楼主: lifan_cn
分享PWM输入模式捕捉4路PWM波形的周期和占空比 源码+原理讲解+程序讲解
360
360
2012-11-21
62 小时
发表于 2016-7-26 10:48:51 | 显示全部楼层
这个程序确实好用,必须精华贴。用TIM2_CH1的程序如下,测试1K,2K,3K信号占空比准确,
占空比是IC2 捕获,周期是IC1捕获,这块注意一下就行,还有前2到3次测量结果不准确要抛弃。
//----------------------PWM输入模式配置--------------------------------------------------
void TIM2_PWMINPUT_INIT(u16 arr,u16 psc)
        TIM_ICInitTypeDef  TIM2_ICInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
//        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;               //PB7:TIM4_CH2
//  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
//  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
//  GPIO_Init(GPIOB, &GPIO_InitStructure);
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;                 //PA0: TIM2_CH1
        TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值
        TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值
        TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
        TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
//        TIM4_ICInitStructure.TIM_Channel = TIM_Channel_2;
//  TIM4_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
//  TIM4_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
//  TIM4_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
//        TIM4_ICInitStructure.TIM_ICFilter = 0x0;
//初始化TIM2输入捕获参数
        TIM2_ICInitStructure.TIM_Channel = TIM_Channel_1; //CC1S=01         选择输入端 IC1映射到TI1上
        TIM2_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;        //上升沿捕获
        TIM2_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI1上
        TIM2_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;         //配置输入分频,不分频
        TIM2_ICInitStructure.TIM_ICFilter = 0x00;//IC1F=0000 配置输入滤波器 不滤波
        TIM_ICInit(TIM2, &TIM2_ICInitStructure);
/*配置中断优先级*/
        NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
//        TIM_PWMIConfig(TIM4, &TIM4_ICInitStructure);     //PWM输入配置
//  这个是选择有效的输入端 ,我这里TIM_TS_TI2FP2选择的PB7,注意:只有TI1FP1和TI2FP2连到了从模式控制器,所以PWM输入模式只能使用TIMx_CH1 /TIMx_CH2信号
//  TIM_SelectInputTrigger(TIM4, TIM_TS_TI2FP2);     //选择有效输入端
//  这个是配置为PWM输入主从复位模式,就是每次输入端有效电平变化的时候定时器计数器就会硬件上置0
//  TIM_SelectSlaveMode(TIM4, TIM_SlaveMode_Reset);  //配置为主从复位模式
//  TIM_SelectMasterSlaveMode(TIM4, TIM_MasterSlaveMode_Enable);
//  TIM_ITConfig(TIM4, TIM_IT_CC2|TIM_IT_Update, ENABLE);          //中断配置
//        TIM_ClearITPendingBit(TIM4, TIM_IT_CC2|TIM_IT_Update); //清除中断标志位
//        TIM_Cmd(TIM4, ENABLE);
  TIM_PWMIConfig(TIM2, &TIM2_ICInitStructure);     //PWM输入配置
  TIM_SelectInputTrigger(TIM2, TIM_TS_TI1FP1);     //选择有效输入端
  TIM_SelectSlaveMode(TIM2, TIM_SlaveMode_Reset);  //配置为主从复位模式
