查看: 8630|回复: 2
指纹识别模块AS608,串口2 收不到数据
47
47
2016-7-12
14 小时
发表于 2017-9-12 21:42:12 | 显示全部楼层 |阅读模式
最近买了一个AS608指纹识别模块 ,看了一下原子哥的源代码, 原子哥的串口2通信 用的是定时检测一帧数据 ,有点看不懂 , 然后在网上查了下资料, 用 串口空闲中断可以解决接受一帧不定长数据, 所以我就用了这种方法, 开发板是探索者的, 但是现在无法正常通信 , 有哪位大神帮忙看下,如果解决了,发个50红包给你, 说到做到
串口相关代码如下
#include "myusart.h"
void Usart2_Init(void)
        GPIO_InitTypeDef        GPIO_InitStructure;
        USART_InitTypeDef     USART_InitStructure;
        NVIC_InitTypeDef        NVIC_InitStructure;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA,ENABLE);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
                //USRT2对应引脚复用映射
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource2,GPIO_AF_USART1);
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource3,GPIO_AF_USART1);
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; -
        GPIO_Init(GPIOA,&GPIO_InitStructure);
                //USART2初始化配置
        USART_InitStructure.USART_BaudRate = 56700;
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        USART_InitStructure.USART_Parity = USART_Parity_No;
        USART_InitStructure.USART_StopBits = USART_StopBits_1;
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;
        USART_Init(USART2,&USART_InitStructure);
       //使能USART2
     USART_Cmd(USART2,ENABLE);
         USART_ITConfig(USART2,USART_IT_RXNE,ENABLE); // 开启接收非空中断
          USART_ITConfig(USART2,USART_IT_IDLE,ENABLE); // 开启接受空闲中断
   //USART1 NVIC 配置
   NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn; // 串口2中断通道
   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; // 抢占优先级
   NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0 ; // 响应优先级
   NVIC_InitStructure.NVIC_IRQChannelCmd  = ENABLE; // IRQ通道使能
extern uint8_t  aRxBuffer[100];
extern uint8_t RxCounter ;
extern uint8_t ReceiveState;
void USART2_IRQHandler(void)
     u8 clear = clear;
                                if(USART_GetFlagStatus(USART2,USART_IT_RXNE) != RESET) //如果接受到一个字节
                                     aRxBuffer[RxCounter++]= USART_ReceiveData(USART2);
                    else if(USART_GetFlagStatus(USART2,USART_IT_IDLE) != RESET) //如果接收到一帧数据
                            clear = USART2->SR ; // 读SR寄存器
                                clear = USART2->DR; // 读DR寄存器 (先读SR再DR,就是为了清除IDLE中断标志位)
                                ReceiveState = 1;        // 标记接受到一帧数据
#include "as608.h"
#include "stm32f4xx.h"
#include "string.h"
#include "delay.h"
//发送一个字节
static void MYUSART2_SendData(u8 data)
      USART_SendData(USART2,data);
        while(USART_GetFlagStatus(USART2,USART_FLAG_TXE) == RESET);
//发送一个包头
static void SendHead(void)
        MYUSART2_SendData(0xEF);
        MYUSART2_SendData(0x01);
//读取一帧数据
void MYUSART2_GetFrameData(void)
          u8 i;
      if(ReceiveState == 1)
               ReceiveState = 0; // 见标志位清零
            for(i = 0; i < RxCounter; i++)
                  ACK_data = aRxBuffer;
              RxCounter = 0; //
//与AS608 模块握手函数
u8 PS_HandShake(u32 *PS_Addr)
        int i, j;
        SendHead();
        SendAddr();
        MYUSART2_SendData(0X01);
        MYUSART2_SendData(0X00);
   delay_ms(200);
        MYUSART2_GetFrameData();
        if(ACK_data[0] == 0xEF && ACK_data[1] == 0x01 && ACK_data[6] == 0x07)
                        *PS_Addr=(ACK_data[2]<<24) + (ACK_data[3]<<16)+(ACK_data[4]<<8) + (ACK_data[5]);
                     return 1;  //握手成功返回1
        return 0;
#include "delay.h"
#include "as608.h"
#include "led.h"
volatile uint8_t aRxBuffer[100] = {0x00}; // 接受缓存数据
volatile uint8_t RxCounter  = 0;
volatile uint8_t ReceiveState = 0 ; //接收一帧数据标志位
int main(void)
           uint8_t i;
           delay_init(168);
       Usart_Init(115200);
           Usart2_Init();
           LED_Init();
       delay_ms(200);
                   if(PS_HandShake(&AS608Addr))
                                   printf("握手成功\n");
                                 printf("握手失败\n");
203
2447
2447
2017-9-13
559 小时
发表于 2017-9-13 14:53:01 | 显示全部楼层
看看!!
448
1755
1755
2015-2-7
369 小时
发表于 2017-9-13 22:12:30 来自手机 | 显示全部楼层
使用空闲中断接收,需在每发送一条指令后马上开启中断,当接收完一帧数据后立即关闭中断
GMT+8, 2026-10-31 11:23
