查看: 8852|回复: 5
TFT显示出错!!!
40
100
100
2013-4-26
发表于 2013-5-22 20:06:41 | 显示全部楼层 |阅读模式
为什么从sd卡读取出来的图片在TFT显示是这样的,屏幕上怎会出现这么多白色的斜线,求大神指点啊~~~
这是SD卡操作:
#include <reg52.h>
#include <stdio.h>
#include<9325TP.h>
//定义SD卡需要的4根信号线
sbit SD_CLK = P1^7;
sbit SD_DI  = P1^5;
sbit SD_DO  = P1^6;
sbit SD_CS  = P1^0;
//定义按键端口
sbit KEY = P3^2;
//定义512字节缓冲区,注意需要使用 xdata关键字
unsigned char xdata DATA[512];
//写一字节到SD卡,模拟SPI总线方式
void SdWrite(unsigned char n)
unsigned char i;
for(i=8;i;i--)
SD_CLK=0;
SD_DI=(n&0x80);
n<<=1;
SD_CLK=1;
SD_DI=1;
//从SD卡读一字节,模拟SPI总线方式
unsigned char SdRead()
unsigned char n,i;
for(i=8;i;i--)
SD_CLK=0;
SD_CLK=1;
n<<=1;
if(SD_DO) n|=1;
return n;
//检测SD卡的响应
unsigned char SdResponse()
unsigned char i=0,response;
while(i<=8)
response = SdRead();
if(response==0x00)
break;
if(response==0x01)
break;
i++;
return response;
//发命令到SD卡
void SdCommand(unsigned char command, unsigned long argument, unsigned char CRC)
SdWrite(command|0x40);
SdWrite(((unsigned char *)&argument)[0]);
SdWrite(((unsigned char *)&argument)[1]);
SdWrite(((unsigned char *)&argument)[2]);
SdWrite(((unsigned char *)&argument)[3]);
SdWrite(CRC);
//初始化SD卡
unsigned char SdInit(void)
int delay=0, trials=0;
unsigned char i;
unsigned char response=0x01;
SD_CS=1;
for(i=0;i<=9;i++)
SdWrite(0xff);
SD_CS=0;
//Send Command 0 to put MMC in SPI mode
SdCommand(0x00,0,0x95);
response=SdResponse();
if(response!=0x01)
return 0;
while(response==0x01)
SD_CS=1;
SdWrite(0xff);
SD_CS=0;
SdCommand(0x01,0x00ffc000,0xff);
SD_CS=1;
SdWrite(0xff);
return 1;
//往SD卡指定地址写数据,一次最多512字节
unsigned char SdWriteBlock(unsigned char *Block, unsigned long address,int len)
unsigned int count;
unsigned char dataResp;
//Block size is 512 bytes exactly
//First Lower SS
SD_CS=0;
//Then send write command
SdCommand(0x18,address,0xff);
if(SdResponse()==00)
SdWrite(0xff);
SdWrite(0xff);
SdWrite(0xff);
//command was a success - now send data
//start with DATA TOKEN = 0xFE
SdWrite(0xfe);
//now send data
for(count=0;count<len;count++) SdWrite(*Block++);
for(;count<512;count++) SdWrite(0);
//data block sent - now send checksum
SdWrite(0xff); //两字节CRC校验, 为0XFFFF 表示不考虑CRC
SdWrite(0xff);
//Now read in the DATA RESPONSE token
dataResp=SdRead();
//Following the DATA RESPONSE token
//are a number of BUSY bytes
//a zero byte indicates the MMC is busy
while(SdRead()==0);
dataResp=dataResp&0x0f; //mask the high byte of the DATA RESPONSE token
SD_CS=1;
SdWrite(0xff);
if(dataResp==0x0b)
//printf("DATA WAS NOT ACCEPTED BY CARD -- CRC ERROR\n");
return 0;
if(dataResp==0x05)
return 1;
//printf("Invalid data Response token.\n");
return 0;
//printf("Command 0x18 (Write) was not received by the MMC.\n");
return 0;
