查看: 7237|回复: 1
有没有用过STC12C5A60S2 PWM变频输出,并且脉冲计数的????
72
227
227
2013-10-16
发表于 2013-10-31 15:05:42 | 显示全部楼层 |阅读模式
#include <stc12c5a60s2.h>
#define FOSC 12000000L
sbit led0=P0^6;
sbit led1=P0^7;
sbit PWM0=P1^3;
sbit PWM1=P1^4;
sbit int0=P3^2;
unsigned char HZ;
unsigned long PCHZ;
unsigned char xdata rsbuf[64],ssbuf[64];
unsigned char yb,syb;
unsigned int m;
void INT0_Init()
     IT0=1;EX0=1;
void ENPCA_Init(unsigned char tt)
    CMOD |=0x04;
    CL=0;CH=0;
    CR=1;
     AUXR |=0x80;
    TMOD |=0x02;
    TH0= tt;
    TL0= tt;
    TR0= 1;
    ET0= 1;
void PWM_OUT(unsigned char channel,unsigned char start_value)
     if(channel == 0)
          CCAP0L = start_value; //Set the initial value same as CCAP0H
          CCAP0H = start_value; //25% Duty Cycle
          CCAPM0 = 0x42;   //0x42 Setup PCA module 0 in PWM mode
     if(channel == 1)
          CCAP1L = start_value; //Set the initial value same as CCAP1H
          CCAP1H = start_value; //25% Duty Cycle
          CCAPM1 = 0x42;   //0x42 Setup PCA module 1 in PWM mode
void Serical_Init()
     PCON |= 0x80;  //使能波特率倍速位SMOD
     SCON = 0x50;  //8位数据,可变波特率
     BRT = 0xC4;  //设定独立波特率发生器重装值
     AUXR |= 0x04;  //独立波特率发生器时钟为Fosc,即1T
     AUXR |= 0x01;  //串口1选择独立波特率发生器为波特率发生器
     AUXR |= 0x10;  //启动独立波特率发生器
     ES=1;
void main()
     Serical_Init();
     INT0_Init();
     EA=1;
          led0=PWM0;
          if(m>10000)
               TR0=0;ET0=0;CR=0;EX0=0;
               m=0;
void Serical_Interrupt() interrupt 4
        unsigned char temp,temp_next;
     if(RI)
          RI=0;
          temp=SBUF;
          rsbuf[yb]=temp;
          yb++;
          if((rsbuf[0]==':')&&(temp_next=0x0D)&&(temp==0x0A))
               yb=0;
               CHZ=(rsbuf[1]-0x30)*10000+(rsbuf[2]-0x30)*1000+(rsbuf[3]-0x30)*100+(rsbuf[4]-0x30)*10+(rsbuf[5]-0x30)*1;
               HZ=256-FOSC/256/PCHZ;
               WM_OUT(0,0X80);
               ENPCA_Init(HZ);
     if(TI)
     {TI=0;}
void INT0_Interrupt() interrupt 0
     m++;
通过外部中断来计算PWM个数,PWM最大频率为10K(个人自定义的),这样的话外部中断完全可以采集到的,但是呢在运行的过程中PWM脉冲个数总会比预想的要多这是个什么情况??
发表于 2013-10-31 21:15:51 | 显示全部楼层
帮顶。
GMT+8, 2026-11-14 08:33
