查看: 6995|回复: 1
谁能帮我在程序加几个按键
2013-3-11
发表于 2013-4-21 21:45:15 | 显示全部楼层 |阅读模式
  #include <reg51.h>
#include <intrins.h>
#define  NOP()   _nop_()
#define uchar unsigned char
#define uint  unsigned int
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
void delay(uchar x);
void delay1(int ms);
void beep(void);
sbit IRIN = P3^2;         //红外接收器数据线
sbit BEEP = P1^5;         //蜂鸣器驱动线
sbit LED1=P1^0;  //主音量 +
sbit LED2=P1^1;  //主音量 -
sbit LED3=P1^2;  //高音 -
sbit LED4=P1^3;  //高音 +
sbit LED5=P3^3;  //低音 -
sbit LED6=P3^4;  //低音 +
sbit key1=P2^0;  //切换
sbit key2=P2^1;  //静音
sbit key3=P2^2;  //开关
sbit QIEHUAN=P2^3; //切换键      怎么让这几个按键控制   p2.3  p2.4  p2.5
sbit JINGYIN=P2^4; //静音键
sbit OFF=P2^5;          //开关键
uchar IRCOM[7];
uchar cdis1[] = {" REMOTE CONTROL "};
uchar cdis2[] = {"  IR-CODE: ----H"};
main()
    IE = 0x81;
    TCON = 0x01;
    IRIN=1;
    BEEP=1;
void IR_IN(void) interrupt 0
  unsigned char j,k,N=0;
     EX0 = 0;
delay(15);
if (IRIN==1)
     { EX0 =1;
  return;
  while (!IRIN)
    {delay(1);}
 for (j=0;j<4;j++)
  for (k=0;k<8;k++)
   while (IRIN)
     {delay(1);}
    while (!IRIN)
     {delay(1);}
     while (IRIN)
    delay(1);
    N++;
    if (N>=30)
{ EX0=1;
return;}
     IRCOM[j]=IRCOM[j] >> 1;
     if (N>=8) {IRCOM[j] = IRCOM[j] | 0x80;}
     N=0;
  }//end for k
 }//end for j
   if (IRCOM[2]!=~IRCOM[3])
   { EX0=1;
     return; }
   IRCOM[5]=IRCOM[2] & 0x0F;
   IRCOM[6]=IRCOM[2] >> 4;
   if(IRCOM[5]>9)
    { IRCOM[5]=IRCOM[5]+0x37;}
 IRCOM[5]=IRCOM[5]+0x30;
   if(IRCOM[6]>9)
    { IRCOM[6]=IRCOM[6]+0x37;}
 IRCOM[6]=IRCOM[6]+0x30;
switch(IRCOM[2])
  case 0x09: LED1=0;
 delay(250);
  LED1=1; break;
  case 0x15: LED2=0;
                 delay(250);
 LED2=1; break;
  case 0x07: LED3=0;
   delay(250);
 LED3=1; break;
  case 0x44: LED4=0;
   delay(250);
 LED4=1; break;
  case 0x40: LED5=0;
   delay(250);
 LED5=1; break;
  case 0x43: LED6=0;
                 delay(250);
 LED6=1 ;break;
          case 0x0D:  QIEHUAN=!QIEHUAN; break; //切换
 case 0x45:  OFF=!OFF; break; //静音
 case 0x47:  JINGYIN=!JINGYIN; break; //开关
    beep();
    EX0 = 1;
void beep(void)
  unsigned char i;
  for (i=0;i<100;i++)
   delay(4);
 BEEP=!BEEP;                 //BEEP取反
 BEEP=0;                      //关闭蜂鸣器
void delay(unsigned char x)
 unsigned char i;
  while(x--)
  for (i = 0; i<13; i++) {}
void delay1(int ms)
 unsigned char y;
  while(ms--)
  for(y = 0; y<250; y++)
   _nop_();
   _nop_();
   _nop_();
   _nop_();
152
197
197
2013-4-4
发表于 2013-4-22 11:54:26 | 显示全部楼层
切换之类的状态机的思想就可以了
~~~~ 欢迎讨论,拒绝谩骂 ~~~~
GMT+8, 2026-11-14 08:33