  TIM_SelectMasterSlaveMode(TIM2, TIM_MasterSlaveMode_Enable);
  TIM_ITConfig(TIM2, TIM_IT_CC1|TIM_IT_Update, ENABLE);   //中断配置
        TIM_ClearITPendingBit(TIM2, TIM_IT_CC1|TIM_IT_Update); //允许更新中断 ,允许CC1IE捕获中断
        TIM_Cmd(TIM2, ENABLE);
u16 period = 0;
u16 DUTY  = 0;
u8 CollectFlag = 1;
void TIM2_IRQHandler(void)
        if(CollectFlag)
        if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)//捕获1发生捕获事件
                        period = TIM_GetCapture1(TIM2);          //采集周期
                  DUTY         =        TIM_GetCapture2(TIM2);     //采集占空比
                CollectFlag = 0;
                TIM_ClearITPendingBit(TIM2, TIM_IT_CC1|TIM_IT_Update); //清除中断标志位
360
360
2012-11-21
62 小时
发表于 2016-7-26 10:49:03 | 显示全部楼层
//初始化TIM2输入捕获参数
/*配置中断优先级*/
u16 period = 0;
u16 DUTY  = 0;
u8 CollectFlag = 1;
        if(CollectFlag)
                CollectFlag = 0;
176
1106
1106
2015-10-27
206 小时
发表于 2016-7-27 11:05:15 | 显示全部楼层
楼主的程序,设置的是TIM3,占空比也设置的是TIM3的,为什么中断函数里面是TIM4中断采集TIM4的占空比,从程序看,好像并没有设置TIM4的占空比,是如何用串口输出的
61
274
274
2016-7-15
88 小时
发表于 2016-7-27 11:53:58 | 显示全部楼层
50
50
2014-6-13
发表于 2016-7-27 17:47:47 | 显示全部楼层
好资料,谢谢分享。。。。
102
102
2013-7-25
23 小时
发表于 2016-7-28 13:46:02 | 显示全部楼层
谢谢
2016-7-30
发表于 2016-7-30 00:24:49 | 显示全部楼层
你好,我学习了下这个程序。。。很好,很佩服。但是TIM4测量低频的时候,我修改了加上溢出还是不行。能帮我修改下能够测量低频信号吗新手祈求修改了发我qq2691224103
210
2599
2599
2016-7-6
546 小时
发表于 2016-7-30 00:55:22 | 显示全部楼层
我也下载来看看,谢谢楼主分享!
把复杂的事,做简单!
2016-8-3
发表于 2016-8-3 10:41:46 | 显示全部楼层
好东西,学习中
125
170
170
2016-5-13
76 小时
发表于 2016-8-3 11:54:26 | 显示全部楼层
学习了
2016-8-4
发表于 2016-8-4 14:46:22 | 显示全部楼层
360浏览器不能下载附件,用IE就可以下载,NND,360什么时候沦落到这个地步了!?
2016-6-16
发表于 2016-8-8 17:10:16 | 显示全部楼层
楼主是个有心人。。。
2016-6-16
发表于 2016-8-8 17:16:23 | 显示全部楼层
附件无法下载。。。。。??
71
71
2016-7-28
12 小时
发表于 2016-8-9 10:30:52 | 显示全部楼层
多谢分享
2016-8-4
发表于 2016-8-10 21:14:38 | 显示全部楼层
你的程序我有点看不懂啊,能否指点一下啊
98
1197
1197
2012-3-26
387 小时
发表于 2016-8-15 21:35:51 | 显示全部楼层
为什么不能下载了?
23
183
183
2016-7-24
22 小时
发表于 2016-8-16 13:03:28 | 显示全部楼层
支持……
36
36
2015-8-10
发表于 2016-8-23 14:51:20 | 显示全部楼层
谢谢楼主的分享
2016-7-17
发表于 2016-8-24 20:27:20 | 显示全部楼层
最近在搞这个
101
101
2016-8-30
15 小时
发表于 2016-8-30 15:53:49 | 显示全部楼层
试试看
2016-8-2
11 小时
发表于 2016-8-31 22:20:56 | 显示全部楼层
dop101 发表于 2016-7-27 11:05
楼主的程序,设置的是TIM3,占空比也设置的是TIM3的,为什么中断函数里面是TIM4中断采集TIM4的占空比,从程 ...
tim4是用来捕获tim3产生的pwm波的
东辉 该用户已被删除
发表于 2016-9-17 23:06:46 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
95
95
2016-9-26
17 小时
发表于 2016-9-27 17:10:27 | 显示全部楼层
如何达到22MHz的PWM输出啊
yimolijie 该用户已被删除
发表于 2016-9-30 09:13:38 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
39
39
2016-6-13
发表于 2016-10-31 16:07:53 | 显示全部楼层
学习了,这个功能以前一直没搞懂
58
163
163
2015-8-5
发表于 2016-11-3 19:48:41 | 显示全部楼层
多谢分享!
