查看: 4975|回复: 2
stm32在中断里改变频率 怎么没有反应。程序以及进入中断,应该是定时器配置有问题,麻烦大佬帮忙看一下
2017-9-9
发表于 2017-9-11 09:29:55 | 显示全部楼层 |阅读模式
#include "timer.h"
#include "led.h"
#include "usart.h"
unsigned int capture1=0;
extern unsigned int CCR1_Val=17535;
void TIM3_PWM_Init(void)
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);        //使能定时器3时钟
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB  | RCC_APB2Periph_AFIO, ENABLE);  //使能GPIO外设和AFIO复用功能模块时钟
        GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE); //Timer3部分重映射  TIM3_CH2->PB5
  //设置该引脚为复用输出功能,输出TIM3 CH2的PWM脉冲波形        GPIOB.5
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //TIM_CH2
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //复用推挽输出
        GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIO
        NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;  //TIM3中断
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //先占优先级0级
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;  //从优先级3级
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
        NVIC_Init(&NVIC_InitStructure);  //根据NVIC_InitStruct中指定的参数初始化外设NVIC寄存器
  //初始化TIM3
        TIM_TimeBaseStructure.TIM_Period = 65535; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值
        TIM_TimeBaseStructure.TIM_Prescaler =2; //设置用来作为TIMx时钟频率除数的预分频值
        TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
//TIM_PrescalerConfig(TIM3,199,TIM_PSCReloadMode_Immediate);
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
//初始化TIM3 Channel2 PWM模式
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Toggle; //选择定时器模式:TIM脉冲宽度调制模式2
        ////TIM_OCInitStructure.TIM_chan=
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //正向通道有效
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;//反向通道无效
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //输出极性:TIM输出比较极性高
        TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;    //互补端的极性
        TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
        TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
        TIM_OCInitStructure.TIM_OutputNState=ENABLE;
        TIM_OCInitStructure.TIM_Pulse=CCR1_Val; //设置待装入捕获比较寄存器的脉冲值
        TIM_OC2Init(TIM3, &TIM_OCInitStructure);  //根据T指定的参数初始化外设TIM3 OC2
         /////TIM_ARRPreloadConfig( TIM3, DISABLE );
        TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Disable);  //失能TIM3在CCR2上的预装载寄存器
        TIM_ITConfig(TIM3,TIM_IT_CC2,ENABLE );
        TIM_Cmd(TIM3, ENABLE);  //使能TIM3
void TIM3_IRQHandler(void)   //TIM3中断
{   u16 capture;
        if (TIM_GetITStatus(TIM3, TIM_IT_CC2) != RESET) //检查指定的TIM中断发生与否:TIM 中断源
                ///GPIO_WriteBit(GPIOB,GPIO_Pin_5,(BitAction)(1-GPIO_ReadOutputDataBit(GPIOB,GPIO_Pin_5)));
                ///capture=TIM_GetCapture2(TIM3);
                //TIM_SetCompare2(TIM2, capture+CCR1_Val);
                // TIM_SetIC2Prescaler(TIM3,899);
         TIM_PrescalerConfig( TIM3, CCR1_Val, TIM_PSCReloadMode_Update) ;//改变TIM_Prescaler,改变频率
         TIM_ClearITPendingBit(TIM3, TIM_IT_CC2 );  //清除TIMx的中断待处理位:TIM 中断源
68
176
176
2016-9-20
56 小时
发表于 2017-9-11 10:10:25 | 显示全部楼层
 TIM_PrescalerConfig( TIM3, CCR1_Val, TIM_PSCReloadMode_Update) ;//改变TIM_Prescaler,改变频率   这个函数贴出来看看
发表于 2017-9-12 01:21:43 | 显示全部楼层
仿真找问题
GMT+8, 2026-10-31 10:53
