查看: 4305|回复: 4
我用的定时器中断输出固定个数PWM为什么不准确呢
2017-8-29
发表于 2017-8-29 15:48:06 | 显示全部楼层 |阅读模式
我用的定时器4输出固定个数的PWM,但是仿真输出的个数和我程序设定的不一样,我程序设置5个PWM,仿真中它输出9个,无语,求大神解答
void PWM_Init(u16 arr,u16 psc)
        u16 val1=arr/5;
        TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
        TIM_OCInitTypeDef TIM_OCInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4 ,ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO ,ENABLE);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9;
        TIM_TimeBaseInitStructure.TIM_Period=arr;
        TIM_TimeBaseInitStructure.TIM_Prescaler=psc;
        TIM_TimeBaseInitStructure.TIM_ClockDivision=0;
        TIM_TimeBaseInitStructure.TIM_CounterMode=TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM4,&TIM_TimeBaseInitStructure);
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_Pulse = val1;
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OC1Init(TIM4, &TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
        TIM_ARRPreloadConfig(TIM4, ENABLE);
        TIM_ClearITPendingBit(TIM4, TIM_IT_CC1);
        TIM_ITConfig(TIM4,TIM_IT_CC1,ENABLE);
void NVIC_Config(void)
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn  ;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
主函数
u32 step=0;
int main()
        delay_init();
        uart_init(9600);
        NVIC_Config();
        PWM_Init(99,719);
        LED_Init();
        TIM_Cmd(TIM4,ENABLE);
        delay_ms(100);
         LED1=!LED1;
         delay_ms(100);
void TIM4_IRQHandler(void)
        if(TIM_GetITStatus(TIM4,TIM_IT_CC1)!=RESET)
                TIM_ClearITPendingBit(TIM4,TIM_IT_CC1);
        step++;
                printf("%d\n",step);
                if(step==5)
                TIM_Cmd(TIM4,DISABLE);
printf很占时间,去掉试试
发表于 2017-8-29 15:48:07 | 显示全部楼层
printf很占时间,去掉试试
2017-8-29
 楼主| 发表于 2017-8-29 15:49:38 | 显示全部楼层
请问代码有毛病吗
2017-8-29
 楼主| 发表于 2017-8-30 10:41:58 | 显示全部楼层
正点原子 发表于 2017-8-30 00:37
printf很占时间,去掉试试
原子哥果然厉害,可以了,但是输出的脉冲总是比设定的少一个,咋回事捏
发表于 2017-8-31 01:09:24 | 显示全部楼层
step记得清零
GMT+8, 2026-10-31 07:12
