印是乱码,
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-29 09:57:03 | 显示全部楼层
huanghan 发表于 2017-8-29 09:52
能输出,串口打印是乱码
那我为什么不是乱码呢?printf重定义,是定义fputc,不是重定义usart2。
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-29 10:03:19 | 显示全部楼层
能输出,USB转串口打印是乱码,
如果此时要用多个串口输出数据,那你怎么办?printf只能绑一个串口
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 10:03:34 | 显示全部楼层
我无语了
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-29 10:09:35 | 显示全部楼层
肯定不是你说的什么printf的问题。就是我的工程设置那错了,但是我找不到哪。
我现在用CubeMX生产的工程直接修改的代码,还是用HAL_UART_Transmit函数,不用printf,结果难道不是对的?
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 10:10:29 | 显示全部楼层
printf 给PC机用,一就够了。
要用多个串口输出数据,选择串口多的芯片
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 10:12:46 | 显示全部楼层
printf 给PC机用,一就够了。
你打印中文看看
172
172
2015-11-12
28 小时
 楼主| 发表于 2017-8-29 10:16:45 | 显示全部楼层
中文一样,printf只是用着方便,并不是你说的那样。
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 10:27:50 | 显示全部楼层
你打印的12345是错的吗?
265
693
693
2017-7-27
98 小时
发表于 2017-8-29 10:41:08 | 显示全部楼层
看看你移植的工程
GMT+8, 2026-10-31 06:42