2016-12-14
发表于 2016-12-14 14:51:17 | 显示全部楼层
正在调试,借用了
122
122
2015-11-1
44 小时
发表于 2016-12-20 08:43:18 | 显示全部楼层
附件怎么下载不了?
chenqingyu 该用户已被删除
发表于 2017-1-10 18:24:51 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
chenqingyu 该用户已被删除
发表于 2017-1-10 18:29:21 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
41
1506
1506
2016-7-3
270 小时
发表于 2017-1-10 22:09:02 | 显示全部楼层
楼主的帖子写的很好,很容易能看懂!受教了!
2019-7-30
发表于 2017-1-11 16:31:30 | 显示全部楼层
最近多路PWM输入,检测不正常,学习下
fulmine 该用户已被删除
发表于 2017-1-13 09:09:15 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
84
84
2020-11-14
23 小时
发表于 2017-1-13 18:57:12 | 显示全部楼层
下载不了,怎么解
liuhanqiu 该用户已被删除
发表于 2017-2-5 19:45:31 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
170
170
2016-5-17
25 小时
发表于 2017-2-6 09:10:47 | 显示全部楼层
不错
145
602
602
2015-7-11
94 小时
发表于 2017-2-18 11:10:02 | 显示全部楼层
谢谢分享,很赞!!!
42
42
2016-10-9
发表于 2017-2-27 21:13:05 | 显示全部楼层
很老但是很好,只要修改捕获计时器的周期就可以检测低频信号,如果测量结果不准确可能是计数溢出了,小伙伴多注意。
46
46
2015-9-19
发表于 2017-3-3 09:01:28 | 显示全部楼层
楼主, 代码能发我一份么?    网页上下载不了。邮箱:369610755@qq.com
83
83
2017-2-20
16 小时
发表于 2017-3-3 14:32:11 | 显示全部楼层
需要的时候就找到了
81
81
2017-3-8
37 小时
发表于 2017-3-8 20:50:10 | 显示全部楼层
谢谢楼主
310
495
495
2016-12-31
63 小时
发表于 2017-3-11 14:05:13 | 显示全部楼层
lifan_cn 发表于 2013-10-27 19:27
回复【3楼】aming882046:
tim4的pb7是捕获引脚你说的很对,tim3是产生P ...
学习ing
310
495
495
2016-12-31
63 小时
发表于 2017-3-11 14:06:08 | 显示全部楼层
fan_xj 发表于 2013-10-28 21:39
我也下载不了。。。。
我也不能下载,郁闷
310
495
495
2016-12-31
63 小时
发表于 2017-3-11 14:06:26 | 显示全部楼层
lifan_cn 发表于 2013-10-29 20:46
 好多人下载不了,有好几种浏览器不支持下载,在上传一遍试试,看看可不可以下载1
谢谢楼主
105
304
304
2016-12-6
40 小时
发表于 2017-3-11 16:13:58 | 显示全部楼层
谢谢分享
48
161
161
2016-11-25
28 小时
发表于 2017-3-12 13:59:58 | 显示全部楼层
MARK\\\
inanLH 该用户已被删除
发表于 2017-4-11 11:12:03 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
43
43
2015-5-18
发表于 2017-4-21 09:15:37 | 显示全部楼层
arao和xiaomi 发表于 2017-3-11 14:06
我也不能下载,郁闷
我也不能下载
43
43
2015-5-18
发表于 2017-4-21 15:21:30 | 显示全部楼层
怎么下载不了,换浏览器也不行
2020-10-19
发表于 2017-5-7 11:48:12 | 显示全部楼层
顶贴下载
GMT+8, 2026-11-11 00:47
