查看: 6543|回复: 1
STM8S存储器的块写和字节写没区别呀!请看代码。
47
143
143
2012-7-12
发表于 2013-10-2 14:52:46 | 显示全部楼层 |阅读模式
  * @brief  Programs a memory block
  * @note   This function should be called and executed from RAM.
  * @param  FLASH_MemType : The type of memory to program
  * @param  BlockNum : The block number
  * @param  FLASH_ProgMode : The programming mode.
  * @param  Buffer : Pointer to buffer containing source data.
  * @retval None.
IN_RAM(void FLASH_ProgramBlock(uint16_t BlockNum, FLASH_MemType_TypeDef FLASH_MemType,
                        FLASH_ProgramMode_TypeDef FLASH_ProgMode, uint8_t *Buffer))
    uint16_t Count = 0;
    uint32_t startaddress = 0;
    /* Check parameters */
    assert_param(IS_MEMORY_TYPE_OK(FLASH_MemType));
    assert_param(IS_FLASH_PROGRAM_MODE_OK(FLASH_ProgMode));
    if (FLASH_MemType == FLASH_MEMTYPE_PROG)
        assert_param(IS_FLASH_PROG_BLOCK_NUMBER_OK(BlockNum));
        startaddress = FLASH_PROG_START_PHYSICAL_ADDRESS;
        assert_param(IS_FLASH_DATA_BLOCK_NUMBER_OK(BlockNum));
        startaddress = FLASH_DATA_START_PHYSICAL_ADDRESS;
    /* Point to the first block address */
    startaddress = startaddress + ((uint32_t)BlockNum * FLASH_BLOCK_SIZE);
    /* Selection of Standard or Fast programming mode */
    if (FLASH_ProgMode == FLASH_PROGRAMMODE_STANDARD)
        /* Standard programming mode */ /*No need in standard mode */
        FLASH->CR2 |= FLASH_CR2_PRG;
        FLASH->NCR2 &= (uint8_t)(~FLASH_NCR2_NPRG);
        /* Fast programming mode */
        FLASH->CR2 |= FLASH_CR2_FPRG;
        FLASH->NCR2 &= (uint8_t)(~FLASH_NCR2_NFPRG);
    /* Copy data bytes from RAM to FLASH memory */
    for (Count = 0; Count < FLASH_BLOCK_SIZE; Count++)
        *((PointerAttr uint8_t*) (uint16_t)startaddress + Count) = ((uint8_t)(Buffer[Count]));
这不还是字节写吗!?
47
143
143
2012-7-12
 楼主| 发表于 2013-10-2 15:15:58 | 显示全部楼层
没仔细看
这里是块相关
GMT+8, 2026-11-12 13:01