//从SD卡指定地址读取数据,一次最多512字节
unsigned char SdReadBlock(unsigned char *Block, unsigned long address,int len)
unsigned int count;
//First Lower SS
 //printf("MMC_read_block\n");
SD_CS=0;
SdCommand(0x11,address,0xff);
while(SdRead()!=0xfe);
for(count=0;count<len;count++) *Block++=SdRead();
for(;count<512;count++) SdRead();
SdRead();
SdRead();
SD_CS=1;
SdRead();
return 1;
 //printf("Command 0x11 (Read) was not received by the MMC.\n");
return 0;
//主程序
main()
 unsigned int x,y; //定义液晶屏坐标
 unsigned long j;  //执行循环需要的临时变量
  unsigned int i;
  unsigned long AddTemp=262144;//SD卡地址第一个数据物理地址初始值,可以用winhex查看,这里是512扇区,512x512=262144,根据实际SD卡内容更改
  //CS=1;
delayms(25);
RES=0;
delayms(150);
RES=1;
delayms(25);
ILI9325_Initial();//液晶屏初始化
SdInit();         //SD卡初始化
 for(j=0;j<300;j++)   //300表示一幅图片含有300x512字节的信息
    SdReadBlock(DATA,AddTemp+(j*512),512);//每次读出512字节放到缓冲区
    for(i=0;i<256;i++)                    //然后写到液晶屏,可以显示256个像素,每个像素16位即2个字节
      LCD_SetPos(x,x,y,y);
      Write_Data(DATA[2*i+1],DATA[2*i]);
  x++;
  if(x==240)                         //检测是否写到屏的边缘 240x320
    y++;
    x=0;
    if(y==320)
      y=0;
     AddTemp = AddTemp+((j+20)*512);          //写完一幅图片后把SD地址加300x512到下一个图片地址
     while(KEY);                         //等待按键按下继续执行循环显示下一幅图片,如果没有按下则等待
这是9325TP.h
#include"reg52.h"
//根据芯片资料定义
#define WINDOW_XADDR_START 0x0050 // Horizontal Start Address Set
#define WINDOW_XADDR_END 0x0051 // Horizontal End Address Set
#define WINDOW_YADDR_START 0x0052 // Vertical Start Address Set
#define WINDOW_YADDR_END 0x0053 // Vertical End Address Set
#define GRAM_XADDR    0x0020 // GRAM Horizontal Address Set
#define GRAM_YADDR    0x0021 // GRAM Vertical Address Set
#define GRAMWR    0x0022 // memory write
//定义液晶屏接口
sbit CS=P2^1; //片选
sbit RES=P2^3; //复位
sbit RS=P2^4; //数据/命令选择
sbit RW=P2^5;
                    //数据口使用P0
//函数声明
void ILI9325_Initial(void);
void Write_Cmd_Data(unsigned char x, unsigned int y);
void Write_Cmd(unsigned char DH,unsigned char DL);
void Write_Data(unsigned char DH,unsigned char DL);
void delayms(unsigned int tt);
void Write_Data_U16(unsigned int y);
static void LCD_SetPos(unsigned int x0,unsigned int x1,unsigned int y0,unsigned int y1);
void ClearScreen(unsigned int bColor);
//清屏
 unsigned int i,j;
 LCD_SetPos(0,240,0,320);//320x240
 for (i=0;i<320;i++)
  for (j=0;j<240;j++)
      Write_Data_U16(bColor);
//写命令数据
void  Write_Cmd_Data (unsigned char x,unsigned int y)
unsigned char m,n;
m=y>>8;
n=y;
Write_Cmd(0x00,x);
Write_Data(m,n);
//写16位数据
unsigned char m,n;
m=y>>8;
n=y;
Write_Data(m,n);
//写命令
CS=0;
RS=0;
P0=DH;
RW=0;
RW=1;
P0=DL;
RW=0;
RW=1;
CS=1;
//写数据
CS=0;
RS=1;
P0=DH;
RW=0;
    RW=1;
P0=DL;
RW=0;
RW=1;
CS=1;
//延时程序
