查看: 6810|回复: 2
DDS AD9850驱动 串口+并口
54
536
798
798
2012-2-27
发表于 2013-10-22 14:56:31 | 显示全部楼层 |阅读模式
 * AD9850.h
 *  Created on: 2013-7-12
 *      Author: Allen
#ifndef AD9850_H_
#define AD9850_H_
#include  <MSP430G2553.h>
#include "MyType.h"
//AD9850:W_CLK P2.5
#define  AD9850_W_CLK_DIR   (P2DIR)
#define  AD9850_W_CLK_OUT   (P2OUT)
#define  AD9850_W_CLK_PIN_NUM  (BIT5)
#define  AD9850_W_CLK_IO_INIT  (Set_Bit(P2DIR,AD9850_W_CLK_PIN_NUM))
#define  AD9850_W_CLK_H       (Set_Bit(P2OUT,AD9850_W_CLK_PIN_NUM))
#define  AD9850_W_CLK_L       (Clr_Bit(P2OUT,AD9850_W_CLK_PIN_NUM))
//AD9850:FQ_UP P2.4
#define  AD9850_FQ_UP_DIR   (P2DIR)
#define  AD9850_FQ_UP_OUT   (P2OUT)
#define  AD9850_FQ_UP_PIN_NUM  (BIT4)
#define  AD9850_FQ_UP_IO_INIT  (Set_Bit(P2DIR,AD9850_FQ_UP_PIN_NUM))
#define  AD9850_FQ_UP_H       (Set_Bit(P2OUT,AD9850_FQ_UP_PIN_NUM))
#define  AD9850_FQ_UP_L       (Clr_Bit(P2OUT,AD9850_FQ_UP_PIN_NUM))
//AD9850:RESET P2.3
#define  AD9850_RESET_DIR   (P2DIR)
#define  AD9850_RESET_OUT   (P2OUT)
#define  AD9850_RESET_PIN_NUM  (BIT3)
#define  AD9850_RESET_IO_INIT  (Set_Bit(P2DIR,AD9850_RESET_PIN_NUM))
#define  AD9850_RESET_H       (Set_Bit(P2OUT,AD9850_RESET_PIN_NUM))
#define  AD9850_RESET_L       (Clr_Bit(P2OUT,AD9850_RESET_PIN_NUM))
//AD9850:BIT_DATA P1.7
#define  AD9850_BIT_DATA_DIR   (P1DIR)
#define  AD9850_BIT_DATA_OUT   (P1OUT)
#define  AD9850_BIT_DATA_PIN_NUM  (BIT7)
#define  AD9850_BIT_DATA_IO_INIT  (Set_Bit(P1DIR,AD9850_BIT_DATA_PIN_NUM))
#define  AD9850_BIT_DATA_H   (Set_Bit(P1OUT,AD9850_BIT_DATA_PIN_NUM))
#define  AD9850_BIT_DATA_L   (Clr_Bit(P1OUT,AD9850_BIT_DATA_PIN_NUM))
extern void AD9850_INIT_SERIAL(void);
extern void AD9850_RESET_SERIAL(void);
extern void AD9850_WR_SERIAL(unsigned char w0,double frequence);
extern void AD9850_INIT_PARREL(void);
extern void AD9850_RESET_PARREL(void);
extern void AD9850_WR_PARREL(unsigned char w0,double frequence);
#endif /* LED_H_ */
 * AD9850.c
 *  Created on: 2013-10-15
 *      Author: Allen
#include "AD9850.h"
 AD9850_W_CLK_IO_INIT;
 AD9850_FQ_UP_IO_INIT;
 AD9850_RESET_IO_INIT;
 AD9850_BIT_DATA_IO_INIT;
 AD9850_W_CLK_L;
 AD9850_FQ_UP_L;
    //rest信号
 AD9850_RESET_L;
    AD9850_RESET_H;
    AD9850_RESET_L;
    //w_clk信号
    AD9850_W_CLK_L;
    AD9850_W_CLK_H;
    AD9850_W_CLK_L;
    //fq_up信号
    AD9850_FQ_UP_L;
    AD9850_FQ_UP_H;
    AD9850_FQ_UP_L;
 unsigned char i,w;
 long int y;
 double x;
 //计算频率的HEX值
 x=4294967295/20;//适合125M晶振
 //如果时钟频率不为20MHZ,修改该处的频率值,单位MHz  !!!
 frequence=frequence/1000000;
 frequence=frequence*x;
 y=frequence;
 //写w4数据
 w=(y>>=0);
 for(i=0;i<8;i++)
//    ad9850_bit_data=(w>>i)&0x01;
    if((w>>i)&0x01)
      AD9850_BIT_DATA_H;
      AD9850_BIT_DATA_L;
    AD9850_W_CLK_H;
    AD9850_W_CLK_L;
 //写w3数据
 w=(y>>8);
 for(i=0;i<8;i++)
     if((w>>i)&0x01)
    AD9850_BIT_DATA_H;
    AD9850_BIT_DATA_L;
     AD9850_W_CLK_H;
     AD9850_W_CLK_L;
 //写w2数据
 w=(y>>16);
 for(i=0;i<8;i++)
     if((w>>i)&0x01)
    AD9850_BIT_DATA_H;
    AD9850_BIT_DATA_L;
     AD9850_W_CLK_H;
     AD9850_W_CLK_L;
 //写w1数据
 w=(y>>24);
 for(i=0;i<8;i++)
     if((w>>i)&0x01)
    AD9850_BIT_DATA_H;
    AD9850_BIT_DATA_L;
     AD9850_W_CLK_H;
     AD9850_W_CLK_L;
 //写w0数据
 w=w0;
 for(i=0;i<8;i++)
     if((w>>i)&0x01)
    AD9850_BIT_DATA_H;
    AD9850_BIT_DATA_L;
     AD9850_W_CLK_H;
     AD9850_W_CLK_L;
 //移入始能
 AD9850_FQ_UP_H;
 AD9850_FQ_UP_L;
 1DIR=0xff;
 AD9850_W_CLK_L;
 AD9850_FQ_UP_L;
 //rest信号
 AD9850_RESET_L;
 AD9850_RESET_H;
 AD9850_RESET_L;
 unsigned char w;
 long int y;
 double x;
 //计算频率的HEX值
 x=4294967295/20;//适合20M晶振
 y=frequence;
 //写w0数据
 w=w0;
 1OUT=w;      //w0
 AD9850_W_CLK_H;
 AD9850_W_CLK_L;
 //写w1数据
 w=(y>>24);
 1OUT=w;      //w1
 AD9850_W_CLK_H;
 AD9850_W_CLK_L;
 //写w2数据
 w=(y>>16);
 1OUT=w;      //w2
 AD9850_W_CLK_H;
 AD9850_W_CLK_L;
 //写w3数据
 w=(y>>8);
 1OUT=w;      //w3
 AD9850_W_CLK_H;
 AD9850_W_CLK_L;
 //写w4数据
 w=(y>>0);
 1OUT=w;      //w4
 AD9850_W_CLK_H;
 AD9850_W_CLK_L;
 //移入始能
 AD9850_FQ_UP_H;
 AD9850_FQ_UP_L;
165779
165779
发表于 2013-10-22 16:24:37 | 显示全部楼层
谢谢分享
543
543
2013-8-22
40 小时
发表于 2017-1-3 14:09:59 | 显示全部楼层
楼主发帖辛苦了,谢谢分享!!!!!!!
GMT+8, 2026-10-24 12:07
