查看: 7020|回复: 4
使用TIM1定时器通道1互补输出
261
261
2017-8-30
63 小时
发表于 2017-9-18 16:49:29 | 显示全部楼层 |阅读模式
2金钱
程序下载到开发板后PA8会有个高电平输出,而PB13为低电平,希望都为低电平(或高电平),是F407的板子
void MotorDriver_Init(u32 arr,u32 psc)
        GPIO_InitTypeDef                GPIO_InitStructure;
        TIM_TimeBaseInitTypeDef   TIM_TimeBaseInitStructure;
        TIM_OCInitTypeDef         TIM_OCInitStructure;
        TIM_BDTRInitTypeDef       TIM_BDTRInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); //ê1ÄüTIM1ê±Öó
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA|RCC_AHB1Periph_GPIOB,ENABLE); //ê1ÄüGPIOA,Bê±Öó
        GPIO_PinAFConfig(GPIOA,GPIO_PinSource8,GPIO_AF_TIM1); //GPIOA8¸′óÃÎa¶¨ê±Æ÷1
        GPIO_PinAFConfig(GPIOB,GPIO_PinSource13,GPIO_AF_TIM1);//GPIOB13¸′óÃÎa¶¨ê±Æ÷1
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//¸′óÃ1|Äü
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//íÆíìêä3ö
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100M
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//éÏà-
        GPIO_Init(GPIOA, &GPIO_InitStructure);//3õê¼»ˉGPIOA8
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
        GPIO_Init(GPIOB, &GPIO_InitStructure);//3õê¼»ˉGPIOB13
        GPIO_SetBits(GPIOA, GPIO_Pin_8);
        GPIO_SetBits(GPIOB, GPIO_Pin_13);
        TIM_TimeBaseInitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
        TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInitStructure.TIM_Period = arr;
        TIM_TimeBaseInitStructure.TIM_Prescaler = psc;
        TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStructure);
        TIM_TimeBaseStructInit(&TIM_TimeBaseInitStructure);
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
        TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
        TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
        TIM_OCInitStructure.TIM_OCNIdleState =TIM_OCNIdleState_Reset;
        TIM_OC1Init(TIM1,&TIM_OCInitStructure);
        TIM_OC2Init(TIM1,&TIM_OCInitStructure);
        TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);  //CH1Ô¤×°ÔØê1Äü
        TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);  //CH1NÔ¤×°ÔØê1Äü
        TIM_ARRPreloadConfig(TIM1, ENABLE); //ê1ÄüTIM1ÔúARRéÏμÄÔ¤×°ÔØ¼Ä′æÆ÷
        TIM_Cmd(TIM1, ENABLE);  //ê1ÄüTIM1
        TIM_CtrlPWMOutputs(TIM1,ENABLE);
//ËàÇøê±¼äéèÖÃ
//DT=(64+DTG)*Tdtg,Tdtg=2*TDTS
//DTËàÇøê±¼ä,TDTSÏμí3ê±ÖóÖüÆúê±3¤,TdtgÏμí3ê±ÖóÖüÆúê±3¤3ËòÔ±¶êyoóμÄËàÇøéèÖÃê±¼ä2½½øÖμ
        TIM_BDTRStructInit(&TIM_BDTRInitStructure);
        TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
        TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;
        TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;
        TIM_BDTRInitStructure.TIM_DeadTime = 0xE0;    //3usêÇ0xE0,1usêÇ0x94
        TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
        TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;
        TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
IO看数据手册,不同定时器,不同通道,分配的IO在数据手册里面都有
发表于 2017-9-18 16:49:30 | 显示全部楼层
eric1993 发表于 2017-9-19 22:39
我的意思是在初始化后两个引脚输出一样的电平,我用TIM8的通道1互补输出都可以,是不是和开发板的引脚定 ...
261
261
2017-8-30
63 小时
 楼主| 发表于 2017-9-18 16:53:26 | 显示全部楼层
求大神指教入和输出相同电平
发表于 2017-9-19 00:02:32 | 显示全部楼层
261
261
2017-8-30
63 小时
 楼主| 发表于 2017-9-19 22:39:12 | 显示全部楼层
正点原子 发表于 2017-9-19 00:02
直接一个IO接2根线出来就得了
我的意思是在初始化后两个引脚输出一样的电平,我用TIM8的通道1互补输出都可以,是不是和开发板的引脚定义有关,如果是的话,该如何操作
GMT+8, 2026-10-31 12:09
