查看: 10270|回复: 14
无外部IC\FLASH,不用SD卡显示汉字程序代码分享(汉字内码)
107
329
329
2013-5-12
26 小时
发表于 2013-10-6 05:25:50 | 显示全部楼层 |阅读模式
用了几个小时弄了个小程序,主要用于字数不多但型号字体变化较多的场合
效果如下
 typedef struct typFNT_GB16                 // 汉字字模数据结构
       unsigned char Index[2];               // 汉字内码索引
         char Msk[32];                       // 点阵码数据
// 汉字字模表                                                          //
// 汉字库: 宋体16.dot,逐列取模高位在前,数据排列:从左到右从上到下         //
const struct typFNT_GB16 codeGB_16[] =          // 数据表
"爱", 0x00,0x02,0x02,0x04,0x4D,0x05,0x69,0x09,0x59,0x32,0x49,0xE2,0x6F,0x54,0x59,0x54,
      0xC9,0x48,0x89,0x58,0x99,0x64,0xE9,0x44,0x89,0x02,0x09,0x03,0x0C,0x02,0x00,0x00,
"你", 0x01,0x00,0x02,0x00,0x0F,0xFE,0x34,0x00,0xC2,0x08,0x04,0x30,0x19,0xC0,0xF0,0x84,
      0x50,0x02,0x17,0xFC,0x10,0x00,0x11,0x00,0x14,0xC0,0x38,0x38,0x10,0x10,0x00,0x00,
"无", 0xFF,0xFD,0xFD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xDF,0xBD,0x3F,0x80,0xFF,
      0xBC,0x03,0xBD,0xFD,0xBD,0xFD,0xBD,0xFD,0xBD,0xFD,0xBD,0xFD,0xFD,0xF1,0xFF,0xFF,
"线", 0xFD,0xFB,0xF9,0xBB,0xE5,0x3B,0x1C,0xB7,0xB9,0xB7,0xFF,0xB7,0xF6,0xFB,0xF6,0xFB,
      0xF6,0xF7,0x00,0x37,0xF6,0xCF,0xB6,0xD7,0xC6,0xBB,0xD6,0xFD,0xFE,0xE0,0xFF,0xFF,
"站", 0xF7,0xF7,0xF5,0xF7,0xB6,0x2F,0xC7,0xCF,0xF7,0x2F,0xF0,0xEF,0xF7,0xFF,0xFF,0x01,
      0xFF,0x7B,0xFF,0x7B,0x00,0x7B,0xF7,0x7B,0xF7,0x7B,0xF7,0x01,0xF7,0xFF,0xFF,0xFF,
"标", 0xF7,0xDF,0xF7,0x3F,0xF4,0xFF,0x00,0x00,0xF5,0xFF,0xF6,0x6F,0xFB,0xDF,0xBB,0x3F,
      0xBB,0xFD,0xBB,0xFE,0xB8,0x01,0xBB,0xFF,0xBB,0x7F,0xBB,0x9F,0xFB,0xC7,0xFF,0xFF,
//显示一个汉字
void LCD_GB1616(u16 x,u16 y,u8 font[2],u8 size)
    u8 y0=y;
 u16 tempcolor;
 u8 temp;
    unsigned int i,j,k;
    for (k=0;k<70;k++)
     if ((codeGB_16[k].Index[0]==font[0])&&(codeGB_16[k].Index[1]==font[1]))
      for(i=0;i<size*2;i++)
       temp=codeGB_16[k].Msk;
       for(j=0;j<8;j++)
        if(temp&0x80)LCD_DrawPoint(x,y);
   tempcolor=POINT_COLOR;
   POINT_COLOR=BACK_COLOR;
   LCD_DrawPoint(x,y);
         POINT_COLOR=tempcolor;//还原
         temp<<=1;
      y++;
   if((y-y0)==size)
    y=y0;
    x++;
    break;
 void Show_Str(u16 x,u16 y,u16 width,u16 height,u8*str,u8 size)
 u16 x0=x;
 u16 y0=y;
    u8 bHz=0;     //字符或者中文
    while(*str!=0)//数据未结束
        if(!bHz)
         if(*str>0x80)bHz=1;//中文
         else              //字符
                if(x>(x0+width-size/2))//换行
     y+=size;
     x=x0;
          if(y>(y0+height-size))break;//越界返回
          if(*str==13)//换行符号
              y+=size;
     x=x0;
              str++;
          else LCD_ShowChar(x,y,*str,size,0);//有效部分写入
    str++;
          x+=size/2; //字符,为全字的一半
        }else//中文
            bHz=0;//有汉字库
            if(x>(x0+width-size))//换行
    y+=size;
    x=x0;
         LCD_GB1616(x,y,str,size); //显示这个汉字,空心显示
         str+=2;
         x+=size;//下一个汉字偏移
107
329
329
2013-5-12
26 小时
 楼主| 发表于 2013-10-6 05:26:27 | 显示全部楼层
Show_Str(80,80,200,16,"爱你标a站无7线无无无无",16);
发表于 2013-10-6 10:55:57 | 显示全部楼层
谢谢分享
23
23
2013-10-7
发表于 2013-10-7 21:16:44 | 显示全部楼层
107
329
329
2013-5-12
26 小时
 楼主| 发表于 2013-10-7 23:42:48 | 显示全部楼层
 //显示一个汉字-16
void LCD_GB1616(u16 x,u16 y,u8 font[2],u8 size,u8 mode)
    u16 y0=y;
 u16 tempcolor=POINT_COLOR;
 u8  temp;
    unsigned int i,j,k;
    if(mode==0)
     for (k=0;k<70;k++)
        for(j=0;j<8;j++)
         if((temp&0x80)&&(mode==0)) POINT_COLOR=BACK_COLOR;
   else POINT_COLOR=tempcolor;
    LCD_DrawPoint(x,y);
          temp<<=1;
       y++;
   if((y-y0)==size)
    y=y0;
    x++;
    break;
    for (k=0;k<70;k++)
       for(j=0;j<8;j++)
        if((temp&0x80)&&(mode==1)) POINT_COLOR=tempcolor;
  else POINT_COLOR=BACK_COLOR;
   LCD_DrawPoint(x,y);
         temp<<=1;
      y++;
   if((y-y0)==size)
    y=y0;
    x++;
    break;
MODE==1
Show_Str(80,100,200,14,"无8线a无",14,1);
MODE==0
Show_Str(80,100,200,14,"无8线a无",14,0);
46
1571
1970
1970
2011-7-17
发表于 2013-10-8 08:37:31 | 显示全部楼层
你这方法我早在AVR时代用过了,我还以为你说的是不用外部IC和FLASH甚至SD卡,直接根据汉字GBK码,来用算法算出字体的点阵来,然后显示,如果真这么牛×,此贴可以申酷了。
Time?And?Relative?Dimension?In?Space.
