查看: 13144|回复: 6
关于ch376t的问题,紧急求助大虾们
53
53
2013-4-19
发表于 2013-11-26 14:58:06 | 显示全部楼层 |阅读模式
ch376t一些初始化的东西都是对的,发送DISK_CONNECT命令也能得到预期的结果。可是发送DISK_MOUNT命令,再发送GET_STATUS只能收到31,22,7f的序列,没有一个是正确的。
53
53
2013-4-19
 楼主| 发表于 2013-11-26 15:01:34 | 显示全部楼层
 * SPI operation
static void spi2_init(void)
    RCC->APB2ENR |= ( 1 << 3 ); // enable GPIOB clock
    RCC->APB1ENR |= ( 1 << 14 ); // enable SPI2 clock
    // config GPIOB B12,13,14,15
    GPIOB->CRH &= ~( (unsigned long)0xffff << 16 );
     GPIOB->CRH |= ( (unsigned long)0xbbb3 << 16 );
    GPIOB->ODR |= ( 0xf << 12 );
    // config SPI
    SPI2->CR1 &= ~( 1 << 0 ); // CPHA == 0
    SPI2->CR1 &= ~( 1 << 1 ); // CPOL == 0
    SPI2->CR1 |= ( 1 << 2 ); // be master
    SPI2->CR1 &= ~( 7 << 3 );
    SPI2->CR1 |= ( 7 << 3 ); // CLK / 4
    SPI2->CR1 &= ~( 1 << 7 ); // MSB first , Fsck = Fcpu / 256
     SPI2->CR1 |= ( 1 << 8 ); // SSI
     SPI2->CR1 |= ( 1 << 9 ); // SSM
     SPI2->CR1 &= ~( 1 << 10); // full duplex
     SPI2->CR1 &= ~( 1 << 11); // 8 bits format
     SPI2->CR1 |= ( 1 << 6 ); // enable SPI2
     spi2_read_writ_byte(0xff);
unsigned char spi2_read_writ_byte( unsigned char tx_data )
    unsigned char retry = 0 ;
    while( ( SPI2->SR & ( 1 << 1 ) ) == 0 )
        retry ++ ;
    SPI2->DR = tx_data ;
    retry = 0 ;
     while( ( SPI2->SR & ( 1 << 0 ) ) == 0 )
    retry ++ ;
    return SPI2->DR ;
53
53
2013-4-19
 楼主| 发表于 2013-11-26 15:03:23 | 显示全部楼层
回复【2楼】wangwum:
int ch376t_send_cmd( unsigned char cmd )
    return spi2_read_writ_byte(cmd);
int ch376t_write_byte( unsigned char data )
    return spi2_read_writ_byte(data);
unsigned char ch376t_read_byte(void)
    return spi2_read_writ_byte(0xff);
这些是封装代码
53
53
2013-4-19
 楼主| 发表于 2013-11-26 15:12:28 | 显示全部楼层
回复【2楼】wangwum:
static int start_disk_mount(void)
    unsigned char status = 0 ;
    int i = 0 ;
    CH376T_SEL();
    delay_ms(10);
    do
        ch376t_write_byte(DISK_MOUNT);
        delay_ms(10);
        status = ch376t_write_byte(GET_STATUS);
        printer_print( "status : %x\n", status);
        status = ch376t_read_byte();
        i ++ ;
    }while( ( status != USB_INT_SUCCESS ) && ( i < 5 ) );
    if( i >= 5 )
        return -1 ;
    CH376T_DSL();
    return 0 ;
这是发送DISK_MOUNT命令的函数。
38
2061
3273
3273
2012-1-16
37 小时
发表于 2013-11-26 20:18:01 | 显示全部楼层
没用过,帮顶
站在巨人的肩膀上不断的前进。。。
53
53
2013-4-19
 楼主| 发表于 2013-11-26 20:19:20 | 显示全部楼层
回复【5楼】xiaoyan:
回复【5楼】xiaoyan:
谢谢你的帮顶之恩。
95
347
347
2018-3-20
75 小时
发表于 2023-4-24 08:34:25 | 显示全部楼层
GMT+8, 2026-10-29 08:09