void delayms(unsigned int count)
    int i,j;
    for(i=0;i<count;i++)
    for(j=0;j<260;j++);
//液晶初始化
 delayms(50);                     //根据不同晶振速度可以调整延时,保障稳定显示
 Write_Cmd_Data(0x0001,0x0010);
 Write_Cmd_Data(0x0002,0x0700);
 Write_Cmd_Data(0x0003,0x0030);
 Write_Cmd_Data(0x0004,0x0000);
 Write_Cmd_Data(0x0008,0x0207);
 Write_Cmd_Data(0x0009,0x0000);
 Write_Cmd_Data(0x000A,0x0000);
 Write_Cmd_Data(0x000C,0x0000);
 Write_Cmd_Data(0x000D,0x0000);
 Write_Cmd_Data(0x000F,0x0000);
//power on sequence VGHVGL
 Write_Cmd_Data(0x0010,0x0000);
 Write_Cmd_Data(0x0011,0x0007);
 Write_Cmd_Data(0x0012,0x0000);
 Write_Cmd_Data(0x0013,0x0000);
//vgh
 Write_Cmd_Data(0x0010,0x1290);
 Write_Cmd_Data(0x0011,0x0227);
 delayms(100);
 //vregiout
 Write_Cmd_Data(0x0012,0x001d); //0x001b
 delayms(100);
 //vom amplitude
 Write_Cmd_Data(0x0013,0x1500);
 delayms(100);
 //vom H
 Write_Cmd_Data(0x0029,0x0018);
 Write_Cmd_Data(0x002B,0x000D);
//gamma
 Write_Cmd_Data(0x0030,0x0004);
 Write_Cmd_Data(0x0031,0x0307);
 Write_Cmd_Data(0x0032,0x0002);// 0006
 Write_Cmd_Data(0x0035,0x0206);
 Write_Cmd_Data(0x0036,0x0408);
 Write_Cmd_Data(0x0037,0x0507);
 Write_Cmd_Data(0x0038,0x0204);//0200
 Write_Cmd_Data(0x0039,0x0707);
 Write_Cmd_Data(0x003C,0x0405);// 0504
 Write_Cmd_Data(0x003D,0x0F02);
 //ram
 Write_Cmd_Data(0x0050,0x0000);
 Write_Cmd_Data(0x0051,0x00EF);
 Write_Cmd_Data(0x0052,0x0000);
 Write_Cmd_Data(0x0053,0x013F);
 Write_Cmd_Data(0x0060,0xA700);
 Write_Cmd_Data(0x0061,0x0001);
 Write_Cmd_Data(0x006A,0x0000);
 Write_Cmd_Data(0x0080,0x0000);
 Write_Cmd_Data(0x0081,0x0000);
 Write_Cmd_Data(0x0082,0x0000);
 Write_Cmd_Data(0x0083,0x0000);
 Write_Cmd_Data(0x0084,0x0000);
 Write_Cmd_Data(0x0085,0x0000);
 Write_Cmd_Data(0x0090,0x0010);
 Write_Cmd_Data(0x0092,0x0600);
 Write_Cmd_Data(0x0093,0x0003);
 Write_Cmd_Data(0x0095,0x0110);
 Write_Cmd_Data(0x0097,0x0000);
 Write_Cmd_Data(0x0098,0x0000);
 Write_Cmd_Data(0x0007,0x0133);
// Write_Cmd_Data(0x0022);//
//定义坐标
  Write_Cmd_Data(WINDOW_XADDR_START,x0);
  Write_Cmd_Data(WINDOW_XADDR_END,x1);
  Write_Cmd_Data(WINDOW_YADDR_START,y0);
  Write_Cmd_Data(WINDOW_YADDR_END,y1);
  Write_Cmd_Data(GRAM_XADDR,x0);
  Write_Cmd_Data(GRAM_YADDR,y0);
  Write_Cmd (0x00,0x22);//LCD_WriteCMD(GRAMWR);
I think: Impossible is equal that i'm possible!!!
发表于 2013-5-22 20:35:29 | 显示全部楼层
看起来像是某些数据没显示.
你的液晶驱动确定正常吧?比如清屏.
40
100
100
2013-4-26
 楼主| 发表于 2013-5-22 22:20:25 | 显示全部楼层
回复【2楼】正点原子:
清屏的没问题,我试了
40
100
100
2013-4-26
 楼主| 发表于 2013-5-23 16:05:13 | 显示全部楼层
回复【2楼】正点原子:
原子哥,你知道这是怎回事不,我都检查了好几遍了,还是不知哪错了
发表于 2013-5-23 18:00:40 | 显示全部楼层
那就是你解码哪里出问题了,呵呵.
47
47
2013-5-24
发表于 2013-5-24 20:08:19 | 显示全部楼层
我的也出现这个问题,特地进来求教
GMT+8, 2026-11-14 08:33