76
265
265
2013-9-5
31 小时
发表于 2014-4-25 23:16:11 | 显示全部楼层
谢谢分享
41
224
224
2014-9-2
发表于 2015-4-9 20:39:39 | 显示全部楼层
回复【2楼】龙胜阳子:
大神,我最近在做显示汉字,把你的代码添加到ALIENTEK MINISTM32 实验11 TFT液晶显示实验里,怎么不显示?求解,谢谢
趁着年轻,追逐自己所爱的----单片机&&足球!
129
129
2015-6-22
30 小时
发表于 2016-4-11 15:19:28 | 显示全部楼层
怎么直接复制你的代码会报错的,,,main.c(53): error:  #513: a value of type "const char *" cannot be assigned to an entity of type "u16"
2017-5-2
11 小时
发表于 2017-5-2 21:59:23 | 显示全部楼层
struct typFNT_GB16
u8 Msk[32];
const struct typFNT_GB16 codeGB_16[] =// ???
"°&reg;", 0x00,0x02,0x02,0x04,0x4D,0x05,0x69,0x09,0x59,0x32,0x49,0xE2,0x6F,0x54,0x59,0x54,
"&Auml;&atilde;", 0x01,0x00,0x02,0x00,0x0F,0xFE,0x34,0x00,0xC2,0x08,0x04,0x30,0x19,0xC0,0xF0,0x84,
"&Icirc;&THORN;", 0xFF,0xFD,0xFD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xDF,0xBD,0x3F,0x80,0xFF,
"&Iuml;&szlig;", 0xFD,0xFB,0xF9,0xBB,0xE5,0x3B,0x1C,0xB7,0xB9,0xB7,0xFF,0xB7,0xF6,0xFB,0xF6,0xFB,
"&Otilde;&frac34;", 0xF7,0xF7,0xF5,0xF7,0xB6,0x2F,0xC7,0xCF,0xF7,0x2F,0xF0,0xEF,0xF7,0xFF,0xFF,0x01,
"±ê", 0xF7,0xDF,0xF7,0x3F,0xF4,0xFF,0x00,0x00,0xF5,0xFF,0xF6,0x6F,0xFB,0xDF,0xBB,0x3F,
u16 y0=y;
u8 temp;
  unsigned int i,j,k;
   if(mode==0)
   for (k=0;k<70;k++)
                        temp=codeGB_16[k].Msk[i];
     for(j=0;j<8;j++)
   LCD_DrawPoint(x,y);
      temp<<=1;
    y++;
  if((y-y0)==size)
   y=y0;
   x++;
   break;
   for (k=0;k<70;k++)
    for(j=0;j<8;j++)
  LCD_DrawPoint(x,y);
     temp<<=1;
    y++;
  if((y-y0)==size)
   y=y0;
   x++;
   break;
u16 x0=x;
u16 y0=y;
    u8 bHz=0;     //??????
    while(*str!=0)//?????
        if(!bHz)
         if(*str>0x80)bHz=1;//??
         else              //??
                if(x>(x0+width-size/2))//??
     y+=size;
     x=x0;
          if(y>(y0+height-size))break;//????
          if(*str==13)//????
              y+=size;
     x=x0;
              str++;
          else LCD_ShowChar(x,y,*str,size,0);//??????
    str++;
          x+=size/2; //??,??????
        }else//??
            bHz=0;//????
            if(x>(x0+width-size))//??
    y+=size;
    x=x0;
         LCD_GB1616(x,y,str,size,0);//??????,????
         str+=2;
         x+=size;//???????
改了下楼主的,不会报错了
2017-5-2
11 小时
发表于 2017-5-2 22:00:41 | 显示全部楼层
字数组跟楼主是一样的,不知道为什么我发出来乱码了
66
3341
3341
2016-11-9
298 小时
发表于 2017-5-3 00:01:55 | 显示全部楼层
学习了,厉害.....
181
181
2017-7-24
48 小时
发表于 2017-7-27 09:36:40 | 显示全部楼层
赞,先保存
79
421
421
2017-6-12
88 小时
发表于 2017-9-16 17:17:34 | 显示全部楼层
瑞克和莫蒂 发表于 2017-5-2 21:59
struct typFNT_GB16
  for (k=0;k<70;k++) 为什么循环70啊?
79
421
421
2017-6-12
88 小时
发表于 2017-9-16 17:29:54 | 显示全部楼层
struct typFNT_GB16
取模软件如何设置的啊?
GMT+8, 2026-10-31 11:38
