查看: 6375|回复: 2
iwdg不能動作
2017-8-30
发表于 2017-8-30 10:24:55 | 显示全部楼层 |阅读模式
大家好 請問一下 我最近在做看門狗的實驗 但是看門狗一直不起作用 麻煩大家指導一下 以下是我的程式碼
#include "stm32f4xx_hal.h"
IWDG_HandleTypeDef hiwdg;
GPIO_InitTypeDef gpio_init;
void SystemClock_Config(void);
void Error_Handler(void);
static void MX_GPIO_Init(void);
static void MX_IWDG_Init(void);
int main(void)
  HAL_Init();
  SystemClock_Config();
  MX_GPIO_Init();
  MX_IWDG_Init();
        HAL_IWDG_Start(&hiwdg);
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE3);
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSI;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.HSICalibrationValue = 16;
  RCC_OscInitStruct.LSIState = RCC_LSI_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* IWDG init function */
  hiwdg.Instance = IWDG;
  hiwdg.Init.Prescaler = IWDG_PRESCALER_64;
  hiwdg.Init.Reload = 500;
        HAL_IWDG_Init(&hiwdg);
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
        __HAL_RCC_GPIOB_CLK_ENABLE();
        gpio_init.Pin = GPIO_PIN_0;
        gpio_init.Mode = GPIO_MODE_OUTPUT_PP;
        gpio_init.Speed = GPIO_SPEED_FREQ_HIGH;
        gpio_init.Pull = GPIO_NOPULL;
        HAL_GPIO_Init(GPIOB,&gpio_init);
#ifdef USE_FULL_ASSERT
void assert_failed(uint8_t* file, uint32_t line)
#endif
如果初始化没问题, main函数这样就行[/backcolor] [/backcolor] [/backcolor] int main(void)[/backcolor] {[/backcolor] HAL_Init();[/backcolor] [/backcolor] SystemClock_Config();[/backcolor] [/backcolor] MX_GPIO_Init();[/backcolor] MX_IWDG_Init();[/backcolor] while(1)[/backcolor] {[/backcolor] // printf("\n\r Refreshes the IWDG !!!\n\r") ...
265
693
693
2017-7-27
98 小时
发表于 2017-8-30 10:24:56 | 显示全部楼层
int main(void)
  HAL_Init();
  MX_GPIO_Init();
  MX_IWDG_Init();
        { //      printf("\n\r Refreshes the IWDG !!!\n\r");  //可以加打印,检测运行是否正常
       HAL_IWDG_Refresh(&hiwdg);
       HAL_Delay(800);
2017-8-30
 楼主| 发表于 2017-8-30 11:43:31 | 显示全部楼层
謝謝你 後來解決了 我在HAL_IWDG_Start函數裡__HAL_IWDG_START前面加一段延遲函數就好了
HAL_StatusTypeDef HAL_IWDG_Start(IWDG_HandleTypeDef *hiwdg)
  /* Process Locked */
  __HAL_LOCK(hiwdg);
    /* Change IWDG peripheral state */
  hiwdg->State = HAL_IWDG_STATE_BUSY;
        delay(250000);
  /* Start the IWDG peripheral */
  __HAL_IWDG_START(hiwdg);
    /* Reload IWDG counter with value defined in the RLR register */
  __HAL_IWDG_RELOAD_COUNTER(hiwdg);
  hiwdg->State = HAL_IWDG_STATE_READY;
  /* Process Unlocked */
  __HAL_UNLOCK(hiwdg);
  /* Return function status */
  return HAL_OK;
GMT+8, 2026-10-31 07:12
